    Fishing net modeling
    131 Posts 12 Posters 26.2k Views 12 Watching
    • W
      willipop
      @ Pilou : What is this exactly ? πŸ˜„
      • W
        willipop
        Wow I will try it right away πŸ˜„ is it sk2014 friendly ? I like your afro btw πŸ˜‰ De quelle rΓ©gion es-tu ? πŸ˜„
          One of the more funny plugin! 😎
          Select any face(s) of something and at each click you will obtain an automatic result of generations of new level of extrusions! β˜€
          A sort of "greeble"
          A must to try! πŸ˜„
          • Color by z and Random Painter by Chris Fullmer πŸ’š
            For the 2014 I don't know, i use only very old versions 6,7,8 πŸ’š
            Pour le pays tout est dans ma signature! πŸ˜„
              Jim
              I do not think it works for 2014, but I am working on it when I can.
              • W
                willipop
                It appears but it's not working ! What version are you guys using ? any links for the download ?
                  You can find old free versions of sketchup here so you will can use the protrude plugin πŸ˜„
                  • olisheaO
                    olishea
                    That makes two of us! πŸ˜†
                    oli
                    • W
                      willipop
                      Still playing with artisan and I luv it !!
                      @ Pilou : ma copine me confirme que tu es un fan de rugby ahah πŸ˜„ ( elles vient du sud et moi de montrΓ©al πŸ˜‰
                      • W
                        willipop
                        Oups here's a picture πŸ˜„
                        • W
                          willipop
                          Now I will use the select brush and select every faces that show less vertex. Afterthen I will subdivide these faces to have a more uniform mesh. I'd like to have 10-15cm in between each edges.
                            Nice bridge! β˜€
                            A Firenze revival? πŸ˜‰
                            http://www.pintoresfamosos.cl/obras/galeria/bellotto.jpg
                            PS Ruby not rugby! πŸ’š
                            • W
                              willipop
                              En GaspΓ©sie au QuΓ©bec mon ami !
                                Arf, je ne connais que Chicoutimi de nom Γ©tant un vieux fan de Carole Laure! β˜€
                                http://nsm08.casimages.com/img/2014/02/13/14021310370316176911979249.jpg
                                • olisheaO
                                  olishea
                                  Your work is really coming on! Great stuff!
                                  oli
                                  • W
                                    willipop
                                    Thx oli πŸ˜„ It's getting better ! I'm wondering how I will do the rendering !:)
                                    • W
                                      willipop
                                      Itteration 4 makes perfect distance in between the edges ::):)
                                      • olisheaO
                                        olishea
                                        Good luck turning the lines to tubes! πŸ˜†
                                        oli
                                        • W
                                          willipop
                                          its going to take approximately 36h 😞:(:( both of my pc running on 2 different files. Jeez ! Hope i will be able to navigate in the file ^^
                                            And what about junctions of tubes ? πŸ˜‰
                                            Normally Lines2tubes don't managed them! πŸ€“
                                            • 3 / 7
