    [Plugin] Unhide ALL (Edges) - Inside Groups / Components ???
    28 Posts 17 Posters 39.9k Views 17 Watching
    • H
      Howard leslie
      Tomasz / TBD / TIG,
      Thanks to all of you for working on this script.
      Now works really well.
      Regards
      Howard L'
        Jim
        Is the fix posted in this thread still needed for the latest SketchUp versions?
        • P
          Pout
          i just did the test, and yes it is still needed
            Currently the failure to ensure that copies of a group become single instances of a definition is not fixed - group.make_unique still reports as being deprecated, but it is needed - it is possible to have several copies made of a group definition where they act like component instances, and so changing one instance changes the lot - it's what Components are supposed to do BUT that's NOT what groups are supposed to do... When you copy a group it should automatically become a single instance of its definition - there should never be the equivalent of group.definition.instances[1]. It doesn't currently work properly - either manually or scripted... ๐Ÿ˜’
            • H
              hygicell
              yesterday and today sketchup 2013 completely froze when using the unhide plugin (which I have used many times before witout problems)
              the only difference I can see is that I twice had the outliner and components windows open, which I didn't before
              both these windows were on a second monitor which I didn't have before either
              anybody else had this experience?
              Frank
              • mitcorbM
                mitcorb
                I have seen it discussed before, quite a while back, that Outliner especially, and Component windows can cause issues with your work when they are fully open. If you click on the top bar of each, they will "roll up". This, I have read, will reduce the problem.
                Hope this helps.
                  michaelhund
                  Alas, I too have found this plugin freezes in Sketchup 2013. I tried closing all dialogs, particularly the outliner, scenes and layers, and no luck. Pity.
                    AirWindSolar
                    No freeze here, just doesn't appear to do anything at all. Won't even unhide elements within the currently open component, even after view>hidden and Ctrl-A.
                    Will fiddle with it a bit more when I have time.
                      Here's v2.0 - I tweaked it to unhide from the active_context downwards - unhiding everything, even in deeply nested sub-containers...
                      If you start in the model it unhides 'all' entities.
                      If you start in a group it unhides 'all' entities inside that group etc...
                      It is one step undo-able.
                      http://sketchucation.com/pluginstore?pln=unhide_all
                        AirWindSolar
                        Latest update seems to be working.
                        This should save a lot of time when I'm having to shuffle stuff around and hide/unhide a lot to clarify something for the fabrication crews.
                        • P
                          peebo22
                          TIG, your plugin makes Sketchup 2015 crash when there's lots of edges.
                            If you do it in smaller batches, does it succeed ?
                            Also have you tried Model Info > Statistics > Fix Problems... in case there's some corrupted geometry ?
                            Also, when you say 'crash' do you mean a BugSplat!, or does SketchUp just become unresponsive ?
                            In the latter case it should still complete, even if it takes a while...
                              acarl720
                              Thanks for creating this plugin. I had "lost" a group in a model and no matter what I did, I couldn't find it. There was no loose geometry and all components were in groups. I knew it was there when I copied and pasted from an older model and SU said there were two in the current model. This plugin saved me from brute forcing a solution or redoing a lot of work.
                              • B
                                bsfranza
                                hi there,
                                with sketchup 2020 we now have isolate which is pretty cool...
                                and toggle visible active (whatever thats for - i have not found out what this is intended for so far) ...
                                however, the su internal unhide command still does not unhide recursively all inside groups and components ...
                                so here is my humble request > make it possible to unhide all recursively except for softend edges ๐Ÿ˜„...
                                often times edges are hidden inside groups or components on purpose and its bad when thhat information is lost due to a unhide all command...
                                maybe you can add a seperate command to this plugin ๐Ÿ˜„
                                thx and all best, franz
                                  Those are not native commands that are new to SU2020. They come from an extension that you installed.
                                  So you want to unhide everything including hidden edges or faces? What if there are intentionally hidden edges and faces that need to remain hidden?
                                  • 2 / 2
