    WebDialog encoding bug found!
    44 Posts 10 Posters 5.9k Views 10 Watching
      slbaumgartner
      @dan rathbun said:
      @slbaumgartner said:
      But in 2014, the original 5-byte UTF-8 string is somehow transmuted into the 8-byte string \xE2\x88\x9A\xC2\xA9lan. ... It's as if the callback processing code has an incorrect implementation of the transcoding.
      YES, agree.
      To me it looks like it IS UTF-8, but Ruby thinks it is some other encoding, and doubly transcodes* it into UTF-8 AGAIN.
      • P.S. - isn't transmute a math term ?
      I was thinking more of alchemy 😄
        driven
        @tt_su said:
        ? It does? Are you sure?
        It certainly looks like it...
        I cleaned up my initial code an per the Nanny and the Professors prodding...
        and these are the new images...v8v13v14
        and the new script
        # encoding; UTF-8
        def show_problem
          @lang_hash = {'lid1'=>"élan"}  # I'm using a hash because it's what I use in my plugin...
          @dlg2 = UI;;WebDialog.new("Problem_Main", false,"main_prob", 700, 500, 600, 0, false)
          html = %Q(
          <!DOCTYPE html>
          <html>
          <head>
          <title>Problem_Main</title>
          <meta content="text/html; charset=utf-8" http-equiv="Content-Type">
          </head>
          <body>
            <p>Tested using Sketchup.version #{Sketchup.version}</p>
            <p>Tested on #{RUBY_PLATFORM =~ /(darwin)/ ? ((%x(sw_vers).sub(/ProductName;/,'').sub(/ProductVersion;/,'').sub(/BuildVersion;/,'_'))) ; 'windows'}</p>
            <p>click into the box and hit return or change to use another non ASCII-8BIT string...</p>
            <input id="#{@lang_hash.keys[0]}" value="#{@lang_hash.values[0]}" type="text" onkeydown="if (event.keyCode == 13) trans_L8();" title="type text and then 'Enter'">
            <p>below is the return using 'get_element_value'</p>
            <h4 id="translation1"><!-- return appears here --></h4>
            <p>below is the return using 'add_action_callback' </p>
            <h4 id="translation2"><!-- return appears here --></h4>
            <p>below is the return of the query  'add_action_callback'  == 'get_element_value'</p>
            <h4 id="translation3"><!-- return appears here --></h4>
            <script type="text/javascript" charset="UTF-8">
              function trans_L8() {
                window.location = 'skp;trans_L8@'+#{@lang_hash.keys[0]}.id+','+(#{@lang_hash.keys[0]}.value);
            </script>
          </body>
        </html>
          @dlg2.set_html html
          RUBY_PLATFORM =~ /(darwin)/ ? @dlg2.show_modal() ; @dlg2.show()
          @dlg2.add_action_callback("trans_L8") {|dialog, params|
            param_id = params.split(',')[0].to_s
            param_val = params.split(',')[1].to_s
            callback = 'return using add_action_callback ' # + param_id.to_s + ' = ' + param_val.to_s # commented out to avoid the error
            puts callback
            p(params)
            elm_val = (@dlg2.get_element_value(param_id)).to_s
            element_value = 'return using get_element_value => ' + elm_val
            puts element_value
            @dlg2.execute_script("translation1.textContent='#{(elm_val)}'")
            @dlg2.execute_script("translation2.textContent='#{param_val}'")
            @dlg2.execute_script("translation3.textContent='#{elm_val == param_val}'")
        show_problem
        # load("/Users/johns_iMac/Library/Application Support/SketchUp 2014/SketchUp/Plugins/jcb_ViewPortResize/dev/show_encoding_issue.rb")
        # load("[add your path]/show_encoding_issue.rb")
        and a question? Is there code to get the Windows operating system details?
          driven
          a CLUE perhaps...
          Using js codepoints for my input, 'get_element_value' has switched all the separators...
          return using add_action_callback "lid1,/uD83D/uDC7D/u20AC/u00A3/u0061/u0009"
          return using get_element_value => \uD83D\uDC7D\u20AC\u00A3\u0061\u0009
          so I modified my code
              param_val_sub = params.split(',')[1].gsub('/','\\').to_s
          p param_val_sub
              puts callback
              p(params)
              puts element_value
              @dlg2.execute_script("translation1.textContent='#{elm_val}'")
              @dlg2.execute_script("translation3.textContent='#{param_val_sub}'")
          and this is the result
          using js codepoints
            driven
            So it seems there are in-fact two issues...
            1: return having separators reversed
            2: encoding being mis-read
            I added the .gsub('/','\\') to both types of return, so it works on v8 or v13/v14
            I added js to convert the string to UNICODE on keydown, before it retrieved by SU...
            and the full workaround...v8 fixed get_element_value and encodingv14 fixed action_callback  and encoding
            # encoding; UTF-8
            def show_problem
              @lang_hash = {'lid1'=> %Q(élan  ümlet)}  # I'm using a hash because it's what I use in my plugin...
              html = %Q(
              <!DOCTYPE html>
              <html>
              <head>
              </head>
              <body>
                <input id="#{@lang_hash.keys[0]}" value="#{@lang_hash.values[0]}" type="text" onkeydown=" if (event.keyCode == 13) this.value=unicodeLiteral(this.value);trans_L8();"  title="type text and then 'Enter'">
                  /* Creates a uppercase hex number with at least length digits from a given number */
            function fixedHex(number, length){
                var str = number.toString(16).toUpperCase();
                while(str.length < length)
                    str = "0" + str;
                return str;
                  /* Creates a unicode literal based on the string */
            function unicodeLiteral(str){
                var i;
                var result = "";
                for( i = 0; i < str.length; ++i){
                    /* You should probably replace this by an isASCII test */
                    if(str.charCodeAt(i) > 126 || str.charCodeAt(i) < 32)
                        result += "\\\\" + "u" + fixedHex(str.charCodeAt(i),4);
                    else
                        result += str[i];
                return result;
                </script>
              </body>
            </html>
              @dlg2.set_html html
                param_val = params.split(',')[1].gsub('/',"\\").to_s
                puts callback
                p(params)
                elm_val = (@dlg2.get_element_value(param_id)).gsub('/',"\\").to_s
                puts element_value
            show_problem
            BIG question is will this work on other PC's, or would I need a platform conditional?
            In review,
            I think the http header has the incorrect encoding and as SU is the server it must come from there...
            The internal 'separator' variations is still a mystery...
            • Dan RathbunD
              Dan Rathbun
              @driven said:
              ... and a question? Is there code to get the Windows operating system details?
              Get the default system Encoding:
              Encoding::find("filesystem")
              or
              Encoding::find("locale")
              (On my machine it returns the #<Encoding:Windows-1252> object reference.)
              If you want the Windows version:
              %x[ver]
              On my machine it returns: "Microsoft Windows [Version 6.1.7601]"
              XP is 5.1
              Vista is 6.0
              Win7 is 6.1
              What else do you want to know ?
              I'm not here much anymore.
                driven
                does my last script run on your PC?
                if swap these in, can you show me a screen shot?
                a more complex input...
                  @lang_hash = {'lid1'=> %Q(élan 勢い Schwung импульс)}  # I'm using a hash because it's what I use in my plugin...
                and the widows versioning...
                    <p>Tested on #{RUBY_PLATFORM =~ /(darwin)/ ? ((%x(sw_vers).sub(/ProductName;/,'').sub(/ProductVersion;/,'').sub(/BuildVersion;/,'_'))) ; %x[ver]}</p>
                also, did you try it without the fix? did you get both returns on v2014?
                • Dan RathbunD
                  Dan Rathbun
                  I had not actually run the code at all, before.
                  Here goes:
                  @driven said:
                  ..., did you try it without the fix? did you get both returns on v2014?
                  On SU2014, without the fix:
                  load "test/WebDialog_param_encoding_bug.rb" %(#004000)[true return using add_action_callback lid1 = élan return using get_element_value => élan]
                  • After hitting return the elements are NOT replaced in the WebDialog because %(#8000BF)[element.textContent=] does not work on MSIE.
                    You need a platform code branch and use %(#8000BF)[element.innerText=] on PC.
                  On SU2014, WITH the fix, AFTER hitting return:
                  load "test/WebDialog_param_encoding_fix.rb" %(#004000)[true return using add_action_callback "lid1,\\u00E9lan \\uF8FF \\u00FCmlet" return using get_element_value => \u00E9lan \uF8FF \u00FCmlet]
                  First setting:
                  Encoding::default_internal="UTF-8" %(#404000)[UTF-8]
                  .. has not effect (no difference.)
                  • Dan RathbunD
                    Dan Rathbun
                    With the two changes on SU2014.
                    Before hitting ENTER:
                    .. but when I click in the text control, and hit the END key, the ruby console shows:
                    %(#004000)[return using add_action_callback "lid1,\xC3\xA9lan \xE5\x8B\xA2\xE3\x81\x84 Schwung \xD0\xB8\xD0\xBC\xD0\xBF\xD1\x83\xD0\xBB\xD1\x8C\xD1\x81" return using get_element_value => élan 勢い Schwung импульс]
                    After hitting ENTER:
                    .. and then the Ruby console shows:
                    %(#004000)[return using add_action_callback "lid1,\\u00E9lan \\u52E2\\u3044 Schwung \\u0438\\u043C\\u043F\\u0443\\u043B\\u044C\\u0441" return using get_element_value => \u00E9lan \u52E2\u3044 Schwung \u0438\u043C\u043F\u0443\u043B\u044C\u0441]
                      driven
                      thanks dan
                      You need a platform code branch and use element.innerText= on PC.
                      innerText works on mac, so I'll just change that...
                      can you run with the tweak...
                      and see if they show in the dialog...
                      the extra // in your console return confuses me. I had to add more to escape ruby escaping javascript...
                      • Dan RathbunD
                        Dan Rathbun
                        OK, that latest tweek, after hitting enter:
                        And the console, after hitting enter:
                        %(#004000)[load "test/show_encoding_issue.rb" true return using add_action_callback "lid1,\\u00E9lan \\u52E2\\u3044 Schwung \\u0438\\u043C\\u043F\\u0443\\u043B\\u044C\\u0441" return using get_element_value => \u00E9lan \u52E2\u3044 Schwung \u0438\u043C\u043F\u0443\u043B\u044C\u0441]
                        BTW.. if the WebDialog has focus after hitting ENTER, and I need to use the ALT key (for ALT+PrintScreen to copy the active window image to the clipboard, so I can save it from Paint.NET,) there is a whole bunch of repeated console output, like 15 times while I held the ALT key down.
                          driven
                          yeh it works...
                          with this should I just add a screen grab and dump it to desktop?
                              @dlg2.write_image(File.join((File.expand_path("~")), "Desktop", "dlg_test.png"))
                          auto acquired image...
                          what's the PC equiv...
                          EDIT: for completeness I'll add the unmodified pair back into the mix after sleep...
                          thanks again dan
                          • Dan RathbunD
                            Dan Rathbun
                            @driven said:
                            ... should I just add a screen grab and dump it to desktop?
                            NO.
                            Replace the %(#8000BF)[onkeydown=] with:
                            %(#8000BF)[onkeyup=" if (event.keyCode == 13) { this.value=unicodeLiteral(this.value); trans_L8(); }"]
                            Notice that I enclose BOTH the following statements within a "curly block", so that the test only fires when ENTER key is released (after being pressed.)
                            The condition will not even be tested while any key is down, including any modifier key.
                            • Dan RathbunD
                              Dan Rathbun
                              FYI: I am one of those who hates programs putting stuff on MY Desktop.
                                driven
                                so do I so I added it as a button...
                                NEW VERSION...
                                I split the input method to make it function the same in all versions of SU...
                                I can't get the raw code too display in the dialog, so here it is for v2014, the others are similarly wrong...
                                EDIT: made a small adjustment to get 'fixed' to display correctly [puts v p]
                                true
                                return using add_action_callback [id,value]
                                "\xE2\x88\x9A\xC2\xA9lan \xC3\x82\xC3\xA3\xC2\xA2\xE2\x80\x9E\xC3\x85\xC3\x91 Schwung \xE2\x80\x93\xE2\x88\x8F\xE2\x80\x93\xC2\xBA\xE2\x80\x93\xC3\xB8\xE2\x80\x94\xC3\x89\xE2\x80\x93\xC2\xAA\xE2\x80\x94\xC3\xA5\xE2\x80\x94\xC3\x85"
                                return using add_action_callback [id,value_fixed]
                                return using get_element_value fixed => \u00E9lan \u52E2\u3044 Schwung \u0438\u043C\u043F\u0443\u043B\u044C\u0441
                                Please test the new script...with puts fix
                                  Here are my PC results.
                                  Win7 IE11.
                                  Note how v2014 misses platform ?
                                  Only the v8 Russian text seems to have a problem on get_element_value ??
                                  • G
                                    Garry K
                                    Here you go.
                                    I've got SU 7 Free, SU 8 Free, SU 2013 Trial, SU 2014 Trial
                                    • G
                                      Garry K
                                      Sorry - missed clicking the button for SU 7
                                        driven
                                        Thanks Tig and Garry,
                                        from your images it appears that v8 had an issue with the standard call but shows correctly if SU is handed a Unicode charset string with it's separators gsub'd.
                                        The ongoing v2014 (PC) handles both standard or 'fixed', where my mac's fail.
                                        I'll write up a bug report for this, and at least I can now carry on with my language translator...
                                        The only conditions, in this script, are for the 'extra' system info, which I won't need...
                                        @garry, if you click into the text field, then hit return and then click the button, you'll see the default results as well...
                                        I had to split them onto Two buttons for v8 to use the same code as the others...
                                        • fredo6F
                                          Here are my results on SU14, Windows 7 64-bits, IE11
                                          1) When starting Sketchup
                                          2) After putting the focus in the field and typing Enter
                                            driven
                                            Thanks Fredo,
                                            I updated the script since then to shows both the default and fixed returns...
                                            the default shows with the return from the input box and the button shows the 'fix' i.e. Unicode literals with separators fixed...
                                            on the PC it appears v8 may have an issue with the 'default' return for 'get_element_value' some of these chars, and mac has issues on all versions, but the Unicode literals appear to work on all, so far...
                                            Thanks for taking the time.
                                            here is a rbz version...
                                            • 2 / 3
