    WebDialog encoding bug found!
    44 Posts 10 Posters 5.9k Views 10 Watching
      slbaumgartner
      @driven said:
      @aerilius said:
      ...Then one can use get_element_value to fetch user input of any arbitrary character range.
      except, get_element_value fails pre v2013 and get_element_value works.
      I got a few old scripts I was trying to update, and was unable to figure out the issue...
      I think this shows it was broken to begin and got broken 'differently' with a fix...
      I'm more inclined, to look at using 'unicodeEscape' in the js... before retrieving by either method...
      It's possible to get deeply confused trying to sort this out
      Here's what I have observed:
      The UTF-8 byte sequence for élan is \xC3\xA9lan (that is, UTF-8 encodes é as the two-byte sequence \xC3\xA9).
      On Mac, get_element_value returns this byte sequence exactly in both SU8 and 2014. However, because Ruby 8 thinks it is a 5-character string in ASCII-8BIT, it treats \xC3 as à and \xA9 as ©, the extended ASCII interpretations of these bytes. Ruby 2.0 happily assumes it is UTF-8 and gets it correct.
      The action callback parameters are handled differently and inconsistently between Windows and Mac.
      On the Mac, in SU8 the action callback also returns the original UTF-8 5-byte sequence, but somehow when Ruby prints it as a string, it gets it right 😲 Further, it believes this string and the one from get_element_value (that prints as élan) are equal. This makes no sense to me...
      But in 2014, the original 5-byte UTF-8 string is somehow transmuted into the 8-byte string \xE2\x88\x9A\xC2\xA9lan. Note that \xE2\x88\x9A is the UTF-8 for the square-root sign √ and \xC2\xA9 is UTF-8 for ©. So it appears the translation of the copyright is an attempt to handle misreading of the UTF-8 as ASCII-8BIT, but I don't know where that square root sign byte-sequence came from since as I mentioned above, \xC3 is à in ASCII-8BIT, which is \xC3\x83 in UTF-8. It's as if the callback processing code has an incorrect implementation of the transcoding.
      And then, as juantx0 reports, SU8 on Windows 7 returns the 5 UTF-8 bytes unconverted yet again somehow manages to make sense of it in both cases 😮 .
        driven
        @slbaumgartner said:
        ... Further, it believes this string and the one from get_element_value (that prints as élan) are equal. This makes no sense to me...
        I create this confusion... I don't check for equality it's a 'puts', it should be
            @dlg2.execute_script("translation3.textContent='#{param_val}' + ' == ' + '#{elm_val}' + ' is ' + '#{param_val == elm_val}'")
        which returns
        √©lan == élan is false
        sorry I'll get my coat...
        • JuantxoJ
          Juantxo
          Sorry, I didn't update my profile.
          In Windows SketchUp 2013 p(params) returns
          "lid1,élan"
          so works fine. (I think in SU8 also)
          Problem is in Windows SU2014 that returns non utf string.
            driven
            I suspected that...
            which locale do you use Sketchup.get_locale en-US?, it may have a bearing?
            • JuantxoJ
              Juantxo
              Yes, en-Us.
                slbaumgartner
                which returns
                Nah, I should know enough to check your code 😳 . With a real test, equality fails in all cases (as it should!).
                  driven
                  Nah, I should know enough to check your code :oops: . With a real test, equality fails in all cases (as it should!).
                  it's the tangents that count...
                  now you can write a proper test...
                  • Dan RathbunD
                    Dan Rathbun
                    The text that displays in your test, says UFT-8 in many places. It is UTF-8.
                    (The word format is at the end, of Unicode Transformation Format.)
                    (nag, nag) 😉
                    I'm not here much anymore.
                    • Dan RathbunD
                      Dan Rathbun
                      But in 2014, the original 5-byte UTF-8 string is somehow transmuted into the 8-byte string \xE2\x88\x9A\xC2\xA9lan. ... It's as if the callback processing code has an incorrect implementation of the transcoding.
                      YES, agree.
                      To me it looks like it IS UTF-8, but Ruby thinks it is some other encoding, and doubly transcodes* it into UTF-8 AGAIN.
                      • P.S. - isn't transmute a math term ?
                      • tt_suT
                        tt_su
                        ? It does? Are you sure?
                        • tt_suT
                          tt_su
                          That's a similar problem we have with FILE $LOAD_PATH, $LOADED_FEATURES and ENV. UTF-8 byte sequences isn't labeled with the correct encoding.
                            slbaumgartner
                            YES, agree.
                            I was thinking more of alchemy 😄
                              driven
                              It certainly looks like it...
                              I cleaned up my initial code an per the Nanny and the Professors prodding...
                              and these are the new images...v8v13v14
                              and the new script
                              # encoding; UTF-8
                              def show_problem
                                @lang_hash = {'lid1'=>"élan"}  # I'm using a hash because it's what I use in my plugin...
                                @dlg2 = UI;;WebDialog.new("Problem_Main", false,"main_prob", 700, 500, 600, 0, false)
                                html = %Q(
                                <!DOCTYPE html>
                                <html>
                                <head>
                                <title>Problem_Main</title>
                                <meta content="text/html; charset=utf-8" http-equiv="Content-Type">
                                </head>
                                <body>
                                  <p>Tested using Sketchup.version #{Sketchup.version}</p>
                                  <p>Tested on #{RUBY_PLATFORM =~ /(darwin)/ ? ((%x(sw_vers).sub(/ProductName;/,'').sub(/ProductVersion;/,'').sub(/BuildVersion;/,'_'))) ; 'windows'}</p>
                                  <p>click into the box and hit return or change to use another non ASCII-8BIT string...</p>
                                  <input id="#{@lang_hash.keys[0]}" value="#{@lang_hash.values[0]}" type="text" onkeydown="if (event.keyCode == 13) trans_L8();" title="type text and then 'Enter'">
                                  <p>below is the return using 'get_element_value'</p>
                                  <h4 id="translation1"><!-- return appears here --></h4>
                                  <p>below is the return using 'add_action_callback' </p>
                                  <h4 id="translation2"><!-- return appears here --></h4>
                                  <p>below is the return of the query  'add_action_callback'  == 'get_element_value'</p>
                                  <h4 id="translation3"><!-- return appears here --></h4>
                                  <script type="text/javascript" charset="UTF-8">
                                    function trans_L8() {
                                      window.location = 'skp;trans_L8@'+#{@lang_hash.keys[0]}.id+','+(#{@lang_hash.keys[0]}.value);
                                  </script>
                                </body>
                              </html>
                                @dlg2.set_html html
                                RUBY_PLATFORM =~ /(darwin)/ ? @dlg2.show_modal() ; @dlg2.show()
                                @dlg2.add_action_callback("trans_L8") {|dialog, params|
                                  param_id = params.split(',')[0].to_s
                                  param_val = params.split(',')[1].to_s
                                  callback = 'return using add_action_callback ' # + param_id.to_s + ' = ' + param_val.to_s # commented out to avoid the error
                                  puts callback
                                  p(params)
                                  elm_val = (@dlg2.get_element_value(param_id)).to_s
                                  element_value = 'return using get_element_value => ' + elm_val
                                  puts element_value
                                  @dlg2.execute_script("translation1.textContent='#{(elm_val)}'")
                                  @dlg2.execute_script("translation2.textContent='#{param_val}'")
                                  @dlg2.execute_script("translation3.textContent='#{elm_val == param_val}'")
                              show_problem
                              # load("/Users/johns_iMac/Library/Application Support/SketchUp 2014/SketchUp/Plugins/jcb_ViewPortResize/dev/show_encoding_issue.rb")
                              # load("[add your path]/show_encoding_issue.rb")
                              and a question? Is there code to get the Windows operating system details?
                                driven
                                a CLUE perhaps...
                                Using js codepoints for my input, 'get_element_value' has switched all the separators...
                                return using add_action_callback "lid1,/uD83D/uDC7D/u20AC/u00A3/u0061/u0009"
                                return using get_element_value => \uD83D\uDC7D\u20AC\u00A3\u0061\u0009
                                so I modified my code
                                    param_val_sub = params.split(',')[1].gsub('/','\\').to_s
                                p param_val_sub
                                    puts callback
                                    p(params)
                                    puts element_value
                                    @dlg2.execute_script("translation1.textContent='#{elm_val}'")
                                    @dlg2.execute_script("translation3.textContent='#{param_val_sub}'")
                                and this is the result
                                using js codepoints
                                  driven
                                  So it seems there are in-fact two issues...
                                  1: return having separators reversed
                                  2: encoding being mis-read
                                  I added the .gsub('/','\\') to both types of return, so it works on v8 or v13/v14
                                  I added js to convert the string to UNICODE on keydown, before it retrieved by SU...
                                  and the full workaround...v8 fixed get_element_value and encodingv14 fixed action_callback  and encoding
                                  # encoding; UTF-8
                                  def show_problem
                                    @lang_hash = {'lid1'=> %Q(élan  ümlet)}  # I'm using a hash because it's what I use in my plugin...
                                    html = %Q(
                                    <!DOCTYPE html>
                                    <html>
                                    <head>
                                    </head>
                                    <body>
                                      <input id="#{@lang_hash.keys[0]}" value="#{@lang_hash.values[0]}" type="text" onkeydown=" if (event.keyCode == 13) this.value=unicodeLiteral(this.value);trans_L8();"  title="type text and then 'Enter'">
                                        /* Creates a uppercase hex number with at least length digits from a given number */
                                  function fixedHex(number, length){
                                      var str = number.toString(16).toUpperCase();
                                      while(str.length < length)
                                          str = "0" + str;
                                      return str;
                                        /* Creates a unicode literal based on the string */
                                  function unicodeLiteral(str){
                                      var i;
                                      var result = "";
                                      for( i = 0; i < str.length; ++i){
                                          /* You should probably replace this by an isASCII test */
                                          if(str.charCodeAt(i) > 126 || str.charCodeAt(i) < 32)
                                              result += "\\\\" + "u" + fixedHex(str.charCodeAt(i),4);
                                          else
                                              result += str[i];
                                      return result;
                                      </script>
                                    </body>
                                  </html>
                                    @dlg2.set_html html
                                      param_val = params.split(',')[1].gsub('/',"\\").to_s
                                      puts callback
                                      p(params)
                                      elm_val = (@dlg2.get_element_value(param_id)).gsub('/',"\\").to_s
                                      puts element_value
                                  show_problem
                                  BIG question is will this work on other PC's, or would I need a platform conditional?
                                  In review,
                                  I think the http header has the incorrect encoding and as SU is the server it must come from there...
                                  The internal 'separator' variations is still a mystery...
                                  • Dan RathbunD
                                    Dan Rathbun
                                    @driven said:
                                    ... and a question? Is there code to get the Windows operating system details?
                                    Get the default system Encoding:
                                    Encoding::find("filesystem")
                                    or
                                    Encoding::find("locale")
                                    (On my machine it returns the #<Encoding:Windows-1252> object reference.)
                                    If you want the Windows version:
                                    %x[ver]
                                    On my machine it returns: "Microsoft Windows [Version 6.1.7601]"
                                    XP is 5.1
                                    Vista is 6.0
                                    Win7 is 6.1
                                    What else do you want to know ?
                                      driven
                                      does my last script run on your PC?
                                      if swap these in, can you show me a screen shot?
                                      a more complex input...
                                        @lang_hash = {'lid1'=> %Q(élan 勢い Schwung импульс)}  # I'm using a hash because it's what I use in my plugin...
                                      and the widows versioning...
                                          <p>Tested on #{RUBY_PLATFORM =~ /(darwin)/ ? ((%x(sw_vers).sub(/ProductName;/,'').sub(/ProductVersion;/,'').sub(/BuildVersion;/,'_'))) ; %x[ver]}</p>
                                      also, did you try it without the fix? did you get both returns on v2014?
                                      • Dan RathbunD
                                        Dan Rathbun
                                        I had not actually run the code at all, before.
                                        Here goes:
                                        @driven said:
                                        ..., did you try it without the fix? did you get both returns on v2014?
                                        On SU2014, without the fix:
                                        load "test/WebDialog_param_encoding_bug.rb" %(#004000)[true return using add_action_callback lid1 = élan return using get_element_value => élan]
                                        • After hitting return the elements are NOT replaced in the WebDialog because %(#8000BF)[element.textContent=] does not work on MSIE.
                                          You need a platform code branch and use %(#8000BF)[element.innerText=] on PC.
                                        On SU2014, WITH the fix, AFTER hitting return:
                                        load "test/WebDialog_param_encoding_fix.rb" %(#004000)[true return using add_action_callback "lid1,\\u00E9lan \\uF8FF \\u00FCmlet" return using get_element_value => \u00E9lan \uF8FF \u00FCmlet]
                                        First setting:
                                        Encoding::default_internal="UTF-8" %(#404000)[UTF-8]
                                        .. has not effect (no difference.)
                                        • Dan RathbunD
                                          Dan Rathbun
                                          With the two changes on SU2014.
                                          Before hitting ENTER:
                                          .. but when I click in the text control, and hit the END key, the ruby console shows:
                                          %(#004000)[return using add_action_callback "lid1,\xC3\xA9lan \xE5\x8B\xA2\xE3\x81\x84 Schwung \xD0\xB8\xD0\xBC\xD0\xBF\xD1\x83\xD0\xBB\xD1\x8C\xD1\x81" return using get_element_value => élan 勢い Schwung импульс]
                                          After hitting ENTER:
                                          .. and then the Ruby console shows:
                                          %(#004000)[return using add_action_callback "lid1,\\u00E9lan \\u52E2\\u3044 Schwung \\u0438\\u043C\\u043F\\u0443\\u043B\\u044C\\u0441" return using get_element_value => \u00E9lan \u52E2\u3044 Schwung \u0438\u043C\u043F\u0443\u043B\u044C\u0441]
                                            driven
                                            thanks dan
                                            You need a platform code branch and use element.innerText= on PC.
                                            innerText works on mac, so I'll just change that...
                                            can you run with the tweak...
                                            and see if they show in the dialog...
                                            the extra // in your console return confuses me. I had to add more to escape ruby escaping javascript...
                                            • 2 / 3
