    Call to Retina users (for Fredo6 plugins)
    33 Posts 7 Posters 5.7k Views 7 Watching
    • pbacotP Offline
      @fredo6 said:
      @pbacot said:
      I get the following message when I try start ThruPaint
      Could you upgrade to libfredo6 5.5g and FredoTools 1.6g
      I upgraded the above and that removed the error message. I then copied the Lib6Palette.rb at the location shown. Restarted SU. The Thrupaint toolbar does look not any different than before.
      • fredo6F Offline
        @pbacot said:
        Did you go to the default parameters and check the flag for Retina?
        • fredo6F Offline
          @slbaumgartner said:
          Here's a screenshot. As you can see, this affected the button graphics, but not the text. BTW, different models of MacBook Pro Retina have used different GPU chips. In theory at least, that could cause some low-level variations from Mac to Mac...
          I can't do anything for the text from the Ruby side. There is no API for that and apparently the setup of text size in Model Info [Text section] does not do anything for the text drawn from Ruby.
          But since some Retina users get the text in 'normal' size, there may be a way for you to get it as well by playing with some settings. If this is a matter of graphical card or driver, then I am afraid we'll have to wait for the SU Team to address the problem.
          Anyway, I guess this is already a progress to get the buttons bigger, even if the text remains tiny.
          What I need now to do is to make the change for some other graphical elements like the Visual Progress bars, the custom tooltips and some other decoration.
          • pbacotP Offline
            @fredo6 said:
            @pbacot said:
            Doh! Didn't do that!. But I can't find it now. Peter
            • O Offline
              oli_sketch
              Dear Fredo,
              Can you help me?
              .-oli
              • fredo6F Offline
                @oli_sketch said:
                Dear Fredo,
                Can you help me?
                .-oli
                Sorry, I should have said it. Please upgrade to LibFredo6 5.5g before and then copy the Lib6Palette.rb file.
                Do not forget to turn on the flag about Retina Screen in the LibFredo6 Default Parameters.
                • O Offline
                  oli_sketch
                  Hi Fredo,
                  I have installed the 5.6g lib but the same problem appears....
                  thanks.
                  • fredo6F Offline
                    Oli,
                    I realized that on Sketchup 8, there is a problem. So here is a corrected version. Sorry for that.
                    Lib6Palette.rb
                    • fredo6F Offline
                      I made a change to offer the possibility to scale up the button palettes (by a factor 2).
                      ONLY FOR RETINA USERS
                      Would you be be kind to
                      1. Drop the attached file Lib6Palette.rb into the Fredo6_!LibFredo6 subfolder
                        Lib6Palette.rb
                      2. Go to Windows > LibFredo6 Settings... and set the Retina Screen parameter to true (it is at the bottom of the dialog)
                      3. Check with my plugins if the display has improved.
                      4. If possible, post some screenshots so that I can see visually what is going on.
                      @oli_sketch: I still don't understand why you get tiny text whereas other Retina users get normal text size
                      Thanks very much
                      • O Offline
                        oli_sketch
                        Hi Fredo,
                        I´ve installed your file and SU 2013 open it without problems.
                        I show you some screenshots.
                        Thanks.
                        • O Offline
                          oli_sketch
                          Hi Again,
                          Sorry, I´ve selected Retina in default parameters but I haven´t saved the changes.
                          Much better.
                          • fredo6F Offline
                            Oli,
                            Do you have any way to play with the Retina settings on OSX to see if they would impact the text size? Some other Retina users have a bigger text.
                            If not, then, I am afraid that I won't be able to do anything about it, except that the buttons are now bigger.
                            • O Offline
                              oli_sketch
                              Hi again,
                              The only way (Mac) that I know for change the type size on screen is choosing resolution.
                              When you talk about retina users with normal size, are they using macosx 10.9.1 ? macbook pro 15" latest 2013 ?
                              Gráficos NVIDIA GeForce GT 750M 2048 MB ?
                              Thank you again
                              • fredo6F Offline
                                LibFredo 5.6a, just published integrates some limited support for Retina users.
                                You can set the parameter on in the Default Parameters dialog box of LibFredo6.
                                When set, the size of the button palettes, visual progress bars and some custom tooltips will be enlarged by a factor 2.
                                HOWEVER, there is no way to change and adjust the font size proportionallyfrom the Sketchup Ruby API. So you may still get tiny fonts if this was the case before.
                                Thanks to Retina users to advise on the change and signal if there are graphical elements that would need to be enlraged as well. I am also referring to the width of lines, which I did not change in the current version (except for the Visual Progression bars).
                                • O Offline
                                  oli_sketch
                                  Hi Fredo,
                                  I show you some screenshots. The types are little enough but bigger than before.
                                  Much better. Thank you very much.
                                  Kind regards.
                                  pd.- I put a screenshot from Soap Buble plugin with the same problem....
                                  • charly2008C Offline
                                    charly2008
                                    Maybe this tool could help the retina user. SwitchResX 4
                                    Site not installed - OVHcloud
                                    Site not installed
                                    (www.madrau.com)
                                    • pbacotP Offline
                                      Site not installed
                                      (www.madrau.com)
                                      That's a great find, not only for Retina, but maybe for a monitor I Just got that needs tweaking and has few settings. Thanks. P
                                      • josephkim626J Offline
                                        josephkim626
                                        Thank you Fredo,
                                        This is actually helpful for high-resolution windows machines as well.
                                        Although some control over the scale value other than 2 would be great as well.
                                        Anyways, much better than no scale as all the texts and toolbar are scrambled without.
                                        • 2 / 2
