    [Concept]Shortcutter for SketchUp
    36 Posts 13 Posters 8.8k Views 13 Watching
    • BoxB Offline
      I wonder how many people gave you a thumbs up instead of actually voting.
        21 positive votes
        we could look at the down votes but what for?
        • BoxB Offline
          No, I just meant that it looks like some people may have used the thumbs up rather than the poll. So maybe the 21 thumbs adds to the current 57 votes making it already 78.
            True dat....
            79 it is..keep voting
              After much arm wrestling with Gabor Shortcutter is now in the PluginStore.
              TIG has graced the ruby lines with his magic and Gabor fixed it!
              I have never seen such debate over /n and /t. But in the end //n won! Hooray for the extra /.
              • G Online
                Gábor
                Well..... Actually it was \n. 👿
                • G Online
                  Gábor
                  So the ".....rather drab version...." is out, some more votes are needed for the cloud enabled version dev.
                  • djohnson.nzD Offline
                    djohnson.nz
                    Can this include a tools setting as well so when you download from the cloud it syncs not only your shortcuts but your toolbar settings as well.
                    Cheers...
                    nO fiKst ideas
                    • Dan RathbunD Offline
                      Dan Rathbun
                      I had already made this for my own use in table form.
                      Was going to have it user selectable-sort by both columns.
                      I did not think to display in by the menu, as most users want to know if a certain key combo has been assigned, or if a certain command or tool has a shortcut.
                      I'm not here much anymore.
                      • G Online
                        Gábor
                        Cheers...
                        We would like to extend the capabities of the Sketchucation Tools toolset in the future. As you've seen it is under continous developement and new and newer features are introduced release by release.
                        Certainly the toolbar settins is an area what will be addressed in the near future. At the moment I can't tell you if that will be combined with the shortcuts element of the toolset or with the bundles element or it will be a standelone tool.
                        Watch the future releases of Shetchucation Plugins! 😄
                        • G Online
                          Gábor
                          @dan rathbun said:
                          ...in by the menu, as most users want to know if a certain key combo has been assigned, or if a certain command or tool has a shortcut.
                          Thank you Dan. It is a very good idea to have multiply views (sortings) of the shortcuts.
                          You might have noticed that we'd already come out with the beta version of the tool: http://sketchucation.com/pluginstore?pln=shortcutter
                            Dan Rathbun
                            @gábor said:
                            You might have noticed that we'd already come out with the beta version of the tool.
                            I had not yet tried it.
                            My edition, I did not yet get to the sorted table version.
                            I think the Active-X Tabular Data Control "tdc.ocx" is MS Windows only, .. but was wondering if it was added into HTML 5+ ? (.. so it could be cross-platform.)
                            • G Online
                              Gábor
                              I doubt that in the near future there will be any cross-browser compatible "HTML only" way to implement TAB control. But there are some nice frameworks like "Bootstrap" that implement it in a cross-browser compatible way by using Javascript and .css.
                                Dan Rathbun
                                OK I tested it. Had to mod it because I do not run SketchUcation Tools under SU2014.
                                And I would have the menuitem under the "Help" menu anyway.
                                Forcing users to have SUT loaded is poopie. I cannot run it all the time on older SU versions because of those dang random named VB scripts cause Comodo warnings.
                                  Dan Rathbun
                                  33 JAVASCRIPT SOLUTIONS FOR SORTING TABLES
                                    Dan Rathbun
                                    Vote: I actually do not care, as I do not keep plugins in the cloud.
                                    • G Online
                                      Gábor
                                      @Dan: Thank you very much for the suggestions and for trying out the plugin.
                                      • sallyS Offline
                                        sally
                                        YES PLEEEEEEEZZZZEEEEEE! Having just redone mine for both my macs for SU14 upgrade...I was just thinking how useful it would be to have this automated!!!!! 😄
                                          August
                                          Well, I got here too late for the poll, but I do see that it reached 90 before being closed, not counting those who thumbed-up instead of poll voting. Does that mean it's a go for the non-drab version? Would another vote help?
                                          “An idea, like a ghost, must be spoken to a little before it will explain itself.”
                                          [floatr:v1mcbde2]-- Charles Dickens[/floatr:v1mcbde2]
                                          • 2 / 2
