    [Plugin] Add comments to your file
    104 Posts 20 Posters 28.7k Views 20 Watching
    • inteloideI Offline
      inteloide
      Hello Glro,
      Actually, the plugin should works like this : when selecting a scene in Sketchup, the linked (if defined) tab in plugin is shown.
      The opposite (when clicking on a tab in plugin, show the scene in Sketchup) is not implemented yet. I could, if you need it.
      About the javascript error you have, could you please tell me more : when do you have this error, what did you do before ?
      Inteloide
      Humanity will do a huge step when the IT professionals will understand that computers are tools...
        glro
        @inteloide said:
        Hello Glro,
        Inteloide
        when i clic on a scene tab in sketchup, it doesn't change anything in the comment window, even if i previously set a link between a comment tab and a scene tab
        the error message i sent, i don't remember how it popped up
        here is a new one: it appeared when i clicked on the comment button to show again the comment window, after closing it using the cross in the upper left corner
          inteloide
          tiiuuuu !!!!
          I've same bug when changing the language.... not good
            inteloide
            okay, version 1.5.2 should solve javascript issue.
            About your tab-scene issue, I tried from an empty file : it works.
            Could you please open the ruby consol window (Window/Ruby Consol) to see if error appear Inside, when setting the link and changing the scene in SU ?
            Thank you.
            Inteloide
              glro
              Thank you.
              Inteloide
              no error message in the ruby console ... because it works perfectly!
              i clic on the scene tab and the comment window shows the corresponding tab, as said
              after installation, i had to close sketchup and open it again, though; just after the installation, it didn't work
              thank you, seems operational; i am not sure about the use of a backward link between the comment window and the scenes...
                inteloide
                @glro said:
                I don't know how to proceed to make it work for the first time. I think, it's the same of some other extension (from other developers) I installed in the past.
                No big problem, I think.
                I just add an help file in first post of this thread, in pdf format.
                Inteloide
                  glro
                  Inteloide
                  i agree; you just have to know it
                  the plugin seems to be ready for use; adding an active link to a web page would be nice, but the link can be added and copied/pasted in an internet browser also, so it is not very important
                    alexanor
                    Great plugin!
                    Made translation for the Russian language.
                    elsif @option_langue=="ru" then
                    @strWindowName="Заметки"
                    @strButtonsTitles=["Добавить текущую дату и время", "Настройки", "О Плагине"]
                    @strModifyTabName="Настройки Вкладки"
                    @strDeleteTab="Удалить Вкладку"
                    @strButtonsTexts=["Сохранить","Отмена"]
                    @strAbout="О Плагине"
                    @strTexts=["Язык",
                    "Автоматически открывать окно, если существуют заметки",
                    "Автоматически открывать окно, даже если заметок нет",
                    "Показывать окончание заметки при открытии вкладки"]
                    @strTabName="Название Заметки: "
                    @strTab=""
                    @strSureToDeleteTab = "Вы уверены, что хотите УДАЛИТЬ эту вкладку?"
                    @strTabOptionName="Настройки вкладки"
                    @strNoLink="-- Не связывать со Сценой --"
                    @strTextsOptionsTab=["Имя Вкладки :","Связка со Сценой :","Применить","Отмена"]
                      inteloide
                      Hello
                      Thanks alexanor for this translation.
                      For Glro, in version 1.5.4, I optimized the code in order have the text area more reactive.
                      I hope it will works, I just have one model at works that slow down the text area, so I cannot check at home.
                      Regards.
                      Inteloide
                        inteloide
                        See life in colors !!
                        New version added : set colors to your tabs :
                        Colored tabs
                        Enjoy !
                        Inteloide
                          alexanor
                          I can not find a link to download version 1.6.1...
                            inteloide
                            Correcto !
                            Just update the post...
                            Inteloide
                              alexanor
                              Excellent! Now it works!
                                alexanor
                                Inteloide whether you can connect to the script calculator? It would be convenient to make calculations and take notes in one window ...
                                  Aerilius
                                  Can't you do calculations already in the operating system's calculator, in SketchUp's Ruby Console and in various Ruby Console plugins? You can then copy&paste the calculations that you want to keep.
                                  The comments plugin is to save text that the user enters, and not to automatically evaluate and manipulate parts of the text. I think it should keep focussed to do this task well.
                                    inteloide
                                    Hello !
                                    Is this script something that already exist ? If yes, could you send me the link ?
                                    Inteloide
                                      alexanor
                                      I do not want to open many windows in Sketchup. If this plugin can do "Add comments".
                                      Inteloide, thank you for the effort!
                                      • U Offline
                                        unearthed
                                        Great plugin, very, very useful, and seconding the idea of building a/the calculator into the comment box.
                                        Growplan - People ∩ Plants ∩ Place
                                        windows 7 64b, 4GB RAM, SU 8.0.16846
                                        Gimp, QGIS, Vectorworks 12, Bricscad 11
                                          inteloide
                                          Hello !
                                          I'm back after one week of holidays in Rome. Such a nice town !
                                          So if I understand correctly your request, you want me to add a button that allow you to have a calculator, like Windows'one, in the "add comment" plugin, without openning another window, correct ?
                                          If yes does anybody knows a free plugin I can insert in my script ? This will make my work easier !
                                          Inteloide
                                            inteloide
                                            Let me guess, you look for something like this :
                                            Future version 1.7.0
                                            Isn't it ?
                                            I'm close to release it...
                                            I'll try to link it with VCB.
                                            Inteloide
                                            • 3 / 6
