    [Plugin] Add comments to your file
    104 Posts 20 Posters 30.7k Views 20 Watching
    • BoxB
      Still getting the same error.
      • BoxB
        Sorry, I just noticed that it has a second error, thought it was a repeat but it is a different line.
        • inteloideI
          inteloide
          There were a lot of bugs actually... Thanks for raising the error you had.
          Version 1.5.1, just posted, corrects the tab deletion issue.
          Inteloide
          Humanity will do a huge step when the IT professionals will understand that computers are tools...
          • G
            glro
            just downloaded the 1.5.1 version
            found out you have to press on "TAB" to link a tab to a scene
            but actually no link seems to be made on my computer, because when i clic on the tab in comment window, it doesn't show the linked scene in sketchup, and when i clic on the scene tab in sketchup, it does'nt show the linked tab comment
            i am probably missing something...
            • G
              glro
              error
              Inteloide
              • inteloideI
                inteloide
                Hello Glro,
                Actually, the plugin should works like this : when selecting a scene in Sketchup, the linked (if defined) tab in plugin is shown.
                The opposite (when clicking on a tab in plugin, show the scene in Sketchup) is not implemented yet. I could, if you need it.
                About the javascript error you have, could you please tell me more : when do you have this error, what did you do before ?
                Inteloide
                • G
                  glro
                  @inteloide said:
                  Hello Glro,
                  Inteloide
                  when i clic on a scene tab in sketchup, it doesn't change anything in the comment window, even if i previously set a link between a comment tab and a scene tab
                  the error message i sent, i don't remember how it popped up
                  here is a new one: it appeared when i clicked on the comment button to show again the comment window, after closing it using the cross in the upper left corner
                  • inteloideI
                    inteloide
                    tiiuuuu !!!!
                    I've same bug when changing the language.... not good
                    • inteloideI
                      inteloide
                      okay, version 1.5.2 should solve javascript issue.
                      About your tab-scene issue, I tried from an empty file : it works.
                      Could you please open the ruby consol window (Window/Ruby Consol) to see if error appear Inside, when setting the link and changing the scene in SU ?
                      Thank you.
                      Inteloide
                      • G
                        glro
                        Thank you.
                        Inteloide
                        no error message in the ruby console ... because it works perfectly!
                        i clic on the scene tab and the comment window shows the corresponding tab, as said
                        after installation, i had to close sketchup and open it again, though; just after the installation, it didn't work
                        thank you, seems operational; i am not sure about the use of a backward link between the comment window and the scenes...
                        • inteloideI
                          inteloide
                          @glro said:
                          I don't know how to proceed to make it work for the first time. I think, it's the same of some other extension (from other developers) I installed in the past.
                          No big problem, I think.
                          I just add an help file in first post of this thread, in pdf format.
                          Inteloide
                          • G
                            glro
                            Inteloide
                            i agree; you just have to know it
                            the plugin seems to be ready for use; adding an active link to a web page would be nice, but the link can be added and copied/pasted in an internet browser also, so it is not very important
                              alexanor
                              Great plugin!
                              Made translation for the Russian language.
                              elsif @option_langue=="ru" then
                              @strWindowName="Заметки"
                              @strButtonsTitles=["Добавить текущую дату и время", "Настройки", "О Плагине"]
                              @strModifyTabName="Настройки Вкладки"
                              @strDeleteTab="Удалить Вкладку"
                              @strButtonsTexts=["Сохранить","Отмена"]
                              @strAbout="О Плагине"
                              @strTexts=["Язык",
                              "Автоматически открывать окно, если существуют заметки",
                              "Автоматически открывать окно, даже если заметок нет",
                              "Показывать окончание заметки при открытии вкладки"]
                              @strTabName="Название Заметки: "
                              @strTab=""
                              @strSureToDeleteTab = "Вы уверены, что хотите УДАЛИТЬ эту вкладку?"
                              @strTabOptionName="Настройки вкладки"
                              @strNoLink="-- Не связывать со Сценой --"
                              @strTextsOptionsTab=["Имя Вкладки :","Связка со Сценой :","Применить","Отмена"]
                              • inteloideI
                                inteloide
                                Hello
                                Thanks alexanor for this translation.
                                For Glro, in version 1.5.4, I optimized the code in order have the text area more reactive.
                                I hope it will works, I just have one model at works that slow down the text area, so I cannot check at home.
                                Regards.
                                Inteloide
                                • inteloideI
                                  inteloide
                                  See life in colors !!
                                  New version added : set colors to your tabs :
                                  Colored tabs
                                  Enjoy !
                                  Inteloide
                                    alexanor
                                    I can not find a link to download version 1.6.1...
                                    • inteloideI
                                      inteloide
                                      Correcto !
                                      Just update the post...
                                      Inteloide
                                        alexanor
                                        Excellent! Now it works!
                                          alexanor
                                          Inteloide whether you can connect to the script calculator? It would be convenient to make calculations and take notes in one window ...
                                            Aerilius
                                            Can't you do calculations already in the operating system's calculator, in SketchUp's Ruby Console and in various Ruby Console plugins? You can then copy&paste the calculations that you want to keep.
                                            The comments plugin is to save text that the user enters, and not to automatically evaluate and manipulate parts of the text. I think it should keep focussed to do this task well.
                                            • 3 / 6
