    Vray 2.0 service pack is here!!
    renderpluginsextensions
    25 Posts 14 Posters 17.8k Views 14 Watching
    • dcauldwellD Offline
      dcauldwell
      openspaces
      I'm having similar difficulty installing. I think I may have made the mistake of downloading directly from the website instead of going to my re-seller who provided the dongle.
      Vray hasn't installed properly and now I have no vray at all either in SU2013 or 2014.
      I'm still trying to sort it out.
      Sketchup 2017
      (vray 2.00)
      • F Offline
        floffy1983
        Openspace continued.
        Installation problem same as above. As far as i can make out the program has installed but has not placed the vray plugin in the 2014 plugin folder, so SU cannot find it.
        As this is a partially locked down pc i cannot go around and search for the relevant .rb
        Anybody has any clue?
        EDIT
        I have solution!
        ๐Ÿ˜
        If you install as admin, as one does, it puts the rb files in the admin plug in but NOT in the users plug in folder, rendering the hole idea of user plugin folder pointless.
        Simply copy said rb files from
        C:\Users[ADMIN]\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins
        to
        C:\Users[YOUR USERNAME]\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins
        and voilร , plugin loads.
        • dkendigD Offline
          dkendig
          You ran the installer as a different user? Not sure why you would do that, but yes, that will place our plugin in the wrong user's user folder. There is no reason to run the installer as an admin afaik.
          Devin Kendig
          Developer
          • O Offline
            Openspaces
            I think I have a different problem.
            Am in the correct folder, but cant seem to pick my license.
            Just renders in Demo mode.
            Still need help anyone.
            Thank you
            • dkendigD Offline
              dkendig
              if you downloaded the demo version, it will only be a demo. If you can't download a commercial or edu version from our site, and you have a paid license (and dongle) for 2.0, you need to contact support@chaosgroup.com to have your account permissions fixed. The demo does not convert to a commercial or edu version when a dongle is present.
              Devin Kendig
              Developer
              • O Offline
                Openspaces
                Ok, Thanks. I have written to the email address.
                Waiting for response.
                Meanwhile back to what I had. ๐Ÿ˜ž
                • arail1A Offline
                  arail1
                  The download page is quite confusing and should be re-organized.
                  Some questions I hope someone can answer for me -
                  The download page only lists 32bit systems - why is that?
                  What is the difference between these two categories - V-Ray 2.0 Adv for SketchUp and V-Ray for SketchUp?
                  The first one lists builds up to Mar 4, the second one is Mar 19. Which one should I download?
                  Thanks in advance for any clarity you can provide.
                  • greenskpG Offline
                    greenskp
                    I have an issue: VFB Channels doesn't work. Some channels are enabled but VFB does not display at finished.
                    V-Ray for SketchUp Demo Limitations
                    • Distributed Rendering limited to 2 render nodes
                    • produces watermarked images
                    • resolution up to 600x400
                    • rendered results limited to 4 lights
                    • dkendigD Offline
                      dkendig
                      did everyone find the proper download? If not, please contact support@chaosgroup.com. Don't use the demo if you paid for the product. We just need to correct your download permissions if it's not showing up for you!
                      Devin Kendig
                      Developer
                      • O Offline
                        Openspaces
                        Thank you Devin, I contacted Chaos group, and my download fixed.
                        Am up and running again with the update.
                        And Batch Render is awesome, at least I can catch some sleep now, while my computer
                        works away.
                        Thanks for your support.
                        • V Offline
                          Vittorio
                          [highlight=#ffff80:24kh8i1z][/highlight:24kh8i1z][quote="arail1"]The download page is quite confusing and should be re-organized.
                          Frankly Speaking this is the worst download page setup I have seen for a professional software vendor in a long while.
                          I went through this page and the many links leading to it trying to reach the SP1 source file but all my time wasted in vain.
                            rspierenburg
                            Because Sketchup is only 32bit and Vray runs within Sketchup. There is a way to render using DR Spawner to use 64bit but I've never personally tried it.
                            Rob
                            • zdesaynZ Offline
                              zdesayn
                              hello everyone, i try only now using renderID ang materialID selcted in VFB channel but it's not working.
                              http://zdesignviz.blogspot.com/
                              • andybotA Offline
                                andybot
                                are you getting any channels saved? Works fine for me. Are you using the current (second) service release?
                                • V Offline
                                  valerostudio
                                  I've been using these features for years and never had a problem. What version are you on? 2.0? Anything prior to SP1 on 2.0 did not create the mat ids automatically. You have to go into the material and assign a color.
                                    albebrigati
                                    Hello I use vray 2.00.02.
                                    I can't use VFB channels. I Follow the instructions: select ID COLOR /red for exemple) to material, in the option I select channel MATERIAL ID and in the CUSTOM CHANNEL i ADD CHANNEL. When starts rendering I see the channel of my material specific but it is all black. Why this?
                                    • andybotA Offline
                                      andybot
                                      2.00.02 is not a version number. Should be something like 2.00.25774. You can find the specific build number when you go in Sketchup to Window --> Preferences and look at Extensions list and find vray for SU.
