    [Plugin] CleanUp
    974 Posts 217 Posters 860.9k Views 217 Watching
      saucerful
      Thanks for the quick reply! Linux is Debian stable (wheezy) with wine from the repository, version 1.4.1.
      Extensions installed via SketchUp GUI.
      • tt_suT Offline
        tt_su
        it would be cool if we could access the delete coplanar feature with respect to the materials via a shortcut πŸ˜ƒ would save me a thousand clicks...
        If you set up the dialog to merge only by material you can use the Clean With Last Settings by shortcut. It's a workaround, but it currently works.
          saucerful
          By the way, I tried installing SketchUp 2013 and got the same output in console and dialog. Let me know if I can help debug. Thanks!
          • tt_suT Offline
            tt_su
            Can you install this RBZ and go Plugins > SketchUp Diagnostics Tools > Collect Data ?
            Now, it should put a txt file on your Desktop... though I'm not sure how this works when you are running Linux+Wine... :s
            su_diagnostics.rbz
              saucerful
              Diagnostic ouptut is attached.
              SketchUp-Diagnostic.txt
              • tt_suT Offline
                tt_su
                Given that file I don't see CleanUp as being installed - only TT_Lib2...
                  saucerful
                  Whoops, I removed Cleanup to check whether I would get errors with just TT_Lib. And I did.
                  I reinstalled CleanUp and attached the diagnostic. Thanks for your patience.
                  SketchUp-Diagnostic2.txt
                  • tt_suT Offline
                    tt_su
                    Ah, right!
                    And the error message you posted here: http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=22920%26amp;view=unread%26amp;sid=3c5780a432a36ee6c62eb305f16f5390#p516006
                    Was that with or without CleanUp installed?
                      saucerful
                      With. Without I get just the first half:
                      Error Loading File C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb
                      uninitialized constant TT;;GUI;;ToolWindowError Loading File TT_Lib2.rb
                        Are you able to run SU2014? It should provide a more detailed error to pin-point where it fails.
                        I'm not a linux user and I only ever tried Ubuntu briefly in 2008... :s
                          saucerful
                          Unfortunately SketchUp 2014 doesn't work at all. I've attached diagnostic output from SketchUp 2013, in case that helps...
                          SketchUp-Diagnostic2013.txt
                          • tt_suT Offline
                            tt_su
                            I'm sorry how much back and forth this takes, but without being able to reproduce I'm a bit blind here.
                            SketchUp prior to SU2014 has flawed error messages that makes it hard to debug. Can I ask you to open the Ruby Console (SketchUp's console, not Linux) and see what you get from this command: load "TT_Lib2/core.rb"
                            • tt_suT Offline
                              tt_su
                              What? "load_uninstalled.txt" was a result of running load "TT_Lib2/core.rb when TT_Lib was uninstalled? That makes no sense because it's loading files... if you had unisntalled TT_Lib2 then load "TT_Lib2/core.rb should have returned an error about file not found.
                              I'm not able to make any sense out of this...
                              Did you restart SketchUp after uninstalling?
                                saucerful
                                Sorry, by uninstall I meant unchecking TT_Lib2 and Cleanup in the Extensions dialog and restarting SketchUp.
                                The TT_Lib2 files are still in the Plugins directory. Maybe it makes no sense to run "TT_Lib2/core.rb" in this state? I thought it might be akin to how SketchUp loads the extension at startup?
                                • tt_suT Offline
                                  tt_su
                                  Unchecking TT_Lib2 in the Extension Manager will have no effect.
                                  This error is very strange.
                                  Can you try a few other mutations?
                                  ` load "TT_Lib2/sketchup.rb"
                                  load "TT_Lib2/system.rb"
                                  load "TT_Lib2/entities.rb"`
                                    saucerful
                                    Here's one log for all of them (search for the command to get to it).
                                    loads.txt
                                      saucerful
                                      No worries! I really appreciate your patience and am happy to send you any debug info.
                                      I ran this with both TT_Lib2 installed, and not. I think the latter has more information about the error...
                                      load_installed.txt
                                        @saucerful said:
                                        ...The TT_Lib2 files are still in the Plugins directory. Maybe it makes no sense to run "TT_Lib2/core.rb" in this state?...
                                        πŸ˜• !!! Do you mean by that you have files from the TT_Lib2 folder 'loose' in the Plugins folder?? πŸ˜’
                                        When you install the TT_Lib2 you should have a loader .rb and a subfolder with the same name which contains everything else.
                                        I ANY of the files inside the subfolder have found there way into the Plugins folder they will load out of sync as SketchUp starts, rather that as TT's other plugins 'require' them, as they themselves auto-load...
                                        So if that is the case, then you need to carefully 'sanitize' your Plugins folder and remove all of the TT Lib files that should NOT ever be in there... πŸ˜•
                                          saucerful
                                          It works! Thank you so much. This plugin is extremely useful for our workflow at Open Source Ecology (see here).
                                          Any idea when 2.9.9 will be pushed to the extension warehouse?
                                          • tt_suT Offline
                                            tt_su
                                            @saucerful said:
                                            It works!
                                            Huh! How about that! Stab in the dark!
                                            Glad it worked. πŸ˜„
                                            I'll upload to EW right now. Not sure when it goes live, depends on the moderation queue.
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 48
                                            • 49
                                            • 31 / 49
