    Vray split texture
    renderpluginsextensions
    5 Posts 4 Posters 532 Views 4 Watching
    • greenskpG Offline
      greenskp
      Whenever i use plugins for fixing Uv mapping ( like sketchUv, uvtools or uv toolkit ), v-ray extracts in folder ChaosGroupTextureCache many textures. It splits this one texture of the my model.
      The rendering takes a long time or crashes SketchUp.
      vray split texture
      vray version
      This model have:
      1 model
      7.871 faces
      Then vray goes extracts around 7.871 Tile_Checker_BW_extractedTex.jpg JPEG'S
      Someone knows of one workflow to it doesn't happen?
      • dkendigD Offline
        dkendig
        if the uv mapping tool you use, is calling make unique for the material on each face, then you're going to get a unique texture for each face.
        Why are you using 1.60.22982?....
        Devin Kendig
        Developer
        • V Offline
          valerostudio
          2.0
          2.0
          2.0!!!!!!!!!!!!
          • greenskpG Offline
            greenskp
            Then this problem is at uv mapping plugin.
            I did a test with 2.0 e same thing happened.
            The unique plugin that worked fine was Thrupaint.
            • andybotA Offline
              andybot
              I believe if you triangulate, you can avoid writing a material for each face. See info in this post:
              http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=44501%26amp;start=120#p513778
              ThruPaint is magic! Definitely the way to go if you can get what you need that way.
