    [Plugin] Raytracer
    60 Posts 18 Posters 69.3k Views 18 Watching
      Version 1.1.1
      • Fixed a bug in Drop by Bounds that caused chaos when objects where dropped.
      • mitcorbM
        mitcorb
        Thank you, ThomThom:
        I will test this out. You are very talented, relentless in the pursuit of excellence. I salute you. 👍 👍 👍
        • T
          tallerfulano
          Just fantastic !
          thanks
            Any chance to have something for have this result when I select the 3 up objects ?
            I can use SketchyPhysics but...
              mlefevre
              I'm trying to use this plugin to drop a bunch of solar panels to a surface. Some of the blocks drop fine, but others turn up on end. Any thoughts?
              • tt_suT
                tt_su
                No idea without test screenshots or preferable a test model.
                • tt_suT
                  tt_su
                  Hard to tell without a model...
                    AcesHigh
                    Can someone help me? It´s kinda urgent. Basically, For some reason, the components are NOT dropping until the ground. I verified the axis of the component, verified everything, but it still doesn´t work. It´s also weird, but it doesnt work with the other plugin (Drop At Intersection) too!!
                    They drop only a few centimeters. Unless I "drop by bounding box", but then, when dropping by bounding box, the components follow the contour of the terrain (which gets pretty weird for lightpoles)
                    perguntadropcomponent.skp
                      AcesHigh
                      Sorry, but when I posted and attached the model, I didnt notice it failed to upload the model because it was larger than the 4mb forum attachment limit.
                      I edited the first post and attached the model (now, 3mb)
                      • BoxB
                        I used the plugin "Throw to".
                        Throw toSU8.skp
                          AcesHigh
                          Thank you Box. Any slight idea why Raytracer, Drop At Intersection, etc, are not working?
                          • BoxB
                            Sorry, I don't know the ins and outs of either plugin. Which is why I went for throw to. I can look tomorrow if nobody else does.
                            • tt_suT
                              tt_su
                              It appear to be because the ray traced hit the component it tried to drop. Apparently I forgot to make it ignore itself. If I moved the axis to the bottom of the component it worked fine.
                              • tt_suT
                                tt_su
                                Filed issue: https://bitbucket.org/thomthom/raytracer/issue/1/ignore-the-components-being-dropped
                                  AcesHigh
                                  I see. Thanks ThomThom, for looking at the issue.
                                    mlefevre
                                    I can send you a screenshot, but basically I'm having the same issue as one of the prior post with the car crashes.
                                    • tt_suT
                                      tt_su
                                      SketchUp crashes?
                                      What version of SketchUp are you using (full exact version please) and what OS?
                                      Got a sample model and step by step description of what you do to reproduce it?
                                        DCorral
                                        I'm new on sketchup and seem to not understand this plugin. I did a toposurface and modeled all the constructions on a big area. Now im trying to drop the components (i'm guessing it's going to be a lot of work but I'm fine with that) and I can't seem to be able to drop them into the terrain... They keep floating.. want to try raytracing but i dont understand that function.
                                        Could you help me? Thanks a lot.
                                        • P
                                          Panga
                                          DCorral,
                                          One thing you have to verify is the position of your axes inside the component. The origin of axes must be at the bottom of the geometry in order that the drop works.
                                          Hope it helps.
                                          Regards.
                                            Always cool! 😄
                                            • 2 / 3
