    Title Blocks
    6 Posts 3 Posters 745 Views 3 Watching
      archjjg
      Hey All,
      Trying to figure out how to create a title block (most likely in the top view) and use it with an isometric design thats in a 3D view. Not sure on how to combine these & make it work properly.
      Thanks in advance.
        The best way to do this is to use LayOut. There you can make proper title blocks.
        • JQLJ Offline
          JQL
          Or go to window > styles > watermark and place a new image overlayed on the current scene and positioned where you want on screen. Then you can do one of 2 things:
          1 - Use a new image for any new title block you want
          2 - Use a leader text placed on a blank screen area to make a floating text that populates the title block.
          www.casca.pt
          Visit us on facebook!
            archjjg
            Dave R & JQL...thanks for your comments, I'll give them a try.
              archjjg
              Finding the premade title blocks in LayOut is just what I was looking for. I'm sure that there has to be a way to edit the existing text in those title blocks that I'm just not seeing.
                Yes. there is. The layer(s) are probably locked so you need to unlock them first by clicking on the padlock icons in the Layers inspector. Then you can double click on the text box and edit to your heart's content.
