    [Plugin][$] 3D Tree Maker - New version 1.10.14
    322 Posts 79 Posters 164.3k Views 79 Watching
    • lele_poggiL Offline
      lele_poggi
      I have the same problem of Bob James with Sketchup 2013.
      What can I do?
      gsa | Gabriele Sacchi architetto
      http://www.gs-a.it
      • ppoublanP Offline
        ppoublan
        Hi "lele_poggi",
        I need to understand if its due the
        • the setup of the plugin that was incomplete
        • or the configuration (I introduced locale language support)
        • or other bug in the code.
          Please provide :
        • the platform you are using (Mac/Windows)
        • the way you setup the tool (using auto install from skecthucation or rbz extenstion installation or zip).
        • the error message you got when you start SU or when you run the plugin
        Then if you could open the ruby console, type the following and provide the result
        • Sketchup.find_support_file("Plugins", "")
          Then please provide the listing of files and dirs found at this path
          -> this to be sure the plugin has been setup correctly
        • Type into the ruby console : Sketchup.get_locale
          -> It may be linked to the new support of different languages, maybe I need to add code when unsupported language platform
          Yours
          Pascal
        • JBJDesignsJ Offline
          JBJDesigns
          Awesome plug-in! Thank you!!! πŸ˜„
          ...you send them to school, you give them books, and they eat the pages...
          • micioneM Offline
            micione
            Small problem:
            After rendering of a tree (with Thea or Renditioner),
            the tool no longer displays the other trees. (They appear only
            hidden geometry if enabled).
            To make it appear, you must follow the procedure
            indicated in the attached images.
            • ppoublanP Offline
              ppoublan
              Thanks micione to report this issue and the work around.
              I will make tests with Thea Render and let you know if I can find how to fix it in the code.
              PS : you can also force tree redraw or proxy redraw with the right clic menu on the tree (without opening the configuration window).
              Yours
              • OxerO Offline
                Oxer
                Thanks for the update this incredible plugin!! πŸ‘
                I installed it on Mac OSX 10.9.1 & SU 2013, the toolbar icon and plugin menu appear, when you push the toolbar icon a "New Tree" popup window appears, I select a Tree Type and I push OK but nothing happens, the Ruby console is empty.
                I have done the Spanish Language Translation, if you want I can send it you by PM.
                • Bob JamesB Offline
                  Bob James
                  I use the "additional plugin locations" plugin and installed Tree Maker in my additional location. Tree Maker is one of those plugins that need to be in the default location. When I moved it to the default directory, it worked fine.
                  • ppoublanP Offline
                    ppoublan
                    Hi James,
                    thanks for the info. I need to have a look at the "additional plugin locations" to see if I can make the code work with this tool.
                    Gabriele -> are you using the same additional plugin ?
                    • ppoublanP Offline
                      ppoublan
                      Oxer,
                      After clicking OK in the new tree window, move the mouse over other objects or near the origin of the model, or in the bottom part of your SU window and left clic.
                      I have this issue that when your mouse is pointing very far away from the camera, the lines used to draw the preview tree before it is actually placed into you model are not displayed.
                      But when clicking somewhere into your model the tree should be built.
                      Yours
                      Pascal
                      PS : yes of course I'm really interested in a translated version in other language. Looks like you discovered how to do it. If you could send me the file in order to integrate it into the package. You will receive a license key in exchange πŸ˜‰
                      • OxerO Offline
                        Oxer
                        I done that you say me but it doesn't work. I have uninstalled the rest of the plugin (conflict possibility) but it continues the problem. The Plugins folder's and the 3darcstudiotree folder have full permissions.
                        Do have other Mac users the same problem?
                        Mac OSX 10.9.1 & SU2013
                        PS. I sent you the Spanish Language file by PM.
                        EDIT: I have opened a old personal vine tree (previous version) and the Configuration Tree through Contextual Menu (right click with tree selected) works. It appears this text in Drescription Tree: "tree converted from old " but all work fine.
                          Lee05
                          Installed new version from Plugin Store, got an error.
                          • ppoublanP Offline
                            ppoublan
                            Hi Lee05,
                            Currently 3D Tree Maker can only be setup into the Plugins folder of Sketchup, and cant be installed in other directory with AdditionalPluginFolders.
                            Seems the same issue than Bob James
                            see http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=52540%26amp;start=150#p509692
                            Yours
                            Pascal
                            • ppoublanP Offline
                              ppoublan
                              Oxer,
                              As I understand, you correctly got the new tree webdialog.
                              Then you select a tree and clic on "Ok"
                              Here nothing happens.
                              Then if you clic somewhere on the model(do not clic escape or another toolbox at this time as it will exit from tree tool and go back to the other tool) to place the tree, still nothing drawn.
                              Does the Sketchup status text (on the left bottom) display a message from Tree Maker, like "Clic to place tree, Esc to cancel" or other message ?
                              Can you confirm when you open the Ruby console before calling "New Tree", that you got no error displayed in the ruby console ?
                              Does not seems to be an installation problem, so maybe I need to make a "debug" version with some logs in this case, but I will need a little time to prepare this.
                              • ppoublanP Offline
                                ppoublan
                                Oxer,
                                I made a test on my PC changing show_modal by show, and got the same problem. So I suspect this is linked to the fact that modals webdialog are not working the same on PC and Mac.
                                I will need to get advice from experts on this in the developer forum.
                                Will come back to you as soon as possible.
                                Pascal
                                • OxerO Offline
                                  Oxer
                                  Thanks for the reply!!
                                  I sent you a PM two hours ago but it's in the Outbox still. ❓
                                  • ppoublanP Offline
                                    ppoublan
                                    Oxer, (and Mac Users)
                                    Just published in the Sketchucation Plugin Store a new version that should fix the problem of nothing happens after "New Tree..." webdialog.
                                    But as I have no Mac available, if Mac users may test and give feedback ?
                                    Yours
                                    Pascal
                                    • OxerO Offline
                                      Oxer
                                      Yes, it works now on Mac. πŸ‘
                                      I tried to send you a PM yesterday, but it's in the Outbox still, so I put here the Spanish Language Translation.
                                      These are some strings not included in the original language file
                                      Menu Plugin
                                      License...
                                      Registration Popup window
                                      Unregistered Product
                                      username:
                                      keycode:
                                      unregistered@nowhere.com
                                      UI.messagebox
                                      Waiting...
                                      Working...
                                      Building...
                                      Building tree...
                                      Building tree stems...
                                      Building tree leaves...
                                      Building tree leaves level 1...
                                      Building tree leaves level 2...
                                      Building tree flowers...
                                      Commit...
                                      Tree built.
                                      Building tree proxy...
                                      Commit tree proxy...
                                      Tree proxy built.
                                      Description Tree for trees of previous version
                                        Lee05
                                        Hi Pascal,
                                        the plugin is setup into the Plugins folder of Sketchup, as installed by
                                        plugin store.
                                        Error still the same.
                                        Toni
                                        • ppoublanP Offline
                                          ppoublan
                                          Hi Lee,
                                          Looks like Sketchup does not see the file.
                                          Check the permissions as described here : http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=56005
                                          Could you provide a screen capture of your Plugins/3darcstudiotree directory to check the files are there.
                                          You should have something like this :
                                            Lee05
                                            Hello Pascal,
                                            Here's the print screen. In my opinion the plugin is properly installed.
                                            Toni
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 14 / 17
