    Upgrading plugins to Ruby 2.0 for SketchUp 2014
    43 Posts 7 Posters 8.9k Views 7 Watching
    • tt_suT Offline
      tt_su
      @marksup said:
      Upgrade addition...
      Hash-array indexhas been replaced by key...
      key = ( Sketchup.version.to_i > 13 ) ? hash-array.key(value) : hash-array.index(value)
      Easier to just use key as that works on both versions. Less code branching.
      @marksup said:
      re: Encoding...
      I have tried notepad++ Encoding convert to UTF-8 without BOM but now get...
      Error: #<Encoding::CompatibilityError: incompatible character encodings: UTF-8 and ASCII-8BIT>
      Can you provide context around this error.
      @marksup said:
      Also, what might a (newly supported) unicode string look like?!
      It should look like anything different, but under the hood, all characters that is outside the ASCII range (0-127) will be multi-byte characters.
        marksup
        Hi TT,
        Are you sure about key (and not key?) being valid previously...
        ha = {"A"=>"ABC"}
        ha.key("ABC")
        Error: #<NoMethodError: undefined method `key' for {"A"=>"ABC"}:Hash>
        (eval)
        • tt_suT Offline
          tt_su
          @marksup said:
          Hi TT,
          ha = {"A"=>"ABC"}
          ha.key("ABC")
          (eval)
          Ah! My bad, I misread that. I stand corrected.
            Brighter3D
            Win32API.so seems to no longer works on SU2014, instead we should use build in Win32API.rb.
            When passing
            Sketchup.active_model.skpdoc
            pointer,
            I've got error:
            Error: #<TypeError: no implicit conversion of Fixnum into String>
            C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/Win32API.rb:23:in pack' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/Win32API.rb:23:in block in call'
            C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/Win32API.rb:22:in each' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/Win32API.rb:22:in each_with_index'
            C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/Win32API.rb:22:in call' C:/Users/l/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/BrighterSU/BrighterSU.rb:68:in mydll_render'
            C:/Users/l/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/BrighterSU/BrighterSU.rb:248:in block in InitToolbar' -e:1:in call'
            funciton definition:
            BRrender = Win32API.new(mydll,"RenderScene",["P","P","I","I","I"],"I")
            function call:
            BRrender.call(Sketchup.active_model.skpdoc,Sketchup.active_model.path,width.to_i,height.to_i,nFromSett.to_i)
            Is it because of SU 64bit version?
            Does anyone have similar problem or anyone succeed to pass
            Sketchup.active_model.skpdoc pointer into c++ dll with SU2014?
            • tt_suT Offline
              tt_su
              @brighter3d said:
              When passing
              pointer,
              I've got error:
              function call:
              SketchUp is still 32bit.
              The error you are getting is from the Win32API module. Seems to not like it that you feed it integer. It's expecting strings. Maybe you'll get some hints if you dig into Win32API.rb at the line number that raised the error. This Win32API compatibility shim might not be 100% compatible with the old Ruby 1.8. I'm not sure how much it changed between Ruby 1.8 and Ruby 2.0.
                Brighter3D
                What a pity, I thought this version is 64bit already 😞.
                There is still no possibility to load 64bit's dlls 😞.
                Thank you, you put my thoughts into right direction.
                changing
                into
                BRrender = Win32API.new(mydll,"RenderScene",["I","P","I","I","I"],"I")
                solves the problem.
                Looks like "P" is char* now, and "I" can be int or void*...
                • tt_suT Offline
                  tt_su
                  Yea unfortunately it's not. I know it's a pain for render engines. The workaround would be to use a 64bit helper process to host the render engine.
                  changing
                  into
                  solves the problem.
                  Oh good! Glad that worked. I think there has been some tweaks made between Ruby 1.8 and 1.9 in that respect.
                    marksup
                    I have written a CSV format file SketchUp Importer which includes the following lines...
                    File.foreach(csv_filepath) do |file_data|
                    next if file_data.match(/\A#/)
                    The CSV file includes the following comment line: # Room-Name, Floor Nr, Area m², Length
                    Sketchup 2014 Bugsplats on processing the CSV file (at the match statement) if it is not UTF-8 encoded and includes the squared character.
                    Does this need to be fixed by SketchUp and/or is there anything I can do to detect/avoid the issue (since I can not control either the selected CSV file content or its encoding)?
                    These UTF-8 errors are insidious, and a definitive guide to their avoidance would be very helpful. What have other Ruby programmers been doing (prior to SketchUp 2014) to adjust to the new Ruby version?, are there no existing resources?
                    • tt_suT Offline
                      tt_su
                      Bugsplats should not happen and is something we should fix. Have you submitted the splats? With any information we can use to look it up?
                      If you search on Ruby in general, without the context of SketchUp, you find a number of articles and forum posts with people migrating from Ruby 1.8 to 1.9/2.0.
                      The bugsplat here is troublesome, because it should just raise an error. If it had raised an error you would have been able to try again with a different encoding. Now, I haven't read arbitrary files with ruby yet, but I would have thought there would be a methods in the Ruby StdLib to detect encoding of a given string/file?
                      Back to the bugsplat, can you provide a small snippet that reads a file and a file that will cause it to crash? Smallest possible snippet to reproduce this?
                        If the .CSV file is not in UTF8-without-BOM encoding, but say ANSI, and also since it may include characters like 'm²', these both might cause you issues.
                        It's easy enough to [re]encode any file appropriately using Notepad++.exe...
                        However if the 'm²' were typed in say Unicode, then it might then be converted to a strange looking character combo when re-encoded.
                        In that case you need to retype the character[s] and it should convert automatically to display in UTF8 encoding...
                        Save and retry.
                        Of course, the .RB file itself must of course be properly encoded as UTF8-without-BOM to be compatible with v2014's Ruby2.0, and remember that any special characters [like 'm²'] which you had in any earlier encoding might have to be corrected if already UTF8 compliant... as outlined above...
                          marksup
                          Notepad++ is great, but customers of plugins can not be expected to use it to investigate and correct the encoding of their data files.
                          Is the encoding of a scrambled Ruby file significant? - since a scrambled UTF-8 .rb is reported by Notepad++ as ANSI.
                            It is unfortunate that the encoding of a PC's plain Notepad file is in ANSI.
                            However a txt/csv file made in Excel or through a Ruby script should be encoded as compatible UFT8-without-BOM...
                            If you have made the RBS from an incorrectly encoded RB it will fail in v2014.
                            If you make the RB correctly encoded than encrypt the RBS from that is should be compatible.
                            What Notepad++ sees the contents as is somewhat academic as isn't it a binary file ?
                            Files encoded as UFT8-without-BOM should be compatible with v2014 Ruby2.0 AND all earlier versions of SketchUp and their Ruby version...
                            You could try trapping for the Sketchup.version >= 14 then re-encoding the string got from any data file.
                            You should still be able to 'read' the contents of an ANSI encoded data file [or any type of data file - even binary is 'readable'], but to then use that string in Ruby2.0 you probably need to force some recoding...
                            if Sketchup.version.to_i >= 14
                              lines = IO.read(csv_file_path).force_encoding('UTF-8')
                            else
                            lines.split("\n").each{|line|
                              ### process the line...
                            I typed this without reference and it is untested, but you get the idea...
                            • Dan RathbunD Offline
                              Dan Rathbun
                              Making the first statements of the block:
                              if defined?(Encoding)
                                file_data.encode!("UTF-8") unless file_data.encoding == Encoding;;UTF_8
                              I'm not here much anymore.
                              • tt_suT Offline
                                tt_su
                                You could try to open the file as ASCII-8bit - then attempt to convert the data afterwards. But in general you need to know what encoding a file is in. You'll see editors often provide this option, even Notepad.
                                After reading the file as ASCII-8bit - which is in effect what Ruby 1.8 did - then you could try to change the encoding to UTF-8 - if that fails it's a good chance the file is ANSI encoded in which you can retry with that. (Though there are many variants of ANSI, US-ANSI is most normal one.)
                                As for the crashes - as I mentioned, that should not happen. Did you submit those report? This is important for us in order to address the crash.
                                  marksup
                                  Bugsplat report duly filed.
                                  • tt_suT Offline
                                    tt_su
                                    Keywords we can search for?
                                      marksup
                                      I used the original post above as the scenario description, so... Ruby, Importer, UTF-8 and/or m² should find it.
                                      • tt_suT Offline
                                        tt_su
                                        hm... this crashes deep into the Ruby interpreter...
                                        Can you provide a small code snippet to reproduce it?
                                        • tt_suT Offline
                                          tt_su
                                          I see you included some description in the BugSplat, but I'm afraid it's been mangled formatting. Can you attach sample RB file and sample CSV file? That'll ensure we are reproducing 100% correctly.
                                            Dan Rathbun
                                            FWIW. Now in Ruby 2.x, you can specify the arguments that will be used for IO.new via IO.open, as the last argument to File.foreach(), which is inherited from [%(#BF0000)[IO.foreach()]](http://www.ruby-doc.org/core-2.0.0/IO.html#method-c-foreach).
                                            Example
                                            File.foreach( csv_filepath, {;mode=>"r", ;encoding=>"ASCII;UTF-8"} ) do |file_data|
                                              # statements
                                            • 1 / 3
