    Batch render
    renderpluginsextensions
    16 Posts 6 Posters 3.3k Views 6 Watching
    • andybotA Offline
      andybot
      Have you upgraded to the latest 2.0 service pack? It seems to handle the batch render better.
      • brodieB Offline
        brodie
        I thought I did. I'm not quite sure how to check which version I have installed.
        πŸ˜•
        -Brodie
        • dkendigD Offline
          dkendig
          Window->Preferences->Extensions and then click on V-Ray for SketchUp. You should see the version number listed in the details at the bottom of the window. I'm told that this issue may actually be fixed in a recent nightly build, if not the service release.
          Devin Kendig
          Developer
          • brodieB Offline
            brodie
            Thanks Devin,
            It looks like I'm on 2.00.24261
            • dkendigD Offline
              dkendig
              ok, so that's the service release. I believe you have nightly access, could you try in a nightly build?
              Devin Kendig
              Developer
              • brodieB Offline
                brodie
                Hrm, I could but I'm not sure it's worth the hassle, especially without knowing if anything will change. I was just hoping the issue was on my end. I've got a farm of about 20 machines so updating is quite an undertaking. I was hoping to stay on a stable release for a bit before trying a new nightly.
                I assume others have gotten batch render to work though?
                -Brodie
                • andybotA Offline
                  andybot
                  -Brodie
                  It's been working for me lately.
                  Can you try just updating one DR node and do a test run first?
                  Andy
                  • dkendigD Offline
                    dkendig
                    at our office, I have all of the machines in our render farm, syncing the ASGVIS folder, so they all have the same version of DR running. No problems so far, except that you need to ensure that the dr spawner is restarted after the sync is complete.
                    Devin Kendig
                    Developer
                    • brodieB Offline
                      brodie
                      Great tip Devin, I hadn't thought of that. Are you using some sort of syncing program or using symbolic links so that the computers are basically grabbing from the same folder?
                      -Brodie
                      • dkendigD Offline
                        dkendig
                        I use a NAS drive, Synology DS412+, which has a syncing service called Cloud Station. You could similarly use Box, Dropbox, Google Drive, etc. Just make the whole ASGVIS folder synced between them all, shut down the spawner on all of the machines, install an update on one machine, wait for the files to propagate (shouldn't take long) and then start it up on all of the machines again.
                        Devin Kendig
                        Developer
                          g.moggel
                          could you guys solve this? having the same problem here.
                          cheers,
                          mo
                          • TedVitale_CGT Offline
                            TedVitale_CG
                            To use the batch render tool in V-Ray 2.0 you no longer need to check the batch render button in your Globals roll-out menu. What you may want to do is set your scene delay to 0, and turn off scene transitions all together. That could be whats causing it. It may be getting stuck between scenes.
                            Ted Vitale
                            Owner | Creative Director
                            http://www.voxl.vision
                            • N Offline
                              ND1969
                              I have got the same problem with the same build as mentioned by Brodie. It doesn't want to start te next render. Anyone have a solution for this problem? I could use some sleep, batch render would help!
                                TedVitale_CG
                                The build described is an old build. Id recommend upgrading to the latest version of V-Ray for Sketchup, Service Pack 3, which is on the website under downloads: http://www.chaosgroup.com/en/2/downloads.html. After you log in you'll have access to the latest build.
                                Ted Vitale
