    [Plugin][$] 3D Tree Maker - New version 1.10.14
    322 Posts 79 Posters 247.6k Views 79 Watching
    • ppoublanP Offline
      ppoublan
      Hi James,
      thanks for the info. I need to have a look at the "additional plugin locations" to see if I can make the code work with this tool.
      Gabriele -> are you using the same additional plugin ?
      • ppoublanP Offline
        ppoublan
        Oxer,
        After clicking OK in the new tree window, move the mouse over other objects or near the origin of the model, or in the bottom part of your SU window and left clic.
        I have this issue that when your mouse is pointing very far away from the camera, the lines used to draw the preview tree before it is actually placed into you model are not displayed.
        But when clicking somewhere into your model the tree should be built.
        Yours
        Pascal
        PS : yes of course I'm really interested in a translated version in other language. Looks like you discovered how to do it. If you could send me the file in order to integrate it into the package. You will receive a license key in exchange πŸ˜‰
        • OxerO Offline
          Oxer
          I done that you say me but it doesn't work. I have uninstalled the rest of the plugin (conflict possibility) but it continues the problem. The Plugins folder's and the 3darcstudiotree folder have full permissions.
          Do have other Mac users the same problem?
          Mac OSX 10.9.1 & SU2013
          PS. I sent you the Spanish Language file by PM.
          EDIT: I have opened a old personal vine tree (previous version) and the Configuration Tree through Contextual Menu (right click with tree selected) works. It appears this text in Drescription Tree: "tree converted from old " but all work fine.
            Lee05
            Installed new version from Plugin Store, got an error.
            • ppoublanP Offline
              ppoublan
              Hi Lee05,
              Currently 3D Tree Maker can only be setup into the Plugins folder of Sketchup, and cant be installed in other directory with AdditionalPluginFolders.
              Seems the same issue than Bob James
              see http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=52540%26amp;start=150#p509692
              Yours
              Pascal
              • ppoublanP Offline
                ppoublan
                Oxer,
                As I understand, you correctly got the new tree webdialog.
                Then you select a tree and clic on "Ok"
                Here nothing happens.
                Then if you clic somewhere on the model(do not clic escape or another toolbox at this time as it will exit from tree tool and go back to the other tool) to place the tree, still nothing drawn.
                Does the Sketchup status text (on the left bottom) display a message from Tree Maker, like "Clic to place tree, Esc to cancel" or other message ?
                Can you confirm when you open the Ruby console before calling "New Tree", that you got no error displayed in the ruby console ?
                Does not seems to be an installation problem, so maybe I need to make a "debug" version with some logs in this case, but I will need a little time to prepare this.
                • ppoublanP Offline
                  ppoublan
                  Oxer,
                  I made a test on my PC changing show_modal by show, and got the same problem. So I suspect this is linked to the fact that modals webdialog are not working the same on PC and Mac.
                  I will need to get advice from experts on this in the developer forum.
                  Will come back to you as soon as possible.
                  Pascal
                  • OxerO Offline
                    Oxer
                    Thanks for the reply!!
                    I sent you a PM two hours ago but it's in the Outbox still. ❓
                    • ppoublanP Offline
                      ppoublan
                      Oxer, (and Mac Users)
                      Just published in the Sketchucation Plugin Store a new version that should fix the problem of nothing happens after "New Tree..." webdialog.
                      But as I have no Mac available, if Mac users may test and give feedback ?
                      Yours
                      Pascal
                      • OxerO Offline
                        Oxer
                        Yes, it works now on Mac. πŸ‘
                        I tried to send you a PM yesterday, but it's in the Outbox still, so I put here the Spanish Language Translation.
                        These are some strings not included in the original language file
                        Menu Plugin
                        License...
                        Registration Popup window
                        Unregistered Product
                        username:
                        keycode:
                        unregistered@nowhere.com
                        UI.messagebox
                        Waiting...
                        Working...
                        Building...
                        Building tree...
                        Building tree stems...
                        Building tree leaves...
                        Building tree leaves level 1...
                        Building tree leaves level 2...
                        Building tree flowers...
                        Commit...
                        Tree built.
                        Building tree proxy...
                        Commit tree proxy...
                        Tree proxy built.
                        Description Tree for trees of previous version
                          Lee05
                          Hi Pascal,
                          the plugin is setup into the Plugins folder of Sketchup, as installed by
                          plugin store.
                          Error still the same.
                          Toni
                          • ppoublanP Offline
                            ppoublan
                            Hi Lee,
                            Looks like Sketchup does not see the file.
                            Check the permissions as described here : http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=56005
                            Could you provide a screen capture of your Plugins/3darcstudiotree directory to check the files are there.
                            You should have something like this :
                              Lee05
                              Hello Pascal,
                              Here's the print screen. In my opinion the plugin is properly installed.
                              Toni
                              • ppoublanP Offline
                                ppoublan
                                Hi Lee,
                                I do not understand why the file is not loaded by SU if it exists in the right place.
                                To see what happens from SU, can you run this commande from the Ruby Console :
                                File.exists?(Sketchup.find_support_file("Plugins/3darcstudiotree")+"/3darcstudiotree.rbs")
                                Does it return true ?
                                You can also make a try to run SU as Administrator.
                                Pascal
                                • ppoublanP Offline
                                  ppoublan
                                  [attachment=0:101urpzm]<!-- ia0 -->3darcstudiotreees.txt.zip<!-- ia0 -->[/attachment:101urpzm]
                                  Thanks a lot Oxer for that work and pointing out some strings are missing. I will add them to the code in order to be able to localize them as well.
                                  Yours
                                  Pascal
                                    Lee05
                                    I run command in Ruby Console, it returns true.
                                    SU is running as administrator, error still there.
                                    I've installed home the plugin, here works fine.
                                    Toni
                                    • OxerO Offline
                                      Oxer
                                      I seen a curious plant in the templates, the tree26 πŸ‘ πŸ˜† πŸ˜† πŸ˜† πŸ˜†
                                      • ppoublanP Offline
                                        ppoublan
                                        Toni
                                        hi Toni,
                                        So it works fine now ?
                                        You copied files to Plugins/3darcstudiotree folder to solve it ?
                                        Just want to know if it was a pb of security rights or files beeing in the right folder.
                                        Yours
                                        Pascal
                                          Lee05
                                          Hi Pascal,
                                          3D Tree Maker works fine on computer from home, there I've installed it from SU plugin store, I did'nt change anything, just leave it how installed itself.
                                          On my office computer I still get that error. SU runs as administrator, everything is at it's place and security settings are the same as for all other plugins.
                                          When running the command in ruby console returns true also.
                                            Have you read and fixed things as this?
                                            http://sketchucation.com/forums/viewtopic.php?p=508319#p508319
                                            Also your SketchUp installation path looks a bit 'non-standard' ?
                                            Did you allow the SketchUp-installer to choose the path or did you 'customize' it ?
                                            To check where SketchUp thinks Plugins should be and where they are please type or copy+paste these lines of code in the Ruby Console + <enter>
                                            p = Sketchup.find_support_file('Plugins')
                                            should return the path to you plugins folder.
                                            $LOAD_PATH
                                            should return an array of paths, including the same one to the Plugins folder [p].
                                            File.exist?(File.join(p, '3darcstudiotree'))
                                            should return true if that folder exists in Plugins.
                                            File.exist?(File.join(p, '3darcstudiotreeloader.rb'))
                                            should return true if that file exists in Plugins.
                                            πŸ˜•
                                            • 11
                                            • 16
                                            • 17
                                            • 9 / 17
