    [Plugin] RichSection V0.5.8 UPDATED march 2015
    395 Posts 85 Posters 231.7k Views 85 Watching
    • P
      pgarmyn
      @jeff hammond said:
      not sure if there's a way to make the cut color the same as the object? haven't really messed around with the settings too much in richSection.
      YES 😄
      Parameters for "cut color the same as the object" :
      • Set 'RichSection material name' to "prefix+materialname, default"
      • Set 'RichSection materials, prefix' to "" (empty)
      • fionmacoolF
        fionmacool
        @pgarmyn said:
        @fionmacool
        I guess you want to hide section-lines between different elements?
        There is a beter way to controle that. I will make (soon) some "how to" videos. I will post them with the next update.
        I want to keep the nesting & layer structure of the section-group identical to the model. To syncronize visibility and invisibility if certain layers are switched off.
        It can become an option if you can really convince me of the advantage in a standard workflow to produce several sections of one model.
        Thanks for your reply. OK so I'm not sure I understand you entirely... but to answer your last point- definitely multiple sections are desirable for each model- all technical drawings require one plan and one vertical section at least. The problem at the moment is that the 2D section info is "behind" the section cut so that it interferes with visibility. Does that make sense?
        Zere are still some architectes zat do not know ow to use ze SketchUp..... Zis is unbelievable....
        • P
          pgarmyn
          @fionmacool said:
          .....that it interferes with visibility. Does that make sense?
          What do you mean by interfere...
          In this model floorslabs, stairs, walls etc. are separated groups. But i can control visibility of the faces separating those elements.... Zere are still some .... ?
          • jeff hammondJ
            @pgarmyn said:
            YES 😄
            neat.
            i tried a quick one in indigo with glass, metal, and wood..
            i didn't let it render as long as it would need but it shows that it would work in an actual render..
            glass- one solid sphere (rendered as a solid piece of glass)
            metal- sphere inside a sphere (rendered as if it were a bowl)
            wood- i resized the texture on the facing side.. the cut shows the original size.. probably not good to use this technique on renders requiring high quality texturing/mapping (as in- that block would require end grain etc.)
            • P
              pgarmyn
              @jeff 👍 👍
              • K
                kylintz
                I think it's perfect already. The last puzzle to this plugin, as suggestion would be :
                1. How could the section manage not only material per group, but also the section line thickness for each group ?
                2. And suppose we would like to create a furniture layout plan, how could we let furniture layer not afected by the section plane while at the same time letting the wall layer, column layer, windows and door cut by section plane in easy way? A different hierarchy in grouping works well, leaving the furniture group outside the parrent group of wall, door, window, floor, structure, but that would mean a special group just for the sake of displaying unsliced furniture on the floor plan.
                • P
                  pgarmyn
                  @kylintz
                  1. The sectionlines are produced by Sketchup. There is no way to control thickness. An option could be to ad sectionlines with TIG's linestyle (2D Tool). I plan to add dxf export with that capability: Sectionline by layer.
                  2. A special group is the only solution. The Sketchup Ruby API (programmer interface) doesn't let you controle what to cut.
                    😄 Thanks for your interest. 😄
                  • P
                    pgarmyn
                    RichSection plugin [highlight=#ffff00:2tqcoasz]UPDATED[/highlight:2tqcoasz] : download from the Plugin Store
                    404 Not Found
                    (sketchucation.com)
                      diegob
                      I've just intsalled your updated plug-in
                      but apparently is not working
                      once Sketchup is started, a window is telling me that:
                      Error loading files PiGa_Richsection.rb
                      can not convert nil into String
                      ca you please help me?
                      • B
                        bimbachi
                        hello,
                        after install via skechucation plugin store on mac sketchup
                        • when starting skp. i'm geting this rubby error messge
                        "Error Loading File PiGa_RichSection.rb
                        can't convert nil into String"
                        can you advice?
                        • B
                          bimbachi
                          @pgarmyn said:
                          @bimbachi @diegob
                          It must be a MAC related problem, you are both running on MAC ?
                          Any other Mac users with problems ❓ ❓ ❓ ❓ ❓
                          I have no explanation. For me it works on SU8 and SU2013. But i can't test it on mac.
                          Can you test the following : disable all the other plugins ❓
                          If this doesn't help, can you test the following file : replace PiGa_RichSection.rb (in directory ..SketchUp..\Plugins) by the file below, and tell me if it works ❓
                          Thanks in advance.
                          @pgarmyn
                          done what you adviced
                          & no more error on app startup
                          but ...
                          at short test looks like that it is not working (add new section result nothing)
                          • P
                            pgarmyn
                            @Bimbach
                            Done as advised? What did you do : Uninstalled plugins, other file installed, or both?
                            RichSection only creats sectionfaces for groups that produce a closed section.
                            Did you activate the extension in 'preferences' ?
                            Is there a menu in plugins/RichSection?
                            Open the ruby panel : what is printed in the ruby-panel?
                            • F
                              floffy1983
                              It looks like my wish-list plugin, but i cannot get it to load.
                              If it helps, i am stuck with the Italian SU8 on a partially locked down office pc, partially as i can install plugins but can't update.
                              • F
                                factopedia
                                Thanks so much.
                                • P
                                  pgarmyn
                                  @floffy1983
                                  What system (mac/windows) ? what version ?
                                  Please complete your profile. This can help me to find a solution for you?
                                  • P
                                    pgarmyn
                                    @factopedia said:
                                    Thanks so much.
                                    Glad you like it 😄
                                    • F
                                      floffy1983
                                      Sorry, you are perfectly right.
                                      I am working on a windows xp machine, pentium 4, 2gb.
                                      I weep daily for its lack of power, but alas, my place of work will not let me bring my own laptop.
                                      • C
                                        cilemomax
                                        Can you help me with something? how do I uninstall it. I deleted it but every time I start up the program it gets an error saying it's trying loading the file. Thanks in advance
                                        • B
                                          bimbachi
                                          @pgarmyn said:
                                          @Bimbach
                                          ok (following on mac issue)
                                          1./ as adviced I replaced only the file you forwarded "PiGa_RichSection.rb"
                                          2./ then no more loading error on startup
                                          3./ than RichSection is in the palet and plugins menu
                                          4./ than when clicking or choosing from menu - "create richsection" in rubby panel there is:
                                          "Error: #<TypeError: can't convert nil into String>
                                          (eval):917:in +' (eval):917:in l_ctrl'
                                          (eval):1466:in createRichSectionTool' (eval):4353:in require'
                                          (eval):917:in `call'
                                          (eval):917"
                                          • L
                                            lcarlin247
                                            It just does not work to me, i create the section but the paremeters do not appear, not even by using the paremeters icon
                                            any advice? i use skp 2013
                                            • 19
                                            • 20
                                            • 7 / 20
