    [Plugin] Add comments to your file
    104 Posts 20 Posters 30.7k Views 20 Watching
    • G
      glro
      error
      @inteloide said:
      @box said:
      Sorry, I just noticed that it has a second error, thought it was a repeat but it is a different line.
      There were a lot of bugs actually... Thanks for raising the error you had.
      Version 1.5.1, just posted, corrects the tab deletion issue.
      Inteloide
      • inteloideI
        inteloide
        Hello Glro,
        Actually, the plugin should works like this : when selecting a scene in Sketchup, the linked (if defined) tab in plugin is shown.
        The opposite (when clicking on a tab in plugin, show the scene in Sketchup) is not implemented yet. I could, if you need it.
        About the javascript error you have, could you please tell me more : when do you have this error, what did you do before ?
        Inteloide
        Humanity will do a huge step when the IT professionals will understand that computers are tools...
        • G
          glro
          @inteloide said:
          Hello Glro,
          Inteloide
          when i clic on a scene tab in sketchup, it doesn't change anything in the comment window, even if i previously set a link between a comment tab and a scene tab
          the error message i sent, i don't remember how it popped up
          here is a new one: it appeared when i clicked on the comment button to show again the comment window, after closing it using the cross in the upper left corner
          • inteloideI
            inteloide
            tiiuuuu !!!!
            I've same bug when changing the language.... not good
            • inteloideI
              inteloide
              okay, version 1.5.2 should solve javascript issue.
              About your tab-scene issue, I tried from an empty file : it works.
              Could you please open the ruby consol window (Window/Ruby Consol) to see if error appear Inside, when setting the link and changing the scene in SU ?
              Thank you.
              Inteloide
              • G
                glro
                Thank you.
                Inteloide
                no error message in the ruby console ... because it works perfectly!
                i clic on the scene tab and the comment window shows the corresponding tab, as said
                after installation, i had to close sketchup and open it again, though; just after the installation, it didn't work
                thank you, seems operational; i am not sure about the use of a backward link between the comment window and the scenes...
                • inteloideI
                  inteloide
                  @glro said:
                  I don't know how to proceed to make it work for the first time. I think, it's the same of some other extension (from other developers) I installed in the past.
                  No big problem, I think.
                  I just add an help file in first post of this thread, in pdf format.
                  Inteloide
                  • G
                    glro
                    Inteloide
                    i agree; you just have to know it
                    the plugin seems to be ready for use; adding an active link to a web page would be nice, but the link can be added and copied/pasted in an internet browser also, so it is not very important
                      alexanor
                      Great plugin!
                      Made translation for the Russian language.
                      elsif @option_langue=="ru" then
                      @strWindowName="Π—Π°ΠΌΠ΅Ρ‚ΠΊΠΈ"
                      @strButtonsTitles=["Π”ΠΎΠ±Π°Π²ΠΈΡ‚ΡŒ Ρ‚Π΅ΠΊΡƒΡ‰ΡƒΡŽ Π΄Π°Ρ‚Ρƒ ΠΈ врСмя", "Настройки", "О ПлагинС"]
                      @strModifyTabName="Настройки Π’ΠΊΠ»Π°Π΄ΠΊΠΈ"
                      @strDeleteTab="Π£Π΄Π°Π»ΠΈΡ‚ΡŒ Π’ΠΊΠ»Π°Π΄ΠΊΡƒ"
                      @strButtonsTexts=["Π‘ΠΎΡ…Ρ€Π°Π½ΠΈΡ‚ΡŒ","ΠžΡ‚ΠΌΠ΅Π½Π°"]
                      @strAbout="О ПлагинС"
                      @strTexts=["Π―Π·Ρ‹ΠΊ",
                      "АвтоматичСски ΠΎΡ‚ΠΊΡ€Ρ‹Π²Π°Ρ‚ΡŒ ΠΎΠΊΠ½ΠΎ, Ссли ΡΡƒΡ‰Π΅ΡΡ‚Π²ΡƒΡŽΡ‚ Π·Π°ΠΌΠ΅Ρ‚ΠΊΠΈ",
                      "АвтоматичСски ΠΎΡ‚ΠΊΡ€Ρ‹Π²Π°Ρ‚ΡŒ ΠΎΠΊΠ½ΠΎ, Π΄Π°ΠΆΠ΅ Ссли Π·Π°ΠΌΠ΅Ρ‚ΠΎΠΊ Π½Π΅Ρ‚",
                      "ΠŸΠΎΠΊΠ°Π·Ρ‹Π²Π°Ρ‚ΡŒ ΠΎΠΊΠΎΠ½Ρ‡Π°Π½ΠΈΠ΅ Π·Π°ΠΌΠ΅Ρ‚ΠΊΠΈ ΠΏΡ€ΠΈ ΠΎΡ‚ΠΊΡ€Ρ‹Ρ‚ΠΈΠΈ Π²ΠΊΠ»Π°Π΄ΠΊΠΈ"]
                      @strTabName="НазваниС Π—Π°ΠΌΠ΅Ρ‚ΠΊΠΈ: "
                      @strTab=""
                      @strSureToDeleteTab = "Π’Ρ‹ ΡƒΠ²Π΅Ρ€Π΅Π½Ρ‹, Ρ‡Ρ‚ΠΎ Ρ…ΠΎΡ‚ΠΈΡ‚Π΅ Π£Π”ΠΠ›Π˜Π’Π¬ эту Π²ΠΊΠ»Π°Π΄ΠΊΡƒ?"
                      @strTabOptionName="Настройки Π²ΠΊΠ»Π°Π΄ΠΊΠΈ"
                      @strNoLink="-- НС ΡΠ²ΡΠ·Ρ‹Π²Π°Ρ‚ΡŒ со Π‘Ρ†Π΅Π½ΠΎΠΉ --"
                      @strTextsOptionsTab=["Имя Π’ΠΊΠ»Π°Π΄ΠΊΠΈ :","Бвязка со Π‘Ρ†Π΅Π½ΠΎΠΉ :","ΠŸΡ€ΠΈΠΌΠ΅Π½ΠΈΡ‚ΡŒ","ΠžΡ‚ΠΌΠ΅Π½Π°"]
                      • inteloideI
                        inteloide
                        Hello
                        Thanks alexanor for this translation.
                        For Glro, in version 1.5.4, I optimized the code in order have the text area more reactive.
                        I hope it will works, I just have one model at works that slow down the text area, so I cannot check at home.
                        Regards.
                        Inteloide
                        • inteloideI
                          inteloide
                          See life in colors !!
                          New version added : set colors to your tabs :
                          Colored tabs
                          Enjoy !
                          Inteloide
                            alexanor
                            I can not find a link to download version 1.6.1...
                            • inteloideI
                              inteloide
                              Correcto !
                              Just update the post...
                              Inteloide
                                alexanor
                                Excellent! Now it works!
                                  alexanor
                                  Inteloide whether you can connect to the script calculator? It would be convenient to make calculations and take notes in one window ...
                                    Aerilius
                                    Can't you do calculations already in the operating system's calculator, in SketchUp's Ruby Console and in various Ruby Console plugins? You can then copy&paste the calculations that you want to keep.
                                    The comments plugin is to save text that the user enters, and not to automatically evaluate and manipulate parts of the text. I think it should keep focussed to do this task well.
                                    • inteloideI
                                      inteloide
                                      Hello !
                                      Is this script something that already exist ? If yes, could you send me the link ?
                                      Inteloide
                                        alexanor
                                        I do not want to open many windows in Sketchup. If this plugin can do "Add comments".
                                        Inteloide, thank you for the effort!
                                        • U
                                          unearthed
                                          Great plugin, very, very useful, and seconding the idea of building a/the calculator into the comment box.
                                          Growplan - People ∩ Plants ∩ Place
                                          windows 7 64b, 4GB RAM, SU 8.0.16846
                                          Gimp, QGIS, Vectorworks 12, Bricscad 11
                                          • inteloideI
                                            inteloide
                                            Hello !
                                            I'm back after one week of holidays in Rome. Such a nice town !
                                            So if I understand correctly your request, you want me to add a button that allow you to have a calculator, like Windows'one, in the "add comment" plugin, without openning another window, correct ?
                                            If yes does anybody knows a free plugin I can insert in my script ? This will make my work easier !
                                            Inteloide
                                            • 3 / 6
