    LayOut not displaying SketchUp!
    Scheduled Pinned Locked Moved LayOut Bug Reporting
    layout
    15 Posts 8 Posters 13.8k Views 8 Watching
    • fionmacoolF Offline
      fionmacool
      I should have raised this a lot earlier in beta testing but thought it was such a big problem that it would get sorted.
      SketchUp models aren't appearing at all properly in LayOut. I can only see a couple of lines in the view- The model is completely transparent no matter what style I choose to display.
      Total breakdown of LayOut! Anyone else have this problem?
      Zere are still some architectes zat do not know ow to use ze SketchUp..... Zis is unbelievable....
      • FrederikF Offline
        Frederik
        No...
        Do you have a sample file...?
        Please post a sample skp-file and a jpg image from LO showing the differences...
        Cheers
        Kim Frederik
          fionmacool
          Thanks for your response.
          Here is the LayOut image and SU file.
          Note that it doesn't make any difference which SU file I use. The model view is set to raster. I can't get LayOut to display raster properly. Vector and Hybrid are better but are still problematic.
          https://lh3.googleusercontent.com/-PiX4I2O8lzc/UxW2uhxy3sI/AAAAAAAAJ7A/JlmMem1YoIk/w341-h193/LayOut+Test.png
          LayOut Test.skp
            Here's what I see. That's all as I would expect.
            SU Model
            LO--Raster
            LO--Hybrid
            • mitcorbM Offline
              mitcorb
              And this is not a graphics driver problem?
              Just asking.
              • FrederikF Offline
                Frederik
                Could be, but I suspect it's a style, which isn't updated...
                Dave...?
                Cheers
                Kim Frederik
                  I didn't do anything to your style before making the LO file and the screen shots so I don't think it is a style thing. Out of curiosity, though, does the scene in the SketchUp inspector show as [Modified]? It didn't on mine.
                    ArCAD-UK
                    In LO pick the view, go to the Sketchup Model tool box and click on Styles. Check you haven't overridden the viewing style in LO?
                      drewcoparker
                      fionmacool,
                      What does the model look like in an image, exported directly from SketchUp? What are your OpenGL settings in SketchUp? Is hardware acceleration on or off? If you were to check or uncheck (whichever is different than what you had) the hardware acceleration setting in SketchUp and then send to LayOut, do you still see the problem? Thanks.
                        fionmacool
                        @drewcoparker said:
                        fionmacool,
                        Well done- Your suggestion worked! It seems as if some setting needed a jolt to get it working. I unchecked hardware acceleration in SU and found that it seemed to fix the problem in LO. Then I tried checking it again and the problem didn't return. Now I'm back to enjoying SU 2014.
                          fionmacool
                          Uh oh... No I'm afraid I'm experiencing problems again. The viewports in LO are not playing nice with my model. Strangely the previous beta release (candidate 4) was much more stable.
                            Update video drivers?
                              tim
                              I'm having a possibly related issue from the looks of it. My house model ( which got started a scary five years ago and still needs some details fixing to reflect the actual building) opens is su14 ok but if sent to lo14 many layers are unseen. In some scenes it looks like most or even all are there, in others virtually nothing shows.
                              In a simpler model I noticed that only items on layer 0 (that is entire components - all my geometry is on layer 0 of course) were shown. After deleting all other layers to force everything to 0 the entire model displayed ok.
                              Haven't tried opening my 'old' LO file yet.
                              Hope it doesn't afflict everyone because I dread to imagine the pain it would cause people like nick sonder!
                              • emerald15E Offline
                                emerald15
                                @ fionmacool
                                I seem to be getting a similar problem with the hardware acceleration in Open GL too. See my post in page 2 of the 'gripes' thread (below). I turned the hardware accelerations off & on again & my select box problem cleared. However, I noticed this morning that it was off again & although the select tool was working correctly (ie. without showing multiple boxes)the screen resolution was so poor everything had 'saw-tooth' edges. When I turn it back on to improve the resolution - I'm back to loads of selection boxes. At the moment it seems I've got to put up with one or other (the latter at present) 'til I find a solution.
                                404 Not Found
                                (sketchucation.com)
                                  tim
                                  Minor additional info - my 'old' LO file for the house model loads does whatever conversion is needed and appears to be fine. Updating the model - which seems to load the 'new' version of the house model as saved by SU14 yesterday - still looks good.
                                  Very odd.
