    Fishing net modeling
    131 Posts 12 Posters 15.3k Views 12 Watching
      You can find old free versions of sketchup here so you will can use the protrude plugin ๐Ÿ˜„
      • olisheaO Offline
        olishea
        For the 2014 I don't know, i use only very old versions 6,7,8 ๐Ÿ’š
        That makes two of us! ๐Ÿ˜†
        oli
        • W Offline
          willipop
          Still playing with artisan and I luv it !!
          @ Pilou : ma copine me confirme que tu es un fan de rugby ahah ๐Ÿ˜„ ( elles vient du sud et moi de montrรฉal ๐Ÿ˜‰
          • W Offline
            willipop
            Oups here's a picture ๐Ÿ˜„
            • W Offline
              willipop
              Now I will use the select brush and select every faces that show less vertex. Afterthen I will subdivide these faces to have a more uniform mesh. I'd like to have 10-15cm in between each edges.
                Nice bridge! โ˜€
                A Firenze revival? ๐Ÿ˜‰
                http://www.pintoresfamosos.cl/obras/galeria/bellotto.jpg
                PS Ruby not rugby! ๐Ÿ’š
                • W Offline
                  willipop
                  En Gaspรฉsie au Quรฉbec mon ami !
                    Arf, je ne connais que Chicoutimi de nom รฉtant un vieux fan de Carole Laure! โ˜€
                    http://nsm08.casimages.com/img/2014/02/13/14021310370316176911979249.jpg
                    • olisheaO Offline
                      olishea
                      Your work is really coming on! Great stuff!
                      oli
                      • W Offline
                        willipop
                        Thx oli ๐Ÿ˜„ It's getting better ! I'm wondering how I will do the rendering !:)
                        • W Offline
                          willipop
                          Itteration 4 makes perfect distance in between the edges ::):)
                          • olisheaO Offline
                            olishea
                            Good luck turning the lines to tubes! ๐Ÿ˜†
                            oli
                            • W Offline
                              willipop
                              its going to take approximately 36h ๐Ÿ˜ž:(:( both of my pc running on 2 different files. Jeez ! Hope i will be able to navigate in the file ^^
                                And what about junctions of tubes ? ๐Ÿ˜‰
                                Normally Lines2tubes don't managed them! ๐Ÿค“
                                • olisheaO Offline
                                  olishea
                                  I don't think it's possible to even see the junctions because the thread is so thin. What is your solution Pilou? ๐Ÿ˜‰
                                  oli
                                  • olisheaO Offline
                                    olishea
                                    Nope! ๐Ÿ˜†
                                    oli
                                      If you want really ropes maybe only lines are sufficient (hide faces) or to map a transparent texture ๐Ÿ˜„
                                      But I am not sure that the drawing of lines shown is the real one in reality?
                                      http://sketchucation.com/forums/download/file.php?id=117797&t=1
                                      • W Offline
                                        willipop
                                        Yes I have to show lines in reality ! I'd like to have the shadow casted too ! ๐Ÿ˜„ I think I will have to try with png texture or transparent texture ... I know that I can make shadow visible from the edges in sketchup but I'm sure if it'll work in kerkythea or artlantis on the rendering.
                                        • W Offline
                                          willipop
                                          Is there a way to apply a texture and have the shadow from the edges without doing to seperate rendering ?
                                          • mitcorbM Offline
                                            mitcorb
                                            I think TIG's Image Trimmer cuts away the transparent portions of a texture?
                                            • 6 / 7
