    [PLUGIN]MITSUBA Render Exporter v1.5.0(20141109)
    102 Posts 18 Posters 202.7k Views 18 Watching
      driven
      @mike
      did you try either/both of these window.exe downloads?http://www.mitsuba-renderer.org/download.html
      maybe some machine specs would help us out, helping you...
        Thanks John, I feel like a right muppet not including specs, not as if I do not know, please put it down to a muppet day. I have tried the 64 bit program from that site/location.
        Specs as in the attached image.
        NVIDIA graphics card 1gb vram. This is updated as of about 1 week ago for drivers.
        System Specs
        • T
          tak2hata
          Hi,All.
          I update this to v1.2.4. in 2014-03-21.
          I finally understood this problem of running mtsimport.
          I add code setting current directory in ruby.
          So mtsimport will make "textures" in setter directory.
          Thanks John.
          Hi,Mike.
          There is "vcredist_2013_x64.exe" in folder unzipped mitsuba render package.
          It is microsoft visual studio 2014 x64 redisributable package"
          Please install it.
          Mitsuba will work.
          by TAK2HATA
            driven
            thank you...
            next thought is, can we 'tag the view' before export, and if it is the 'same tag' after a materials tweak, skip the geometry re-creation? maybe an update button on the materials dialog?
            jonh
              Thanks very much, its appreciated.
                driven
                sketchup model, materials, no lights
                slowly getting the hang of it...
                  driven
                  a bit to shinny, but getting there... I think
                  learning the slow way...
                  • T
                    tak2hata
                    [attachment=0:7vyebg0v]<!-- ia0 -->bar_clamp_ext_vol.jpg<!-- ia0 -->[/attachment:7vyebg0v]
                    Cool Rendering image.
                    TAK2HATA
                    by TAK2HATA
                      Very nice ones! β˜€
                      Any ideas of the rendering time for one image?
                        driven
                        this one is a 13.3 MB skp file, the others took less time each.information stamped  exr are saved on render...
                          OK, got the plugin working, sort of . The ui I get when runinning mitsuba do0es not allow for changing mats/textures etc, is there a ui I am missing or is there a simple explanation I am missing? I get that I do not have the full picture and having found the readme file in the mitsuba directory am kicking myself for my earlier question ans the answer is there. What am I missing?
                          What I see.
                            driven
                            @mike
                            the materials editor is part of this plugin, load it through the SCF download tool and it open mitsuba after you use it.
                              Thanks, please excuse me again, I must be working on flat batteries and an old optic prescription. Slower, more notice............
                              • T
                                tak2hata
                                Hi,All.
                                I update this to V1.2.9 in 20140330.
                                Improves and bugfixes.
                                Thanks.
                                by TAK2HATA
                                • sadyoS
                                  sadyo
                                  Thanks Tak2hata, it's dream come true
                                    driven
                                    @tak2hata,
                                    cheers for the update, will test on mac...
                                      driven
                                      hi
                                      can anyone else see if they can render one of Rich's models...
                                      http://sketchucation.com/shop/models/furniture/303-marc-newson-wooden-chair
                                      I'm getting this error message...download is free for 'Premiums'...
                                      • T
                                        tak2hata
                                        @driven said:
                                        hi
                                        http://sketchucation.com./shop/models/furniture/303-marc-newson-wooden-chair
                                        I'm getting this error message...[attachment=0:3lajmeue]<!-- ia0 -->2014-04-06 05.34.02 pm.png<!-- ia0 -->[/attachment:3lajmeue]
                                        Hi,john.
                                        This script roundup the matrix values.
                                        42 line of code in mitsuba_main.rb
                                        Please Delete that line.
                                        The error will not appear.
                                        Now I still can not return to home.
                                        So I can not edit this script for a month.
                                        Please modify it yourself.
                                        Thanks.
                                        by TAK2HATA
                                        • SminkyS
                                          Sminky
                                          I am not sure this is related to this exporter plugin but allow me to ask it:
                                          I tried rendering an animation with mitsuba and all worked fine apart that I got the frames in .exr format that is not supported by virtualdub so I can't make a movie of it;
                                          how to change the output format of animation frames?
                                          Sorry for my noobness, best regards and thanks in advance.
                                          • T
                                            tak2hata
                                            hi,sminky.
                                            It will be added in one or two week.
                                            Now I can not return to home.
                                            sorry please wait.
                                            tak2hata
                                            by TAK2HATA
                                            • 3 / 6
