    Fishing net modeling
    131 Posts 12 Posters 20.5k Views 12 Watching
    • olisheaO Offline
      olishea
      @willipop said:
      About the innerfaces... I hide the faces and then I select the edges and run lines to tube so I can delete the faces after.. Is it what you mean ?
      No.
      You see the base of the cone? How it looks distorted, unlike the other cones? It's because there is a face inside the cone. It causes the subdivided mesh to act strange.
      See this as an example:
      Above The Mesh
      Under The Mesh
      oli
      • W Offline
        willipop
        Got it πŸ˜„ I actually deleted these innerfaces πŸ˜‰
        • W Offline
          willipop
          @ Pilou : What is this exactly ? πŸ˜„
          • W Offline
            willipop
            Wow I will try it right away πŸ˜„ is it sk2014 friendly ? I like your afro btw πŸ˜‰ De quelle rΓ©gion es-tu ? πŸ˜„
              One of the more funny plugin! 😎
              Select any face(s) of something and at each click you will obtain an automatic result of generations of new level of extrusions! β˜€
              A sort of "greeble"
              A must to try! πŸ˜„
              • Color by z and Random Painter by Chris Fullmer πŸ’š
                For the 2014 I don't know, i use only very old versions 6,7,8 πŸ’š
                Pour le pays tout est dans ma signature! πŸ˜„
                  Jim
                  I do not think it works for 2014, but I am working on it when I can.
                  • W Offline
                    willipop
                    It appears but it's not working ! What version are you guys using ? any links for the download ?
                      You can find old free versions of sketchup here so you will can use the protrude plugin πŸ˜„
                      • olisheaO Offline
                        olishea
                        That makes two of us! πŸ˜†
                        oli
                        • W Offline
                          willipop
                          Still playing with artisan and I luv it !!
                          @ Pilou : ma copine me confirme que tu es un fan de rugby ahah πŸ˜„ ( elles vient du sud et moi de montrΓ©al πŸ˜‰
                          • W Offline
                            willipop
                            Oups here's a picture πŸ˜„
                            • W Offline
                              willipop
                              Now I will use the select brush and select every faces that show less vertex. Afterthen I will subdivide these faces to have a more uniform mesh. I'd like to have 10-15cm in between each edges.
                                Nice bridge! β˜€
                                A Firenze revival? πŸ˜‰
                                http://www.pintoresfamosos.cl/obras/galeria/bellotto.jpg
                                PS Ruby not rugby! πŸ’š
                                • W Offline
                                  willipop
                                  En GaspΓ©sie au QuΓ©bec mon ami !
                                    Arf, je ne connais que Chicoutimi de nom Γ©tant un vieux fan de Carole Laure! β˜€
                                    http://nsm08.casimages.com/img/2014/02/13/14021310370316176911979249.jpg
                                    • olisheaO Offline
                                      olishea
                                      Your work is really coming on! Great stuff!
                                      oli
                                      • W Offline
                                        willipop
                                        Thx oli πŸ˜„ It's getting better ! I'm wondering how I will do the rendering !:)
                                        • W Offline
                                          willipop
                                          Itteration 4 makes perfect distance in between the edges ::):)
                                          • olisheaO Offline
                                            olishea
                                            Good luck turning the lines to tubes! πŸ˜†
                                            oli
                                            • 3 / 7
