    Between different Macs plugin works and doesn't work
    48 Posts 6 Posters 2.3k Views 6 Watching
      Garry K
      Jeff and Walt
      I changed this based on what TIG said.
      Please try it
      modified dialog_test.rb
        mwm5053
        This is what I get Garry
        2011 iMac
        SU 2015 Pro, 2017 Make
        V2 Twilight
        macOS Sierra 10.12.5
          Garry K
          Just to be sure - you downloaded the latest dialog_test.rb and line 10 now says:
          @dlg.allow_actions_from_host( 'cabmaker32.com/' );
            mwm5053
            Yes Garry I deleted the other one and installed the the new one.
            2011 iMac
            V2 Twilight
              slbaumgartner
              Trailing slash not needed. Just 'cabmaker32.com'
                Remove the final / in the domain name. 😕
                  Garry K
                  Jeff and Walt
                  I have now removed the trailing slash from cabmaker32.com on line 10
                  Maybe this will work.
                  Please try it
                  cleaned up the domain address
                    mwm5053
                    Got the same error, sorry wish I could be of more help
                    2011 iMac
                    V2 Twilight
                      slbaumgartner
                      Walt,
                      Do you have the WebKit inspector activated? If not, please open a Terminal window and type
                      defaults write <bundleid> WebKitDeveloperExtras -bool true
                      where you replace <bundleid> with:
                      com.google.sketchupfree8 for v8 Free
                      com.google.sketchuppro8 for v8 Pro (what your info says you have)
                      com.sketchup.SketchUp for 2013
                      After doing that, please run Garry's test script and while the WebDialog labeled "connect to website" is still open, right-click on it and select "Inspect Element" from the popup menu. This will open the WebKit Inspector. The GUI of the WebKit Inspector has changed with version, but look for something labeled "Console" and click it. Please let us know if the Console displays any error or warning messages.
                      Steve
                        mwm5053
                        @ Steve When I right click in Connect to Website all I get is "Reload" but this is what Terminal looks like after pressing return in terminal was that right?
                        2011 iMac
                        V2 Twilight
                          slbaumgartner
                          The Terminal screenshot looks as if you left off part of the command. Did you type the entire line
                          defaults write com.google.sketchuppro8 WebKitDeveloperExtras -bool true
                          I forgot to mention that before entering this command you should quit SketchUp and restart it afterward. Until the default takes hold the right-click menu will only contain "Reload".
                          Steve
                            mwm5053
                            I double checked the terminal and retyped and restated SU still no right click web inspector?
                            2011 iMac
                            V2 Twilight
                              slbaumgartner
                              Missed it again! You typed com.google.sketchup8pro, it should be com.google.sketchuppro8
                              Steve
                                mwm5053
                                2011 iMac
                                V2 Twilight
                                  mwm5053
                                  I don't understand why right click won't bring up Inspect Element?
                                  2011 iMac
                                  V2 Twilight
                                    slbaumgartner
                                    Still typing the command wrong!
                                    t space between Extras and -bool
                                    [edit] Ack, that didn't format right! You left the t out of Extras and attached the - to its end instead of to the front of -bool.
                                      mwm5053
                                      Ya not a very good typist sorry is this right
                                      2011 iMac
                                      V2 Twilight
                                        slbaumgartner
                                        That appears to be right. Did it work?
                                        I'm turning in for the night in a minute. Will check back tomorrow.
                                        Steve
                                          mwm5053
                                          still no inspect element on right click
                                          2011 iMac
                                          V2 Twilight
                                            mwm5053
                                            Ok this AM I had Safari open with Inspect Element open on a web page just to see what it did and opened SU and clicked on Web Dialog Test and right clicked on Connect to Website and Web Inspector popped up with this. Now what? I'll be here for a while then off to work for the day will check back.
                                            Walt
                                            2011 iMac
                                            V2 Twilight
                                            • 3 / 3
