    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 929.8k Views 175 Watching
    • Y Offline
      yhchen
      Dear TIG,
      Thank you for ur quick response.
      I have tried to run it with Ruby Console, n I found lots of error occur, which I do not understand why.
      Regards,
      Yhchen
      Ruby Console (EE Error)
      sketchup file
        @ynchen
        I have tested the SKP and get good results.
        See the attached image.
        The up/down orientation of the face does not affect the result.
        The over all size of the geometry is within sensible limits.
        You errors...
        EE Error 3:
        means that it is failing to add a curve from the cpoints it has got from the melding-profile...
        EE Error 4:
        is a similar error relating to the profile...
        I can't reproduce any errors... πŸ˜•
        Your image shows one corrected located profile and one set on cpoints following a reversed curve, NOT the profile/melding-profiles lines... before the early failure πŸ˜•
        Here are my thoughts...
        Do you have Guides switched on?
        The toolset uses cpoints etc...
        Your SKP is v6 - I don't have that version readily available to test so it might be a limitation - from available methods for your set up; although the API methods used are for >=v6 ?
        Why not upgrade to a newer 'free' version of SketchUp - it is much improved... v2013 'Make' ?
        Different versions can co-exists on the same PC.
        Are you using the latest version of this Extrude toolset [v2.2] ?
        If not then please get the latest RBZ from the PluginStore pages...
        http://sketchucation.com/pluginstore?pln=ExtrudeTools
        If you have v8M2 or newer you can AutoInstall from the SketchUcation PluginStore dialog within SketchUp or use the Preferences > Extensions > Install... button to do it automatically for you...
        In SketchUp versions <8.M2 you'll need to rename the RBZ as a .ZIP file, and then extract its contents and manually move them into the Plugins folder***
        [if you are not an Admin, make yourself an Admin using the Users Control-Panel: then make sure the Plugins folder has FULL read/write permissions set for every user/group listed under Properties > Security > Edit...]
        ***Always leave helper files within the same subfolder[s] that are inside the ZIP.
        After an update restart SketchUp twice: as it'll need to remove older versions is you have a very out of date installation etc...
        Lastly, what other plugins do you have loading?
        Are any of those quarantined or rogues, as explained in other posts ?
        • Y Offline
          yhchen
          Hello,
          Thank you for your help, I have upgrade my sketchup to 2013 version. now it works perfectly.
          Thank you again for your awesome plugins. All the best ^^
          Regards,
          Yh chen
            bob777
            Very useful...this one and the others. Just made a donation.
            • chriC Offline
              chri
              hello TIG
              I have SKETCHUP PRO 2013
              I installed the plugin ExtrudeTools V2.2
              it works fine.
              I installed SKETCHUP 2014 2 days ago to test this new version.
              Something does not work, can you, please take a look at the following pictures
              Perhaps the plugin is'nt up to date or there is something wrong with my machine !
              Chri
              Best Regards
                Did you install a fresh copy of TIG's plugin? Or did you just drag the old copy over from the previous Plugins folder?
                • chriC Offline
                  chri
                  hi DAVE
                  i have install a fresh copy directly in SKETCHUP 2014 with the plugin store
                  chri
                    @Chri
                    If you get v2.2 of the tool's RBZ from the PluginStore and install it from the RBZ [i.e. don't drag+drop from an opened RBZ as if it were a ZIP file etc] you should then get fresh copies of all of the needed files [including the required helper "deBabelizer.rb"].
                    The error you posted relates to an incompatible version of that file - old ANSI v new UTF8-without-BOM.
                    The new version of Ruby used by SketchUp 2014 is less forgiving and cannot use that text file encoding.
                    Most authors have updated their scripts to have the correct encoding, and thereby suit all versions of SketchUp.
                    The files in this tool's latest PluginStore RBZ are all correctly encoded.
                    To double check I have just reinstalled from a newly downloaded RBZ and it worked fine - the enclosed files are all correctly encoded - I checked πŸ˜•
                    It looks like you copied an older one over from an earlier version's Plugins folder ?
                    Reinstall properly, restart and retest...
                    Or have you installed anything else including deBabelizer.rb ?
                    The few RBZs that do include it should all be correctly encoded if the latest versions are downloaded and installed...
                    An old version will cause issues...
                      Here's v2.3
                      A minor glitch [typo] is now fixed and it's compatible with v2014 once again πŸ˜’
                      • BoxB Offline
                        If you want confirmation, loft wasn't working for me in 2014 and now is. Thanks.
                          The EEby Loft error was a strange one. πŸ˜’
                          A very silly typo, that I'd have expected to make it fail in ANY version seems to be glossed-over by the Ruby of earlier versions.
                          The "princess-pea-under-the mattress" miss-picky Ruby2.0 didn't like it...
                          It was easy to fix when I got my head around it...
                          πŸ€“
                          • chriC Offline
                            chri
                            Hi TIG
                            I have tried once again .. and there is always something wrong .
                            what i have done
                            1 - Erasure of all new plugins
                            2 - Installation of plugin Extrude Tools 2.3 with plugin store + Autoinstall
                            3 - Closure and reboot
                            Chri
                              Why does the error message include "invalid byte sequence in UTF-8"?
                              French Windows and English SketchUp?
                                This is most strange. πŸ˜•
                                I have just repeated all of your steps...
                                It reinstalls and works fine after a restart [just in case something was adrift]...
                                That RBZ's version of deBabelizer.rb IS the newest, and therefore compatible - I converted it a few months ago...
                                BUT your file says 02/12/2013 AND that IS the current file ?
                                Try this known-to-work version [install from the attached RBZ]...
                                Restart SketchUp to retest...
                                If this fixes, then it the mystery deepens...
                                BUT at least you'll have a working version...
                                deBabelizer.rbz
                                  PS:
                                  Can you attached your version of deBabelizer.rb that is raising the issue on your system, so I can compare it with the 'real' [working] one that you should have...
                                  Can you also check that you have FULL security permissions to the Plugins folder...
                                  It should be set automatically...
                                  • chriC Offline
                                    chri
                                    @tig said:
                                    PS:
                                    deBabelizer.rb
                                    • chriC Offline
                                      chri
                                      @tig said:
                                      PS:
                                      i dont know how to do this πŸ˜•
                                        That IS the correct file.
                                        It should NOT raise a UTF8 error...
                                        It is correctly encoded...
                                        It works for me.
                                        It works for others...
                                        Weird...
                                        Incidentally, don't confuse the subfolders containing some files that are shipped with SketchUp v2014, with the main Plugins folder that is now located in your Users account...
                                        Security... http://sketchucation.com/resources/tutorials/36-intermediate/811-setting-security-permissions-in-sketchup
                                        • chriC Offline
                                          chri
                                          I have seen this and make an announcement on the french forum
                                          here :
                                          http://sketchucation.com/forums/viewtopic.php?f=51%26amp;t=56469
                                          chri
                                          • jiminy-billy-bobJ Offline
                                            jiminy-billy-bob
                                            here :
                                            There's a french forum?!
                                            I don't have access to it, how can I?
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 31
                                            • 32
                                            • 24 / 32
