    Import A Cut List
    20 Posts 4 Posters 938 Views 4 Watching
    • V Offline
      Vigy
      Hi all;
      Can anyone help me Please!
      I'm looking for a CSV or XLS Cut List importer, I tried "cloud_v8b" but I couldn't make a simple components list to import into my SU scene. I would like to have each line imported as a separate group, here is a sample of my list..
      ID LAYER X Y Z
      A Layer0 20 10 0.75
      B Layer0 5 5 0.75
      C Layer0 10 10 1
      Vigy.
        That's an interesting idea. I don't know of a plugin to do that. How do you determine where the groups wind up in the model? Or do you plan to have them all dropped at the origin and then you'll move them around to assemble the model? I guess I can't really visualize how that would work.
        • V Offline
          Vigy
          Yes Dave, all dropped at the 0 origin is perfectly fine, I'm trying to import a Cut Rite program part list and then assemble it in SU.
            slbaumgartner
            Are all the parts simple rectangular boards? If so, it shouldn't be at all hard to write a Ruby to import them. If not, I'd need more info regarding what other shapes are possible - are there curved pieces? is there joinery on the ends? etc. Rapidly gets much more complicated.
            Unless there aren't very many parts, piling them on top of each other at the origin would make it pretty awkward to grab them for assembly. I'd think it would be easier if they were separated, even though that would take up more space initially.
            Steve
              hmmmm..... It does indeed sound like it would be very awkward to work with all of those groups dropped at the origin. I'd be interested in seeing what you're starting with to get the Cut Rite file.
              • V Offline
                Vigy
                Dave,
                As long my parts are named it's no problem to dropped at the origin. but it would be nice to have them separated
                • V Offline
                  Vigy
                  Steve, thanks for your response!
                  My priority is to have simple rectangular boards, but I never wrote anything in Ruby so it's not that simple for me. and yes it would be nice to have them separated (I didn't want to complicate things)
                  Victor
                    Once you have all these groups in SketchUp are you planning to then assemble the parts into a cabinet or something?
                    • V Offline
                      Vigy
                      Yes indeed, and also detect if anything is programmed wrong.
                        I see. Well, maybe one of our resident Ruby gurus will come up with something for. I must say I'm happy I don't have to build SketchUp models that way. It's a lot of work rearranging the parts. It makes me wonder if it might not be more efficient to build the model from Scratch in SketchUp and export a cutlist you could compare to the one from Cut Rite. I'm thinking with a few overall dimensions, you could model a cabinet pretty quickly.
                        • V Offline
                          Vigy
                          Well Dave, I do most of my models from scratch, and I make them to dynamic components as well, but I have some old Cut Rite programs with lots of parts and would like to review them in SU.
                            Understood.
                              slbaumgartner
                              Victor
                              I'll take a shot at it when I get a chance. Do you have a sample file you could upload?
                              Steve
                              • V Offline
                                Vigy
                                Hi Steve,
                                Attached a sample.
                                Thanks so much, Victor
                                Import A Cut List.zip
                                  slbaumgartner
                                  @vigy said:
                                  Hi Steve,
                                  Attached a sample.
                                  Hi Victor,
                                  Give the attached a try and let me know what happens. Put the rb file into your Plugins folder. It should add an item named "Import Cut List" to the Plugins menu in SketchUp.
                                  This is written to import a csv, not an xlsx, so you will need to save your cut list that way first. xlxs is just way messier than csv, so I took the easy way.
                                  This creates Components, not Groups, and spaces ComponentInstances out along the green (y) axis. I found that piling them all at the origin was hopelessly messy!
                                  This ignores the material field (because there is not enough info to create a material). It also generates only quantity 1 of each part, though that could be changed fairly easily. All your examples were on Layer0, so I didn't co anything to create layers or place things on them. That also could be changed easily enough.
                                  Steve
                                  importcutlist.rb
                                  • V Offline
                                    Vigy
                                    OOOH WOW! This is wonderful Steve, and it work great. Thanks a million! 😍
                                    As you mention, material not needed but layers would be nice if I'm allowed to have audacity to do so. 😳 😳
                                      slbaumgartner
                                      Try this one! It should handle layers (I hope πŸ˜‰ )
                                      Another word of warning: For simplicity, I didn't process the header line to find out what is in which column, so if you rearrange things this plugin will fail in strange ways!
                                      Steve
                                      importcutlist.rb
                                        Jim
                                        Well, you wouldn't need to import anything into the model. The imported components could populate the Components dialog for manual placement after the import.
                                          slbaumgartner
                                          True! That would handle cases with quantity greater than one too - just pull out however many you need (you can do that with my version too, since the components are there). I just followed the workflow Vigy requested.
                                          Steve
                                          • V Offline
                                            Vigy
                                            Steve, It all work very well πŸ‘
                                            Thanks Again!
                                            Victor
