    [Plugin][$] 3D Tree Maker - New version 1.10.14
    322 Posts 79 Posters 222.0k Views 79 Watching
    • jiminy-billy-bobJ Offline
      jiminy-billy-bob
      @bob james said:
      [Rendered with Thea Presto 1.3 in 45 seconds!]
      I suggest you check your skybox, the mapping looks weird.
      • Bob JamesB Offline
        Bob James
        Can you help me by explaining what seems "weird"? πŸ˜„
        • FrederikF Offline
          Frederik
          Not sure what jiminy-billy-bob means, but I also find the sky looking strange...
          It's as if you've wrapped a hemi-spherical sky onto a full spherical sky... 😐
          There doesn't seem to be a horizon, making it appear as if the sky is turned half way around...
          The sky in the horizon appears to be skies that are supposed to be right above the scene...
          (Dang - this was tougher to explain than what I thought it would be, but I hope you understand what I mean...)
          EDIT: Just made a quick and dirty test...
          Another thing that makes it appear "weird" is the sun position vs the shadows the trees are casting...
          Please remember that you can adjust the sun to be positioned where the sun is in your IBL... πŸ˜‰
          Cheers
          Kim Frederik
          • ppoublanP Offline
            ppoublan
            New version available that add some features asked in previous messages.
            See first page of this thread.
            Pascal
              Bob James
              Loaded new version. Get error
              • ppoublanP Offline
                ppoublan
                Hi Bob James,
                Did you setup the plugin from the Sketchucation PluginStore or via add extention in SU ?
                Try to quit and restart SU, do you get the same error ?
                It looks like 3DTreeMaker has not been setup in the standard Sketchup Plugins Folder (Plugins Small Set). Could you please provide a listing of files/dir in your standard Sketchup Plugins Folder and list of files/dir in your Plugins/3Darcstudiotree folder ?
                Once SU launched, open the ruby console, type (copy and run) this and provide results of :
                Sketchup.find_support_file("Plugins", "")
                Sketchup.find_support_file("Plugins/3darcstudiotree", "")
                Yours
                Pascal
                PS : does anybody got the same kind of error ?
                After successful installation, footprint of Tree Maker should be:
                in the standard Sketchup Plugins folder - the one returned by Sketchup.find_support_file("Plugins", "") :
                • one added file : 3darcstudiotreeloader.rb
                • one added directory : 3darcstudiotree
                  Beautiful! 😎
                  By the creators of the plugin!
                  http://www.3darcstudio.com/images/master/verdure09.jpg
                  • KrisidiousK Offline
                    Krisidious
                    Interesting pay model... pay to do away with time. I think I like it. Thanks for all the hard work Pascal.
                    By: Kristoff Rand
                    • lele_poggiL Offline
                      lele_poggi
                      I have the same problem of Bob James with Sketchup 2013.
                      What can I do?
                      gsa | Gabriele Sacchi architetto
                      http://www.gs-a.it
                      • ppoublanP Offline
                        ppoublan
                        Hi "lele_poggi",
                        I need to understand if its due the
                        • the setup of the plugin that was incomplete
                        • or the configuration (I introduced locale language support)
                        • or other bug in the code.
                          Please provide :
                        • the platform you are using (Mac/Windows)
                        • the way you setup the tool (using auto install from skecthucation or rbz extenstion installation or zip).
                        • the error message you got when you start SU or when you run the plugin
                        Then if you could open the ruby console, type the following and provide the result
                        • Sketchup.find_support_file("Plugins", "")
                          Then please provide the listing of files and dirs found at this path
                          -> this to be sure the plugin has been setup correctly
                        • Type into the ruby console : Sketchup.get_locale
                          -> It may be linked to the new support of different languages, maybe I need to add code when unsupported language platform
                          Yours
                          Pascal
                        • JBJDesignsJ Offline
                          JBJDesigns
                          Awesome plug-in! Thank you!!! πŸ˜„
                          ...you send them to school, you give them books, and they eat the pages...
                          • micioneM Offline
                            micione
                            Small problem:
                            After rendering of a tree (with Thea or Renditioner),
                            the tool no longer displays the other trees. (They appear only
                            hidden geometry if enabled).
                            To make it appear, you must follow the procedure
                            indicated in the attached images.
                            • ppoublanP Offline
                              ppoublan
                              Thanks micione to report this issue and the work around.
                              I will make tests with Thea Render and let you know if I can find how to fix it in the code.
                              PS : you can also force tree redraw or proxy redraw with the right clic menu on the tree (without opening the configuration window).
                              Yours
                              • OxerO Offline
                                Oxer
                                Thanks for the update this incredible plugin!! πŸ‘
                                I installed it on Mac OSX 10.9.1 & SU 2013, the toolbar icon and plugin menu appear, when you push the toolbar icon a "New Tree" popup window appears, I select a Tree Type and I push OK but nothing happens, the Ruby console is empty.
                                I have done the Spanish Language Translation, if you want I can send it you by PM.
                                  Bob James
                                  I use the "additional plugin locations" plugin and installed Tree Maker in my additional location. Tree Maker is one of those plugins that need to be in the default location. When I moved it to the default directory, it worked fine.
                                  • ppoublanP Offline
                                    ppoublan
                                    Hi James,
                                    thanks for the info. I need to have a look at the "additional plugin locations" to see if I can make the code work with this tool.
                                    Gabriele -> are you using the same additional plugin ?
                                    • ppoublanP Offline
                                      ppoublan
                                      Oxer,
                                      After clicking OK in the new tree window, move the mouse over other objects or near the origin of the model, or in the bottom part of your SU window and left clic.
                                      I have this issue that when your mouse is pointing very far away from the camera, the lines used to draw the preview tree before it is actually placed into you model are not displayed.
                                      But when clicking somewhere into your model the tree should be built.
                                      Yours
                                      Pascal
                                      PS : yes of course I'm really interested in a translated version in other language. Looks like you discovered how to do it. If you could send me the file in order to integrate it into the package. You will receive a license key in exchange πŸ˜‰
                                      • OxerO Offline
                                        Oxer
                                        I done that you say me but it doesn't work. I have uninstalled the rest of the plugin (conflict possibility) but it continues the problem. The Plugins folder's and the 3darcstudiotree folder have full permissions.
                                        Do have other Mac users the same problem?
                                        Mac OSX 10.9.1 & SU2013
                                        PS. I sent you the Spanish Language file by PM.
                                        EDIT: I have opened a old personal vine tree (previous version) and the Configuration Tree through Contextual Menu (right click with tree selected) works. It appears this text in Drescription Tree: "tree converted from old " but all work fine.
                                          Lee05
                                          Installed new version from Plugin Store, got an error.
                                          • ppoublanP Offline
                                            ppoublan
                                            Hi Lee05,
                                            Currently 3D Tree Maker can only be setup into the Plugins folder of Sketchup, and cant be installed in other directory with AdditionalPluginFolders.
                                            Seems the same issue than Bob James
                                            see http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=52540%26amp;start=150#p509692
                                            Yours
                                            Pascal
                                            • 16
                                            • 17
                                            • 8 / 17
