    [Plugin] Hole Punching Tool
    200 Posts 43 Posters 227.0k Views 43 Watching
    • TIGT Online
      @moonray
      Let's assume you've installed it properly.
      There is NO Plugins-menu item or toolbar.
      If you right-click the context-menu has a submenu for the tool.
      Some items are enabled/disabled - depending on what is selected.
      If you have a component-instance selected that is gluing/cutting and glued to a face then you get the Punch option etc...
      Can you post a simple example SKP so that we can see what you have done...
      If you have not installed it properly, then you won't get the tool appearing in SketchUp at all.
      How did you install it exactly ? πŸ˜•
      Your post suggests that the file/subfolder have installed correctly into the Plugins folder... but this might be an illusion...
      Can you post a screen-shot of the folder, including its top bars in Windows Explorer...
      If you have limited access rights to your Plugins folder Windows can leave you thinking it's installed, but it's not! Limited security permissions is the default for folders inside the Program Files tree - it needs adjusting to allow you to add/manage plugins...
      A button/link in the window's top-bars saying 'Compatibility Files...' is a give away...
      To set up you Plugins folder correctly...
      As an admin [if you are not already one change your status in the Users Control Panel.
      Find the Plugins folder and select it
      Right-click
      Context-menu
      Properties
      Security
      Edit...
      set permissions to FULL [read/write] for all users/groups listed
      Apply/OK
      Also select the SketchUp.exe file [in the same folder] and in the same way...
      Properties
      Compatibility
      Tick the bottom check-box 'Run this Application as Administrator'
      Now you can add/manage your Plugins... β˜€
        moonray
        Thank you for reply!
        Yes understand that it is should be ncontext menu (not simple)
        I have changed permitions to maximum rights both of exe file and plugins folder but
        I still haven't found what I am looking for.
        Please see my attached screens and the file.
        scene and screenshots of folders
          moonray
          It is OK! Thank you!
          It works perfectly!
          The reason was that i did not install the plugin inside sketchup itself, but just copied files to folders. I did not know that I am so stupid. 🀣
          Thankyou! β˜€
          • TIGT Online
            Glad it's fixed.
            The RBZ is an archive and it's contents need installing into the Plugins folder... πŸ˜’
              davidfromwisbech
              I am having a real problem with getting the hole punching tool to work, I am obviously missing something
              I have added a sketchUp file of where I am with it
              I would like to thank you in advance for your help
              Regards
              David
              Hole Punching Test.skp
              • TIGT Online
                @David
                You Component doesn't CUT a hole in its glued face, so how do you expect it to PUNCH one ??
                  TIG beat me to it but note the changes I made to your model.
                  • TIGT Online
                    Here's a future-proofed update.
                    http://sketchucation.com/forums/viewtopic.php?p=271170#p271170
                    • TIGT Online
                      This updated version makes the lingvo files compatible with v2014.
                      http://sketchucation.com/pluginstore?pln=HolePunchTool
                        garystan
                        TIG :
                                Does the Hole Punchng Tool (plugin) require Sketchup 8 Pro ?  The reason I'm asking is because I have Sketchup 8 (Free).  When I downloaded this plugin, Sketchup said it was downloaded and installed.  But, apparently, it's not in my Plugins Folder (within Sketchup).   I checked and it is in the sdk folder inside of the Plugin Folder.  But, the documentation doesn't state where it's supposed to be downloaded to, or what version of Sketchup it works with.  With the Torus plugin, the documentation stated it would reside in the DRAW tab in Sketchup (which it is).
        garystan
                        • TIGT Online
                          If you read the usage notes... πŸ˜’
                          This tool only ever appears in the right-click context-menu.
                          The enabled items vary depending on what is currently selected...
                          From just 'set depth', to punch [if not punched], to undo/redo/unlink etc if it is punched...
                          It is about to be reissued [tomorrow?] after reports of an observer glitch preventing Move etc [selection auto-undo] if the selection contains a punched component...
                          This will be fixed shortly...
                          • TIGT Online
                            Here's an update in the PluginStore....
                            v2.8 Fixes an observer glitch whereby the whole selection was cleared if a punched instance/reveal was in the selection and the active tool was changed. πŸ˜’
                            Turned out to be a simple typo 😳
                            Please update your installation...
                              SSM
                              Great tool but mine isnt working. After trying to place my window component, I right click to select "punch hole" but the only option I can select is "set depth". Thanks for any help in advance!
                              • TIGT Online
                                Is your component definition [door/window/etc] set up to both glue AND cut ?
                                It must cut a hole in its glued_onto-face BEFORE it can ever be considered for a 'punch'...
                                If not, then it will never work...
                                AND please remember that a cutting component definition must have its 'blue' axis [shown as a blue-X] perpendicular to its main geometry - i.e. so it 'lays onto the face that it is to 'cut'.
                                Post an example SKP with wall/instances so we can see what you have set up wrongly...............
                                πŸ˜•
                                • mariochaM Offline
                                  mariocha
                                  After inserting doors and windows, which do cut openings, in some particular cases I would like the cut face to be copied and visible on the parent face, i.e outside the compo. Do you think part of your plugin could be used to get that ?
                                  %(#008000)[Mario C.
                                  • TIGT Online
                                    I don't fully understand the question...
                                    If you UNlink the cutting instance - context-menu - then it is no longer connected to the instance anyway ?
                                    Please explain what you mean/want = somewhat better...
                                    Or perhaps ex-the-tool - how about using "intersect" between the instance and face, then "unglue" the instance ??
                                    • mariochaM Offline
                                      mariocha
                                      Finally, I think your suggestion to intersect the compo with the face will be just fine. Thousand thanks ! πŸ˜„
                                      %(#008000)[Mario C.
                                        Maybe can help for some cases ?
                                        • mariochaM Offline
                                          mariocha
                                          Dynamic components tend to get pretty complicated. They are mainly made of sub-components and groups.
                                          In order to have them cut opening, I add loose edges framing the opening I want.
                                          Some geometry, trimmings, extend outside the perimeter of those edges.
                                          And also, some geometry are hidden, depending on the user choice of options.
                                          So HolePunch is having a lot of problems with my complicated DCs.
                                          Looking at the code, I think I understand that it is adding all the faces of sub components and groups as punching elements. Too many overlapping geometry in my DCs, I think.
                                          Btw, your code is a huge lesson in high level SU Ruby API coding.
                                          So my question; Is a HolePunch variant taking only the cut-opening edges as punching elements a good idea ? If so, feasible ?
                                          PunchCutOpening.rb ? πŸ˜‰
                                          %(#008000)[Mario C.
                                          • mariochaM Offline
                                            mariocha
                                            Ok, so as not to have anybody waste time over this, let it be known that I have done it. Well only proof of concept. Still a lot to do.
                                            It took a lot of reading of numerous post and I must thank TIG, TT, Dan, Driven, Jim, and others for their several replies to newbies questions and for their unscripted plugins from which one can learn a lot.
                                            Cookies to you all SU-Ruby masters. πŸ˜„
                                            %(#008000)[Mario C.
                                            • 10 / 10
