    Upgrading plugins to Ruby 2.0 for SketchUp 2014
    43 Posts 7 Posters 10.6k Views 7 Watching
      If the .CSV file is not in UTF8-without-BOM encoding, but say ANSI, and also since it may include characters like 'm²', these both might cause you issues.
      It's easy enough to [re]encode any file appropriately using Notepad++.exe...
      However if the 'm²' were typed in say Unicode, then it might then be converted to a strange looking character combo when re-encoded.
      In that case you need to retype the character[s] and it should convert automatically to display in UTF8 encoding...
      Save and retry.
      Of course, the .RB file itself must of course be properly encoded as UTF8-without-BOM to be compatible with v2014's Ruby2.0, and remember that any special characters [like 'm²'] which you had in any earlier encoding might have to be corrected if already UTF8 compliant... as outlined above...
        marksup
        Notepad++ is great, but customers of plugins can not be expected to use it to investigate and correct the encoding of their data files.
        Is the encoding of a scrambled Ruby file significant? - since a scrambled UTF-8 .rb is reported by Notepad++ as ANSI.
          It is unfortunate that the encoding of a PC's plain Notepad file is in ANSI.
          However a txt/csv file made in Excel or through a Ruby script should be encoded as compatible UFT8-without-BOM...
          If you have made the RBS from an incorrectly encoded RB it will fail in v2014.
          If you make the RB correctly encoded than encrypt the RBS from that is should be compatible.
          What Notepad++ sees the contents as is somewhat academic as isn't it a binary file ?
          Files encoded as UFT8-without-BOM should be compatible with v2014 Ruby2.0 AND all earlier versions of SketchUp and their Ruby version...
          You could try trapping for the Sketchup.version >= 14 then re-encoding the string got from any data file.
          You should still be able to 'read' the contents of an ANSI encoded data file [or any type of data file - even binary is 'readable'], but to then use that string in Ruby2.0 you probably need to force some recoding...
          if Sketchup.version.to_i >= 14
            lines = IO.read(csv_file_path).force_encoding('UTF-8')
          else
          lines.split("\n").each{|line|
            ### process the line...
          I typed this without reference and it is untested, but you get the idea...
          • Dan RathbunD
            Dan Rathbun
            Making the first statements of the block:
            if defined?(Encoding)
              file_data.encode!("UTF-8") unless file_data.encoding == Encoding;;UTF_8
            I'm not here much anymore.
            • tt_suT
              tt_su
              You could try to open the file as ASCII-8bit - then attempt to convert the data afterwards. But in general you need to know what encoding a file is in. You'll see editors often provide this option, even Notepad.
              After reading the file as ASCII-8bit - which is in effect what Ruby 1.8 did - then you could try to change the encoding to UTF-8 - if that fails it's a good chance the file is ANSI encoded in which you can retry with that. (Though there are many variants of ANSI, US-ANSI is most normal one.)
              As for the crashes - as I mentioned, that should not happen. Did you submit those report? This is important for us in order to address the crash.
                marksup
                Bugsplat report duly filed.
                • tt_suT
                  tt_su
                  Keywords we can search for?
                    marksup
                    I used the original post above as the scenario description, so... Ruby, Importer, UTF-8 and/or m² should find it.
                    • tt_suT
                      tt_su
                      hm... this crashes deep into the Ruby interpreter...
                      Can you provide a small code snippet to reproduce it?
                      • tt_suT
                        tt_su
                        I see you included some description in the BugSplat, but I'm afraid it's been mangled formatting. Can you attach sample RB file and sample CSV file? That'll ensure we are reproducing 100% correctly.
                        • Dan RathbunD
                          Dan Rathbun
                          FWIW. Now in Ruby 2.x, you can specify the arguments that will be used for IO.new via IO.open, as the last argument to File.foreach(), which is inherited from [%(#BF0000)[IO.foreach()]](http://www.ruby-doc.org/core-2.0.0/IO.html#method-c-foreach).
                          Example
                          File.foreach( csv_filepath, {;mode=>"r", ;encoding=>"ASCII;UTF-8"} ) do |file_data|
                            # statements
                          • tt_suT
                            tt_su
                            @dan rathbun said:
                            "ASCII:UTF-8"
                            • Dan RathbunD
                              Dan Rathbun
                              I also wrote:
                              @dan rathbun said:
                              ..., you can specify the arguments that will be used for IO.new
                              so ...
                              http://www.ruby-doc.org/core-2.0.0/IO.html#method-c-new
                              It's an example.
                              At the console you can get names like this:
                              Encoding::ASCII.names %(#008040)[>> ["US-ASCII", "ASCII", "ANSI_X3.4-1968", "646"]]
                              Encoding::ASCII_8BIT.names %(#008040)[>> ["ASCII-8BIT", "BINARY"]]
                                I had a weird problem with a txt file using IO.read to get a string...
                                Notepad++ said was encoded as ANSI, but Ruby2.0 said was was encoded as UTF-8...
                                I could read and parse the string in Ruby1.8, but in Ruby2.0 it sometime 'threw a wobbler' about wrongly encoded characters...
                                If the string was all normal ASCII type characters then no issue...
                                BUT if the string contained an accented character it caused the 'wobbler'...
                                If I re-encoded it in Notepad++ to UTF8-without-BOM - then again no issues with the accents in Ruby2.0 or Ruby1.8.
                                A 'puts' for the strings read for the two file encodings showed differences with \E... etc where the accents were.
                                In Ruby2.0 I tried to force the encoding to UFT-8, but since it thought it already was in that it failed.
                                This was my workaround:
                                data = IO.read(@data_file) data = data.force_encoding('ISO-8859-1').encode("UTF-8") if defined?(Encoding) @uid = data.split('&')[-1].to_s.chomp --> Gábor
                                etc...
                                Now in v2014 it reads and parses OK and in earlier versions it works too...
                                Forcing the encoding into one that it is never going to be [as in my case anyway] and then back to UTF-8 works...
                                I don't know why it thought the encoding was NOT in ANSI but...
                                Incidentally - this also uncovered another oddity...
                                In Ruby1.8 if you use the File.new to make a txt file and write an ASCII string it is reported as a UTF8... encoded file by Notepad++
                                BUT if the string contains an accented character the file encoding is reported as ANSI.
                                Since Ruby1.8 can cope with either encoding when parsing strings etc it causes no issues, but if you have such a txt file, without the above double encoding workaround it causes issues with Ruby2.0...
                                  marksup
                                  TIG - THANK YOU!
                                  I was working on the UTF-8 errors issue when your last post displayed. I can confirm that...
                                  File.foreach(csv_filepath) do |file_data|
                                  file_data.force_encoding('ISO-8859-1').encode("UTF-8") if defined?(Encoding)
                                  Works in both (SketchUp) Ruby releases exactly as you say.
                                  • tt_suT
                                    tt_su
                                    I've reproduced the crash and it happens in the Importer class wrapper that is supposed to return the result code. That's why it works when you call the method directly and not via the Importer dialog.
                                    • tt_suT
                                      tt_su
                                      Right, so I got a fix for it on our side. Until then you can work around the crash by catching Ruby errors in Importer.load_file
                                      <span class="syntaxdefault"><br /></span><span class="syntaxkeyword">class&nbsp;</span><span class="syntaxdefault">CSV_ImporterC&nbsp;</span><span class="syntaxkeyword"><&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Importer<br />&nbsp;&nbsp;def&nbsp;description<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">return&nbsp;</span><span class="syntaxstring">"CSV&nbsp;Importer&nbsp;(*.csv)"<br />&nbsp;&nbsp;</span><span class="syntaxdefault">end<br />&nbsp;&nbsp;def&nbsp;file_extension<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">return&nbsp;</span><span class="syntaxstring">"csv"<br />&nbsp;&nbsp;</span><span class="syntaxdefault">end<br />&nbsp;&nbsp;def&nbsp;id<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">return&nbsp;</span><span class="syntaxstring">"CSV-Importer"<br />&nbsp;&nbsp;</span><span class="syntaxdefault">end<br />&nbsp;&nbsp;def&nbsp;supports_options</span><span class="syntaxkeyword">?<br />&nbsp;&nbsp;&nbsp;&nbsp;return&nbsp;</span><span class="syntaxdefault">false<br />&nbsp;&nbsp;end<br />&nbsp;&nbsp;def&nbsp;load_file</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">file_path</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">status</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;return&nbsp;</span><span class="syntaxdefault">1&nbsp;</span><span class="syntaxkeyword">if&nbsp;(&nbsp;</span><span class="syntaxdefault">not&nbsp;status</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">CSV_importerF</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">file_path</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;return&nbsp;</span><span class="syntaxdefault">0<br />&nbsp;&nbsp;rescue&nbsp;StandardError&nbsp;</span><span class="syntaxkeyword">=>&nbsp;</span><span class="syntaxdefault">e<br />&nbsp;&nbsp;&nbsp;&nbsp;puts&nbsp;e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">message<br />&nbsp;&nbsp;&nbsp;&nbsp;puts&nbsp;e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">backtrace</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">join</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"\n"</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;return&nbsp;</span><span class="syntaxdefault">1<br />&nbsp;&nbsp;end<br />end<br /><br />def&nbsp;CSV_importerF</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">csv_filepath</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">File</span><span class="syntaxkeyword">.foreach(</span><span class="syntaxdefault">csv_filepath</span><span class="syntaxkeyword">)&nbsp;do&nbsp;|</span><span class="syntaxdefault">file_data</span><span class="syntaxkeyword">|<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">next&nbsp;</span><span class="syntaxkeyword">if&nbsp;(&nbsp;</span><span class="syntaxdefault">file_data</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">match</span><span class="syntaxkeyword">(/\</span><span class="syntaxdefault">A</span><span class="syntaxcomment">#/)&nbsp;or&nbsp;not&nbsp;file_data.include?(",")&nbsp;)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">puts&nbsp;</span><span class="syntaxstring">"Floor&nbsp;#{file_data.chomp.split("</span><span class="syntaxkeyword">,</span><span class="syntaxstring">")[1].to_i}"<br />&nbsp;&nbsp;</span><span class="syntaxdefault">end<br />end<br /><br />Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">register_importer</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">CSV_ImporterC</span><span class="syntaxkeyword">.new)<br />&nbsp;</span><span class="syntaxdefault"></span>
                                      As for reading the file correctly, I would first try to read the CSV file in UT-8, then if that fails, fall back to ISO-8859-1 (or maybe try to use whatever codepage is in use if Ruby will let you know this.)
                                      • Dan RathbunD
                                        Dan Rathbun
                                        Didn't Bugra say the two Ruby loadpaths were encoded in the local code page ?
                                          Jim
                                          This isn't new for SketchUp 2014 - it's been around for awhile.
                                          • tt_suT
                                            tt_su
                                            Yup, I saw that when I tested. Bad one - but at least it can be caught. ...one just have to know about it... 😒
                                            But it's fixed in-house now. 😄
                                            • 2 / 3
