    Curved Staircases
    171 Posts 19 Posters 54.1k Views 19 Watching
      Garry K
      I now have language translation working. There is a folder called translations and currently there are 4 files in it.
      en.lang - English
      fr.lang - French
      ru.lang - Russian
      zh.lang - Chineses ( traditional )
      Near the top of the defaults.txt file there is a language= section where you can enter the 2 character language code. If you leave the language= blank the system will try to figure out the locale code.
      These language files are straight translations and as a result there might be some funny and or inappropriate translations.
      Anyone interested in helping out with any language translation can get a hold of me.
      French Stair Maker
      Russian Stair Maker
      Chinese Stair Maker
        Garry K
        A user with a windows 8 machine running SU 2013 has reported an error that I can't duplicate ( I don't have a windows 8 machine )
        puts "starting: dialog.execute_script( js_command )"
        this code doesn't run
        puts "finished: dialog.execute_script( js_command )"
        it errors out with this
        type: mismatch
        code: 0
        url: file:///C:/Users/Admin/AppData/Local/Temp/skp8C34.tmp
        Is there anyone else with a Windows 8 machine running 2013 who would be willing to try this code.
        ` require 'sketchup.rb'
        show_dialog
        def show_dialog()
        dlg = UI::WebDialog.new( "Stair Measurements", false, "DialogTest", 200, 150, 150, 150, true );
        dlg.add_action_callback( "ruby_callback" ) { |dialog, params|
        text = params.to_s
        	if( text == 'loaded' )
        		args =  'inside_stringer=Housed|Sawtooth|None' +
        				'&inside_stringer=1' +
        				'&inside_option=Has Heel|Has Foot|Both|None' +
        				'&inside_option=3' +
        				'&inside_thickness=60' +
        				'&inside_width=300' +
        				'&inside_rail=Guard Rail|Wall Rail|None' +
        				'&inside_rail=2' +
        				'&outside_stringer=Housed|Sawtooth|None' +
        				'&outside_stringer=0' +
        				'&outside_option=Has Heel|Has Foot|Both|None' +
        				'&outside_option=3' +
        				'&outside_thickness=60' +
        				'&outside_width=400' +
        				'&outside_rail=Guard Rail|Wall Rail|None' +
        				'&outside_rail=2' +
        				'&total_rise=2667' +
        				'&risers=15' +
        				'&riser_thickness=12.7' +
        				'&direction=Clockwise|Anti Clockwise' +
        				'&direction=1' +
        				'&stair_width=1000' +
        				'&radius=2400' +
        				'&degrees=90' +
        				'&floor_thickness=60' +
        				'&rail_style=Classic|Modern|Round|Square|Standard|Traditional' +
        				'&rail_style=4' +
        				'&tread_thickness=38' +
        				'&average_run=254' +
        				'&tread_bullnose=12.7' +
        				'&nosing=25.4' +
        				'&flare_amount=0' +
        				'&progressive_flare=20' +
        				'&flare_count=0'
        		js_command = "from_ruby( '" + args + "' )"
        		puts( js_command )
        	else
        		UI.messagebox( text )
        		puts( text )
        dialog.close();
          html = <<-HTML
        <!DOCTYPE html>
        <html>
        <style type="text/css">
        body { background-color: #F9EBD1}
        fieldset { float: left; background-color: #F9EBD1; border-color: black; margin: 3px;}
        fieldset p {display: table-row;
        font-family: Arial, Helvetica, sans-serif;
        font-size: 90%;
        color: black;
        height: 27px}
        fieldset input,
        fieldset select,
        fieldset label {display: table-cell; margin: 2px; width: 120px }
        fieldset label {text-align: right;}
        fieldset input,
        fieldset select {margin-left: 10px; background-color: wheat;}
        </style>
        <head>
        <meta http-equiv="MSThemeCompatible" content="Yes">
        <script>
        function do_click()
        var items = document.getElementsByTagName( '*' );
        var count = items.length;
        var text = "";
        for ( var i = 0; i < count; i++ )
        if ( items[i].type == "select-one" )
        value = items[i].options[items[i].selectedIndex].value;
        else if ( items[i].type == "text" )
        value = items[i].value;
        else if ( items[i].type == "checkbox" )
        value = items[i].checked.toString();
        else
        value = "";
          if ( value.length > 0 )
        	  if ( text.length > 0 )
        		 text += "&";
        	  text += ( items[i].id + "=" + value );
        ruby_call( text );
        function from_ruby( data )
        var element;
        var pair;
        var pairs = data.split( '&' );
        var count = pairs.length;
        	pair = pairs[i].split( '=' );
        	element = document.getElementById( pair[0] )
        	if ( element.type == "select-one" )
        		if ( pair[1].indexOf('|') == -1 )
        			element.selectedIndex = pair[1];
        		else
        			populate_drop_down( element, pair[1] );
        	else if ( element.type == "text" )
        		element.value = pair[1];
        	else if ( element.type == "checkbox" )
        		element.checked = pair[1] == '1';
        function populate_drop_down( element, data )
        var options = data.split( '|' );
        var count = options.length;
        var option;
        element.innerHTML = "";
        	option = document.createElement( "option" );
        	option.text = options[i];
        	element.add( option, null );
        function ruby_call( text )
        query = 'skp:ruby_callback@' + text;
        window.location.href = query;
        function on_load()
        ruby_call( 'loaded' );
        </script>
        </head>
        <body onload="on_load()">
        <form>
        <fieldset>
        <p><label>Inside Stringer:</label><select id="inside_stringer"></select></p>
        <p><label>Options:</label><select id="inside_option"></select></p>
        <p><label>Thickness:</label><input type="text" id="inside_thickness"</p>
        <p><label>Width:</label><input type="text" id="inside_width"</p>
        <p><label>Rail Options:</label><select id="inside_rail"></select></p>
        </fieldset>
        <fieldset>
        <p><label>Outside Stringer:</label><select id="outside_stringer"></select></p>
        <p><label>Options:</label><select id="outside_option"></select></p>
        <p><label>Thickness:</label><input type="text" id="outside_thickness"</p>
        <p><label>Width:</label><input type="text" id="outside_width"</p>
        <p><label>Rail Options:</label><select id="outside_rail"></select></p>
        </fieldset>
        <fieldset>
        <p><label>Stair Direction:</label><select id="direction"></select></p>
        <p><label>Stair Width:</label><input type="text" id="stair_width"</p>
        <p><label>Radius:</label><input type="text" id="radius"</p>
        <p><label>Degrees:</label><input type="text" id="degrees"</p>
        <p><label>Rail Style:</label><select id="rail_style"></select></p>
        <p><label>Open Risers:</label><input type="checkbox" id="open_riser"</p>
        <p><label>Total Rise:</label><input type="text" id="total_rise"</p>
        <p><label>Risers:</label><input type="text" id="risers"</p>
        <p><label>Riser Thickness:</label><input type="text" id="riser_thickness"</p>
        </fieldset>
        <fieldset>
        <p><label>Tread Thickness:</label><input type="text" id="tread_thickness"</p>
        <p><label>Average Run:</label><input type="text" id="average_run"</p>
        <p><label>Tread Bullnose:</label><input type="text" id="tread_bullnose"</p>
        <p><label>Nosing:</label><input type="text" id="nosing"</p>
        <p><label>Flare Amount:</label><input type="text" id="flare_amount"</p>
        <p><label>Progressive Flare:</label><input type="text" id="progressive_flare"</p>
        <p><label>Flare Count:</label><input type="text" id="flare_count"</p>
        <p><label>Floor Thickness:</label><input type="text" id= "floor_thickness"</p>
        <p><label>Create Stair:</label><input type="button" onclick="do_click()" style="background: silver" value="Ok"></p>
        </fieldset>
        </form>
        </body>
        </html>
          HTML
          dlg.set_html html
          dlg.show
        if ( not file_loaded?( "dialog_test.rb" ) )
        UI.menu( "Plugins" ).add_item( "Web Dialog Test" ) { show_dialog() }
        file_loaded( "dialog_test.rb" )
          Garry K
          Version 1.0.11 06-Mar-2014
          1. Now SU 2014 compatible
          2. Added missing line to gkware_stairmaker_loader.rb. Utils.rbs was only loading if door maker was installed.
          3. Added Config folder to hold user configuration and temp files
          4. Make button images for add Handrail profile and glue edges
          5. Fixed bug in handrail scaling
          6. Auto Sizing of Web Dialog. For some reason – need to add room for scroll – even if it shouldn’t be needed
          7. Fixed bug where trial string keeps growing
          8. Handrail was not going into “Handrail” layer. Fixed
          9. Changed Stringer “Width” to “Depth” in web dialog, language files and in defaults.txt
          10. Made changes to defaults.txt for “imperial_stair_width”
            aconk25
            error in windows 8 64bit
              mwm5053
              You might want to add .rbz to post or transfer this to plugins forum it's hard to find the file embedded in the middle of topic I can't find maybe I missed it somewhere.
              2011 iMac
              SU 2015 Pro, 2017 Make
              V2 Twilight
              macOS Sierra 10.12.5
                Garry K
                I've been busy learning about JQuery, Ajax, JSONP etc.
                Here are 2 ruby scripts that I would like someone to try on OSX Lion, OSX Maverick and Windows 8.
                The first script is called 'dialog_test_tabs.rb' and is set up with tabs. The tabs code came from user NewOne
                http://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=22662
                This works nicely on my machine which is a Windows 7 machine. I have Internet Explorer 11 installed.
                The second script is call dialog_test_5.rb and connects to a test web service on my web site. It just passes a very simple JSONP record {"firstname":"Jeff"} and is suppose to respond with 'Your name is Jeff Hansen'
                Tabbed test dialog
                Web service test script
                  pisosse
                  Well i'm on SU2014 and yosemite
                  First of all I still get the "HTTP error"
                  That is very well the reason I get these outputs of your test files.
                  Dialog 5 output
                  Dialog tab output
                    pisosse
                    Installed via the sketchucation plugin and all is good.. Just wonder what to do if stringers have different curvatures ?
                      Garry K
                      Do you have an example of what you mean by different curvatures?
                      My understanding so far is this.
                      Curved stringers do have different curvatures (radius), but they both have the same pivot point. The best I can do right now for irregular stairs is the 2D to 3D portion of the stair maker suite.
                        pisosse
                        Ahh.. ok thanks. Would I mean is that the stringers is curved but not in parallel. On stringer has a sharper curve than the other. Btw. the 2D to 3D feature sounds promising but the documentation in the help file is leaving me a little puzzled. Should I make 2 stringers as pollens and the select them an push the 2Do3D button or do I have to make a face? sorry this is totally obvious to other than stupid old me. Other than that it is a pretty solid piece of coding sir!
                          Garry K
                          I have a few videos on the 2D to 3D stairs.
                            pisosse
                            NICE.. thanks a lot!
                            • 9 / 9
