    Banked curves on a slide
    25 Posts 7 Posters 4.3k Views 7 Watching
    • BoxB
      If you want more control over the path of the slide, use the middle button of Curviloft.
        Damned Jeff made ones πŸ’š
        With fredoScale πŸ˜„
        Here no need of segmentation : it's automatic by default!
        2 radial bending of 90Β°
        • pbacotP
          Those are great examples Jeff and Pilou! I see you can control overall arc in plan and end profile twist angle.
          Jeff, from your experience what tool would give you the best control in a slide like this to integrate it into a real ergonomic path?
          • jeff hammondJ
            hmm.. rhino? πŸ˜‰
            (simply because any point along the curve is accurate as opposed to only at vertices in a poly modeler.. plus tools to analyze surface continuity/smoothness)
            in reality, both models i drew would be pretty bad to actually slide down because they angle into the ground whereas they should level off at the bottom to prevent a kid from smashing into the ground at high speed.. i think they're acceptable for archViz but that's about it.
            out of those two, the fredoscale/shapebender would be easiest to build because each of those 12 sections ends up being a repeating module where as the curviloft one isn't..
            also in reality, i don't think it would be best to try to design this with a flat bottom which then berms.. it would be both easier to fabricate [edit]no- more difficult[/edit] and probably more functional if the slide's profile were more of a U shaped thing and the centrifugal force pushed you up the side of the slide or you move back towards the bottom of the U as you slow down..
            in which case, to draw it in sketchup, it would probably be best to spend most of the time trying to get a perfect path curve which smooths out to level at the bottom and then using FollowmeAndKeep or 1000bit tools to do the extrusion..
            but now i'm thinking about this way too much πŸ˜„
              I will say Moi for a low price than Rhino πŸ˜„
              And if you have just need "image" you can use the demo infinite of Moi without save ! πŸ˜‰
              With this little free plugin you can past your image of the screen at any size (following your memory card) in the Clipboard and then past it in your 2d favorite program! β˜€
              By Michael Gibson
              Past this script inside Moi Menu Options / Scripts
              Here 2560, 2560 but you can put any thing you want ! πŸ˜‰
              script:var v = moi.ui.getActiveViewport(); if ( v != null ) { moi.view.lineWidth = 4; v.renderToClipboard( 2560, 2560 ); moi.view.lineWidth = 1; }
              Have fun Nurbsing! β˜€
              http://www.polyloop.net/imagehosting/19645d1ca817a94d.jpg
              • jeff hammondJ
                moi isn't bloated enough. I know that's opposite of the sketchup style mantra of keeping things simple but that only goes so far.
                in many regards, feature rich software is way better.. it's just harder to learn or more confusing at first but once you get past that phase, it's a lot better. the key is trying to keep the UI somewhat simple/logical while packing in a lot of functionality and I feel rhino has done a decent job at this. (especially with the mac version.. the latest UI changes have my workspace more simple looking than my sketchup workspace. it can be setup to where basically, the entire screen is a viewport while still having easy access to all function)
                I guess it all depends on what your needs are. and I guess this has gone way off topic but the OP has lots of options to try already (and has disappeared πŸ˜„ )
                • ely862meE
                  ely862me
                  Most likely he ran out of RAM . πŸ˜†
                  Elisei (sketchupper)
                  Come and See EliseiDesign
                    Surely for a super Pro use. πŸ€“
                    • pbacotP
                      U-SHAPED? You just have to take the same shape and run Artisan on it.
                      • jeff hammondJ
                        ha.. yeah, that's one way to go about it.. i was thinking even more of a U..
                        if it's berm_ed, you have to go a certain speed or the thing will dump you out.. if it's a U, the 2yr old can take 5 seconds to make it to the bottom following the path in the middle..
                        the 8yr old can get a running start and dive into it then ride more of the sidewall down.
                        (not trying to sound like some sort of expert playground engineer here πŸ˜† ..just ideas is all)
                        • pbacotP
                          Cool one Jeff. (Does Rhino do that rendering too?) I imagined this was a water slide that could go on forever. Yes, your shape would accommodate the more desirable high speeds!
                          • jeff hammondJ
                            i want to build the U version a lot bigger now and use it for skateboarding πŸ˜„
                            that's actually a display mode which can be used for visually checking surface continuity (or- that's a screenshot. not a rendering)..
                            i just used it in this case as it's quick way to show metal.. but you can draw real-time with the surfaces looking like that which will show how changes affect the smoothness via the visual cue of reflections.
                            • T
                              tjaschicksal
                              Wow, I didn't expect so much replays, thanks for that. I tried curviloft and shapebender/fredoscale.
                              They worked both pretty well, so I tried to make a rollercoaster with a corkscrew which looks alot better then all of my other attempts ^^
                              • jeff hammondJ
                                that looks cool.. glad you picked up some tips in the midst of the off topic stuff. πŸ˜‰
                                • pbacotP
                                  Nice job. It's going to be a wild ride!
                                  Thanks for the note Jeff. Looking forward to seeing a skate park with "THE SLIDE". Call it "Slide Park". Wish I had the time and smarts to learn Rhino. Looks fun.
