    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    337 Posts 108 Posters 564.9k Views 108 Watching
    • V
      vilcoyote57
      help me.. I've installed building structure v.1.92 under sketchup 2013. I cannot use it 'cause when I click on the "show tools" on bst toolbar this popup comes out:
      BST TOOLBOX is already running
      or if I click on Table Editor, this popup
      TABLE EDITOR is already running
      this never happen under Sketchup 8 Pro.. everything ok
      platform:
      asus laptop
      windows 7 pro 64bit
      waiting...
      Pier
      • T
        tak2hata
        Hi,Andy and Sumaster and vilcoyote57 and everyone.
        I update this to version 1.9.5.
        I am terribly sorry for keeping you waiting.
        I was too busy,So I can not test the problem.
        I guess the problem about showing dialogs in Sketchup2013.
        So This version is test release.
        Please try this.
        Thanks.
        by TAK2HATA
        • sumasterS
          sumaster
          Hello Tak2hata sir,
          Thanks for this release . . . .
          I will check this release and update how it works . . . .
          Thank you,
          SUmaster
          • sumasterS
            sumaster
            Hello tak2hata,
            the html is not load correctly like previous version different Tab in html . . . . .
            Thank you,
            SUmaster
              setyabudi73
              tak2hata , how can i use your newest plugin bst 1.95. when i install in sketchup 2013, it can load data from pflist. what can i do to solve that problem. tks
              • T
                tak2hata
                Hi,setyabudi.
                Please download pflist csv file from top of this thread.
                http://sketchucation.com/forums/viewtopic.php?f=323&t=35798#p315482
                Hi,Sumaster.
                This image is difficult for me.
                I need the detail of your problem.
                Please show your ruby console.
                And start BST.
                Copy and paste the error message ,if there is any error message in ruby console.
                When there is no error,Please tell me your installed folder for this plugin.
                And capture the screen shot of the different tab.
                by TAK2HATA
                  setyabudi73
                  Hallo tak2hata
                  thank you for your attention in my problem loading pflist on BST 1.95, but that is not solve my problem. Still blank when i try load from BST. If you don't mind please help me . Like your plug in very much since BST 1.2. Thank you
                  • C
                    cadmunkey
                    Hi tak2hata, do you have a donate button anywhere? I get a lot of use out of this great tool and feel you deserve a reward for your time and effort. Many thanks.
                    • T
                      tak2hata
                      @setyabudi73 said:
                      Hallo tak2hata
                      Hi,setyabudi73.
                      I can not watch your "Still blank".
                      You mean the Webdialog is blank? or Listbox is blank? or Table editor is blank.
                      Please capture the screen of the webdialog of your sketchup.
                      And please show ruby console from windows menu in sketchup.
                      And start the BST.
                      Please copy the message on the ruby console,if error message was shown in ruby console.
                      And post the paste here.
                      and I want to know your pflist file path if I could.
                      and your OS is Windows or Mac.
                      Please tell me.
                      I should consider well about your problem.
                      Hi,Cadmunkey.
                      Thanks for your thanks.
                      I do not have donate button.
                      I get a mug of beer each month from youtube and adsense.
                      It is my good reward.
                      by TAK2HATA
                      • fariborz110F
                        fariborz110
                        It's Perfect!THX
                          manel_91
                          Thanks a lot! It's very useful!
                          • H
                            hkbauing
                            a simple question: how to use the lang_de.txt?
                            • facerF
                              facer
                              The UK_pflistAC file does not show list of steel
                              SketchupMaker 2014
                              W7 operating system
                              File location for UK_pflistAC is:
                              Documents\Sketchup_Maker_2014\UK_pflistAC
                              screen capture of attempted use of steel sections
                              • T
                                tak2hata
                                SketchupMaker 2014
                                W7 operating system
                                Hi,facer.
                                I will test it later.
                                Please wait.
                                by TAK2HATA
                                • T
                                  tak2hata
                                  Hi,facer and all.
                                  I update this to v1.9.6. in 2014.05.25.
                                  The problem of the read profile in sketchup2014 was fixed.
                                  And add some improves.
                                  HKBauing.
                                  From the menubar ->"plugins"->"building structure tool"->"Change language file"
                                  Select the lang file.
                                  and It will complete with restart sketchup.
                                  Thanks.
                                  TAK2HATA
                                  by TAK2HATA
                                  • JQLJ
                                    JQL
                                    Hi Tak2hata,
                                    I just saw this new version coming up and even if I have no direct need for the plugin it, looks impressive indeed! Congratulations!
                                    As I was watching the video and I saw that you classify building elements by type and name I remembered the new SU2014 "classifier" feature and I thought that it would be truly useful for your users if your tool would classify strutural elements in a standard BIM way, like IFC using the 2014 "classifier".
                                    Probably it already does that and I missed that feature, but if it doesn't, with what you have right now, what a monster this might become...
                                    Congratulations once again and keep up your great work.
                                    PS: I saw in a post before, you had an accident, I hope your better now...
                                    www.casca.pt
                                    Visit us on facebook!
                                    • sumasterS
                                      sumaster
                                      Hello Tak2hata,
                                      this is your new updated Bs Tools 1.9.6 getting error when opening Show Tools Option and Table Editor in Sketchup 2013 Version 13.0.4812
                                      Please check below . . . . . . .
                                      "show webdialog by CODE"
                                      Error; #<NoMethodError; undefined method `encode' for #<String;0xcd547a4>>
                                      C;/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/building_structure_tool/tst1_mod_common_util.rb;518;in `split_csvline'
                                      C;/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/building_structure_tool/tst1_mod_common_util.rb;480;in `getCSVFile'
                                      C;/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/building_structure_tool/tst1_mod_common_util.rb;477;in `each_line'
                                      C;/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/building_structure_tool/tst1_mod_common_util.rb;477;in `getCSVFile'
                                      C;/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/building_structure_tool/tst1_mod_common_util.rb;326;in `readProfiles'
                                      C;/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/building_structure_tool/tst1_class_tool_for_wdlg.rb;580;in `init_webdialog'
                                      C;/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/building_structure_tool/tst1_class_tool_for_wdlg.rb;849;in `show_tooldialog'
                                      C;/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/building_structure_tool/main.rb;421;in `call'
                                      Error; #<NoMethodError; undefined method `encode' for #<String;0xcee32a0>>
                                      C;/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/building_structure_tool/main.rb;421;in `tst_menu_add'
                                      C;/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/building_structure_tool/tst1_class_table_editor.rb;24;in `show_tooldialog'
                                      (eval);1;in `tst_menu_add'
                                      C;/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/building_structure_tool/tst1_mod_common_util.rb;518;in `eval'
                                      C;/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/building_structure_tool/tst1_mod_common_util.rb;518;in `call'
                                      Thank you,
                                      SUmaster
                                      • T
                                        tak2hata
                                        I update this to v1.9.7.
                                        Fix the encoding code problem.
                                        Hi,JQL.
                                        I search the Sketchup ruby API,
                                        but there are no method for approaching to classifier.
                                        I will wait for future release.
                                        Thanks.
                                        by TAK2HATA
                                        • sumasterS
                                          sumaster
                                          Hello Tak2hata Sir,
                                          NOW Its working . . . . . . . Thanks . . . . . 😍
                                          Thank you,
                                          SUmaster
                                          • G
                                            goga63
                                            Good day !
                                            Found bug in versions of Sketchup 2013 and Sketchup2014.
                                            in Sketchup 2014 when you open the "Component Options" message on the error.
                                            If using the editor Attribute in the Directory "BEAM_SPECS" attribute "PATH" to change the value of " [Point3d(0, 0, 0), Point3d(0, 100, 0)] "
                                            to Point3d(0, 0, 0), Point3d(0, 100, 0) " , deleting the characters "[" and "]" ,
                                            the error message does not occur.
                                            http://ipic.su/img/img7/fs/error.1410935291.jpg
