    Displayed Circles in 2014 and 2013
    16 Posts 6 Posters 1.1k Views 6 Watching
    • jeff hammondJ
      i can't duplicate that but it appears the bottom images have a different AA setting applied compared to the top two.. maybe that's something to do with it?
        Could you post the SKP file?
          driven
          @jeff hammond said:
          .. have a different AA setting applied compared to the top two...
          this was set at 4 for v2013, but reverted to 0 for v2014...
          to test
          check_AA = Test.get_AA_method
          to change
          full_AA = Test.set_AA_method(4)
          to revert
          revert_AA = Test.set_AA_method(0)
          A number of people had real 'slow downs' at the higher settings
          • kenK
            ken
            Dave
            Both version of Sketchup, 2014 and 2013.
            Thanks for your reply.
            Ken
            2014 Circle Display Problem.skp
            2013 Circle No Display Problem.skp
              It does indeed seem to be an AA related issue. I saw it with your file on my Mac. If you change AA to 4 using Driven's snippet, the problem goes away.
              A question for you about your circles. Is it common for you to draw circles off axis?
                driven
                @Ken, I see it on my mac, and can make more with the same error with your v2014 skp, but not in a new drawing?
                  driven
                  even, weirder... if I copy/paste'in'place your odd geometry to a new drawing, it's fine in the new...
                    driven
                    Ok, it appears to be 'Style' related, it goes away with a plain default style
                      Ah ha! One of the Sketchy line styles being used in the 2014 file whereas it's not in the 2013 file. Ken, you should try it with the same style in both versions. Make your test valid. πŸ˜‰
                      • BoxB
                        File size of 1.11mb for one 24 sided circle???
                        • jeff hammondJ
                          heh.. yeah. that's it
                          good catch
                            AirWindSolar
                            Following in the footsteps of Adobe and Microsoft.
                            • kenK
                              ken
                              April Fool.
                              No, I had started some modeling using PNG images. I always put the images on a layer so I can turn the images off and on. I was starting to model when I noticed the problem. So I erased everything, trying to find out what the problem was. So when I sent the files the images layers where turned off.
                              Nothing get by. Thanks for you reply.
                              Ken
                              Well, darn I downloaded the file to see what images I had left in the model. There were no images. So I don't know what the problem is with the file size. Does seem a tad bit large.
                              Ken
                              • BoxB
                                It's in the materials, you haven't purged them.
                                • kenK
                                  ken
                                  Thanks, checked my template, somehow it was loaded up. Now I should start with a smaller file size.
                                  Again thanks.
                                  Ken
