    [Plugin] AttributeInspector 1.1.1 – 2014-05-08
    45 Posts 10 Posters 6.5k Views 10 Watching
      The special file-format has not been uploaded.
      I'll make it and add it for you...
      The latest PluginStore dialog version now in beta-testing will mean that only the RBZ needs uploading, but for now to get it in the dialog you need to make the other kind too...
      You have also misnamed your first upload [it should not include the version code] so the link is badly named - I'll fix that too...[mod=:33lflicj]Now available via the PluginStore Dialog...
      .[/mod:33lflicj]
        Aerilius
        I updated to 1.0.1, now with more entity types in the UI.
        You can download the .rbz from a browser. However, the plugins store does not accept anymore rbz.skp (except an admin adds it), so it's probably again out of the Plugins Store dialog..
          I'll re-add it for you.
          If you can add an RBZ you can add the other file type? 😕
          Are you making it v8 ?
          You either have to do a save_as v8 after making it in v2013 - and remember to get/use with the alternative tool that's available from the Authors' Guidance page for v2014.
          When we finally move over to the newer PluginStore version only an RBZ upload will be needed for both Download/AutoInstall...
          But while there are both versions working for users we need the alternative format....
          Users will be forced to migrate to the newer version once it goes public after beta-testing is finished...
          • jiminy-billy-bobJ
            jiminy-billy-bob
            Nice! Love it 👍
            EDIT : Really usefull 😉
              Anton_S
              Useful plugin, AE.
              The dialog looks professional, as well. 👍
              Thank you!
              • jiminy-billy-bobJ
                jiminy-billy-bob
                I'll repeat myself, but this plugin is really great!
                It's more than usefull for debugging my plugin 😄
                Thanks again for this!
                • inteloideI
                  inteloide
                  Perfect plugin Aerilius !!!
                  I wanted to write a plugins similar a long time ago, but you do it before and better than me !
                  Thank you soooo much !
                  Inteloide
                  Humanity will do a huge step when the IT professionals will understand that computers are tools...
                  • jiminy-billy-bobJ
                    jiminy-billy-bob
                    When changing the value of an attribute of a layer, the attribute vanishes. 😕
                      Aerilius
                      I cannot reproduce this. What steps to reproduce it? What is the dictionary, attribute and value?
                      • jiminy-billy-bobJ
                        jiminy-billy-bob
                        Suddenly, I can't either! Just as I was about to record it.
                        Well, if it happens again, I'll get back to you.
                        • jiminy-billy-bobJ
                          jiminy-billy-bob
                          I get this in the console whenever I open the dialog in SU2014 (Win7). It works fine, though.
                          It happens even on brand new files.
                          I don't have this in SU2013.
                          AEAttributeInspectorDialog Error for callback 'get_title';
                          undefined method `typename' for #<Sketchup;;Model;0x8a58710>
                          C;/Users/Marjorie/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ae_AttributeInspector/AttributeInspector.rb;407;in `get_title'
                          C;/Users/Marjorie/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ae_AttributeInspector/AttributeInspector.rb;303;in `block in create_dialog'
                          C;/Users/Marjorie/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ae_AttributeInspector/Dialog.rb;199;in `call'
                          C;/Users/Marjorie/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ae_AttributeInspector/Dialog.rb;199;in `action_callback_wrapper'
                          C;/Users/Marjorie/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ae_AttributeInspector/Dialog.rb;152;in `block in <class;Dialog>'
                          -e;1;in `call'
                          #<Sketchup::Model:0x8a58710> is the active model (in case you're wondering).
                          • Dan RathbunD
                            Dan Rathbun
                            Sketchup::Model#typename() is added into the API by "dcutils.rbs"... so turn the DynamicComponents extension back on, and you will no longer have the errors.
                            I'm not here much anymore.
                            • Dan RathbunD
                              Dan Rathbun
                              Also.. I would like to say that I wrote at least one plugin which I purposely added a AttributeDictionary to a collection object, because I did not want the user messing with it, or having it included in an attribute report.
                              • Dan RathbunD
                                Dan Rathbun
                                Another think that throws me off a bit, is that I am used to the +/- buttons being on the top toolbar, in the Scenes and Layers managers.
                                BUT.. I like it, mainly because I myself thought about doing this, but never had the time to do much more that the simple lister pluglet for the GeoLocation dictionary.
                                • jiminy-billy-bobJ
                                  jiminy-billy-bob
                                    Aerilius
                                    The bug has been fixed some time ago in the (not yet released) next version. I'll publish it soon.
                                    • Dan RathbunD
                                      Dan Rathbun
                                      v1.0.1
                                      When I choose "materials", nothing happens. (I should see a blank list when no dictionaries are attached to any material in the model.)
                                      Should materials not having dictionary attached be displayed but grayed out ?
                                      • Dan RathbunD
                                        Dan Rathbun
                                        Clicking (giving focus to) the edit boxes in the righthand pane, cause the row height to increase (by differing amounts, depending on whether the attribute name or value box gets focus.)
                                        • genma saotomeG
                                          genma saotome
                                          Hi Dan, would it be possible to expand upon this idea and code up something that will find all elements that match an attribute value? AFAIK there isn't a way to find faces that have no materials applied... and I have a plug-in I use all of the time that makes use of the dictionary to hold an assigned value (always about faces) but if I decide to change that value I have no way to tracking down all instances except by recollection and/or trial and error. So being able to do this attribute --> this value --> show me all that match would be very handy for me. By "show" it would be adequate to show the attribute information but I think it would be better to select them instead.
                                          I think anyone else who uses the dictionary feature might also benefit because those data are not part of SU's own selection function and your plug-in, as it is now, does reveal that data. I think taking the next step and figuring out how to do a select based on Dictionary attributes and their values would be a big plus.
                                          Thank you for any consideration you give this.
                                          • Dan RathbunD
                                            Dan Rathbun
                                            ThomThom's SelectionToys plugin can modify your selection set by many filters.
                                            There are at least 4 filters regarding add or remove objects according to front/back material set as default ( nil.)
                                            So first you window select a bunch of objects. Then use the SelectionToys face filter, so only faces remain in the set.
                                            Then use the default material filter for front faces, and/or back faces.
                                            Install manually via
                                            http://extensions.sketchup.com/en/content/selection-toys
                                            or using the ExtensionWarehouse dialog from within SketchUp 2013 and higher. Navigate to ThomThom's page, and scroll down to SelectionToys
                                            • 1 / 3
