    [Plugin] Layers Panel 1.2.1
    672 Posts 109 Posters 182.4k Views 109 Watching
      Ben Ritter
      I appreciate your generosity in sharing this plugin
      • jiminy-billy-bobJ Offline
        jiminy-billy-bob
        Thanks everybody for your kind words, comments and feedback ! I really appriciate it.
        • kenK Offline
          ken
          I have 4 layers that are in my template. I wanted to get this under a group, so I could turn all the layers off at once. They are xlines, markcenter, workplane and cline. When I try saving a template file, I get unexpected file format and the program closes. On trying to open Sketchup again, I get the failed to open template file. Sketchup open but not with the template file that I saved.
          However, when I open the standby template file, saved as a regular file, and then try to save this file as a template with the name I used above, I get the file exist and do you wish to over write the file. So something was saved.
          Just trying to keep you abreast.
          Ken
            jiminy-billy-bob
            Thanks Ken, I'll look into that.
              jiminy-billy-bob
              New version 0.3.1 beta !
              Changelog :
              • Fix group names disappearing
              Download in the plugin store !
                jiminy-billy-bob
                Ken, were these 4 layers created before you installed the plugin ? What happen when you create a new file, create the same layers, and try to save it as template ?
                If you find a way to reproduce the bug every time, that would be really great ! πŸ˜„ I could propably debug this
                • kenK Offline
                  ken
                  Well OK, I noticed that there were other versions of this plugin in my plugin folder. So I deleted all files associated with this plugin and did a re-install. It now appears to be working. I can save a template file, and re-open and have the four layers still there and in the group I added.
                  Hope this helps.
                  Ken
                  • X Offline
                    xkalvisx
                    I hope you have ever done:
                    Group - visible
                    Group - invisible
                    Should operate in a single click
                    Thank you
                      jiminy-billy-bob
                      What do you mean ? You can already hide/show groups with a single click.
                        jiminy-billy-bob
                        Hope this helps.
                        Ken
                        Great ! I'm glad it works now.
                        But did you have the corrupt template multiple times ? I mean, was it just one time or was it systematic ?
                        EDIT : When you say you had multiple versions installed, was it a beta (layer_panel.rb) and an old alpha version (Layers Panel.rb) ? Otherwise, I don't understand how you can have multiple versions
                          jiminy-billy-bob
                          Okay, I find a way to reproduce the bug in version 0.3 :
                          • Open blank file
                          • Open LP's dialog
                          • Create group
                          • Save as template
                          I get "Incorrect format file" each time.
                          The good news is I don't get this with version 0.3.1 ! πŸ˜„
                          So it was probably related to the group names bug. So please update everybody !
                          Thanks a lot Ken for your feedback, it helped me a lot finding the way to reproduce it.
                          I hope it was the same problem cmeed had, even though he didn't save as template.
                            jiminy-billy-bob
                            For people understanding ruby :
                            I fully identified the cause of the problem : The plugin trying to save "nil" as an AttributeDictionary key.
                            @layerDictID being nil (the bug about group names)
                            @model.set_attribute("jbb_layerspanel_groups", @layerDictID, groupName)
                            • kenK Offline
                              ken
                              Well I was looking the plugin directory an found more than one layerpanel directory and some other files I believe came from other installations. I don't remember all the names, I just removed everything having to do with layerpanel. And re-installed and presto it works.
                              Thanks for looking into this plugin.
                              Wishing you luck.
                              Ken
                              • X Offline
                                xkalvisx
                                No groups, but the group of layers.
                                It is now possible to make invisible only one layer.
                                If you see me group 5 layers, this group click on the "eye", I wish that all the five layers in the group would become visible or not.
                                Thanks.
                                P.S.
                                Sorry for the very poor proficiency in English.
                                  jiminy-billy-bob
                                  If you put layers in a group, and hide that group, all the nested layers will be hidden.
                                  But maybe you're talking about selecting multiple layers and hide them all with one click? I'm not sur about that workflow
                                  • cmeedC Offline
                                    cmeed
                                    I have another one for you....
                                    With the layer Panel open I can't use my shortcut key 'P' assigned to Create new scene. Turn panel off and shortcut key works as it should.
                                    Does that happen for anyone else?
                                    In the model I'm using i have a lot of layers going on. I've just had a major bug splat too, thankfully no lost data or corrupted files. on opening the the file again after the bugsplat, the bugsplat happened again and again - straight away before SU seemed to even open - restarted Machine seems Ok- File opened as Usual
                                    mmmmm
                                    c
                                      jiminy-billy-bob
                                      Were you trying to delete/purge layers with outliner opened ?
                                      http://sketchucation.com/forums/viewtopic.php?f=180&t=54161
                                        jiminy-billy-bob
                                        Not sure about the P shortcut, I'll look into that.
                                        • cmeedC Offline
                                          cmeed
                                          before the major bugsplat I was trying to create new scenes outliner could have been open. When i pressed P no scene tabs appeared which drew my attention
                                          then i opened the 'Scenes window' and noticed the scenes were there - but as i said no scene Tabs at the top of the SU Window. Then the crash
                                            Bimbalas
                                            Hi, jiminy-billy-bob,
                                            very nice job. Thanks.
                                            I'm discovered a new bug.
                                            On renamaming layers or groups directly on Layers Panel with letters from non ASCII character set (e.g. Δ…ΕΎΔ―Δ—Ε‘) this letters was changed to unicode codes.
                                            Can you look for this?
                                            • 33
                                            • 34
                                            • 4 / 34
