    [Plugin][Code]SKMtools,Material/ImageTools
    178 Posts 37 Posters 308.9k Views 37 Watching
    • B
      Ben Ritter
      TIG,
      Thank you for your generosity.
      What am I doing wrong? I imported a .png and implement image trimmer, but I don't see anything different about it once the process is completed.
        Number of possible issues...
        Any messages in the Ruby Console ?
        Do you have Java installed/enabled - it's need to run the JARDs that manipulate the files etc...
        Do you have .JAR files set to open/execute in Java [their default] - some compression apps can hikack that filetype and so open it instead - change it back to the default.
        ImageTrimmer needs a PNG image with an alpha-layer - that is a transparent background, but with other pixels 100% solid.
        In Gimp or a similar image-editor...
        Flatten the PNG image, then add the alpha-layer back, select the background's color [usually white or black] with a magic-wand and delete, so its now transparent.
        Make sure the image is cropped tight to minimize the amount of trimming needed by the tool.
        Export back as the PNG.
        Re-Import and retry...
        If you are still having problems post the PNG image so we can look at it directly.
          I think I might have found a glitch... watch for updates...
            @Ben
            You were right !
            There was a silly typo in the revised ImageTrimmer code I hadn't trapped...
            Here's a link to the update http://sketchucation.com/forums/viewtopic.php?p=293677#p293677
            It's updated in the PluginStore too...
            • B
              Ben Ritter
              TIG,
              Still no results. PNG image attached.
              Ruby Console:
              Error: #<Errno::ENOENT: No such file or directory -
              Thanks.
                Works for me. πŸ˜•
                Although you haven't flattened the PNG and re-added an alpha channel, it works after a fashion...
                As has been explained several times regarding different issues...
                You cannot have' non-ASCII characters' in the file name or paths that need to be processed by SketchUp's Ruby version [on PC]...
                It's a known PITA.
                So if your SKP is saved in a folder path containing even one tiny accented character - then it will fail to complete.
                What is your folder path ?
                The Image's name is OK, but if there's a rogue "ΓΆ" [or similar] in there, then it'll fall over !
                What is your OS / version - your User Profile is incomplete...
                  There was a minor typo in the loader .rb's name...
                  Making it non EW compliant. πŸ˜’
                    There has been some reworking of syntax to future-proof the code.
                    Here's the update.
                    Get the latest version from the SCF PluginStore
                    http://sketchucation.com/resources/pluginstore?pln=SKMtools
                    • N
                      nasos.slab
                      hey there, i did download the plugin and it comes up as skmtools_v20131214.rbz i did put in my plugins folder but is nowhere to be seen in Sketchup
                      any ideas ?
                      Thank you in advance nasos
                        You didn't install the plugin. Take the .rbz file out of the Plugins folder and put it back in your Downloads folder or something. Open SketchUp and go to Preferences>Extensions. Click on Install Extension. Navigate to where you saved the .rbz file and select it. Click Open...
                        Before you do any of that, make sure you have properly set the permissions for the Plugins folder. See TIG's thread at the top of the Plugins forum.
                        Please complete your profile with SketchUp version and OS. Thanks.
                        • N
                          nasos.slab
                          Hello Dave and thank you for your prompt reply !
                          I have opened Sketchup and went to Preferences>Extensions but there is no such thing as Install extension.
                          Any ideas ?
                          Am on MAC os 10.7.5 and Sketchup pro 7
                          Thank you !
                            See? There's a perfect reason to have your profile filled in before asking questions. Maybe we could use you as a "poster child" for filling in profiles. πŸ˜„
                            So with version 7 you wouldn't have the Install Extension option. In that case you get to do it the hard way. Change the .rbz extension to .zip, then double click on the file name. You should get a folder of the same name. Open that folder and select the contents. Hit Command-C to copy them. Navigate to the Plugins folder and press Command-V to paste the files. The files must be in exactly the same structure as when you copied them.
                            I don't think the Sketchucation Plugin Store will do you any good either because SU7 can't do anything with .rbz files. That came with SU8M2.
                            Maybe you ought to look at upgrading to SU2013 Pro.
                            • N
                              nasos.slab
                              I think you should use me as a "poster child" !
                              πŸ˜‰ thanks a million
                              It worked ! And sure i have to look in upgrading to SU2013 Pro ... but me being blonde and all, with regards to all my plugins, after the upgrade, do i have to manually transfer them or do they transfer themselves ?
                                I'm glad that worked for you.
                                When you upgrade, don't copy the plugins over. Just download fresh to make sure you've got the most recent versions of them. Get the SCF Plugin Store and install it first. That'll make installing others you've gotten here painless.
                                • N
                                  nasos.slab
                                  Thank you again for your time Dave !
                                  And one last question, am trying to find a plugin that could either convert a scanned pdf plan to a dxf format, alternatively a plugin that I could use to automatically trace over a scanned pdf or jpeg, without having to go around redrawing on top of the imported image.
                                  Any suggestions ?
                                    Happy to help.
                                    I don't know of any SketchUp plugins to do that but there are a number of raster to vector programs that could take an image from your PDF and create a DXF or DWG file. Do a Google search for 'raster to vector'. It might be that Photoshop or Illustrator could do that directly from a PDF file but I'm not that familiar with them.
                                      ssw
                                      Just tried to autoinstall this plugin using the sketchucation store plugin and it doesn't install. Nothing in my toolbars and no skmtools.rb in the plugins folder.
                                      Any help appreciated, thanks
                                        So you aren't finding Image Trimmer in the Tools menu nor Image Animator in the Toolbars list?
                                        What version of SketchUp? What operating system? Please complete your profile and give some useful information to help diagnose the problem.
                                          ssw
                                          No Image Trimmer in the Tools menu nor Image Animator in the Toolbars list nor skmtools.rb in the plugins folder.
                                          When I attempt to autoinstall with the sketchucation plugin, SU askes if I want to install plugin and I click "yes". Then the User Account Control asks if I want to allow Extended Copy Utility to make changes. I click "yes", then get the rotating blue circle for a few seconds. But the plugin isn't installed.
                                          Operating system is windows 7, SU is free version 8.0.16846
                                          Will update user profile
                                          Thanks for your help
                                            If you download the RBZ from the PluginStore and try to install it using Preferences > Extensions > Install... button what happens ?
                                            http://sketchucation.com/pluginstore?pln=SKMtools
                                            What is this 'User Account Control asks if I want to allow Extended Copy Utility to make changes...'
                                            Do you have admin powers ?
                                            Do you have SketchUp set up under Properties > Compatibility set to 'run as administrator' ?
                                            Do you and all others listed under Properties > Security have FULL permissions to read/write files in the Plugins folder ?
                                            There's a Tutorial on setting these up properly...
                                            Are there any 'SKM' files or subfolder in your Plugins folder ?
                                            To find the folder use the SketchUcation submenu item...
                                            • 4 / 9
