    [Plugin] Layers Panel 1.2.1
    672 Posts 109 Posters 202.8k Views 109 Watching
      gbterstal
      Perfect...! That works for me. Thanks for the quick reply... πŸ‘
      • JQLJ Offline
        JQL
        Hi Jiminy,
        Here's a couple of feature request for when you have the time:
        • You have the add layer button wich when you press a button for long gives you the possibility to add a layer hidden on new pages. Usefull but hard to access, would it be very hard to make it faster to access? Like a separate button or a one click drop down (drop up actually) button?
        • Could you also create a button for adding a layer only visible on current scene?
        Thanks again for this wonderful plugin,
        JQL
        www.casca.pt
        Visit us on facebook!
        • jiminy-billy-bobJ Offline
          jiminy-billy-bob
          Yup. πŸ˜„
          • JQLJ Offline
            JQL
            Does this
            @jiminy-billy-bob said:
            Yup. πŸ˜„
            refer to my useful yet secondary feature requests? Then thank you!
            If not, then no problem, the plugin is already great! πŸ‘
            JQL
            www.casca.pt
              jiminy-billy-bob
              Both πŸ˜„
              • JQLJ Offline
                JQL
                LOL!
                www.casca.pt
                • X Offline
                  xkalvisx
                  Somehow, using the plug-in, it is always required to save the project. Whether someone edited or not. I think that it should not be.
                  thanks
                    jiminy-billy-bob
                    New version 0.10 beta !
                    Changelog :
                    • Added compatibility with Keyshot renderer
                    • Added "Add layer on new pages"
                    • "New layer" button hold-down time is now faster
                    • Minimize/maximize should work better
                    Download in the plugin store ![/quote]
                      jiminy-billy-bob
                      Crap... I removed Keyshot from the poll, and now all the results are gone πŸ˜•
                      • JQLJ Offline
                        JQL
                        Yeah! πŸ˜›
                        www.casca.pt
                          davecoopstl
                          Jiminy,
                          Have a small problem with your amazing Layers Panel plug-in.
                          Whenever I use the Grab Location feature of SU to Geo-locate my model, the Google Earth Terrain and Snapshot layers come into the model, BUT Layers Panel assigns BOTH layers the same name..."Google Earth Snapshot", and the functionality of Layers Panel is broken.
                          If I open the standard SU Layers, both the "Google Earth Terrain" and "Google Earth Snapshot" layers are there, and work as expected.
                          Only when I close your Layers Panel, and re-start it via the Icon does it fix the layer names and functionality.
                          Don't know if others are experiencing this, but it happens with existing models, and if I start a brand new, empty model.
                          Hope you can take a look and address this.
                          Thanks.
                          Dave.
                            jiminy-billy-bob
                            I'll take a look.
                            • EdsonE Offline
                              Edson
                              first of all, thanks for porting this plugin to Mac OS.
                              I am running mac os 10.8.5 and am facing some problems that I will report as they happen.
                              the first is the fact that when I open your layers panel it does not recognize the current layers but loads the ones the file opened with.
                              the second is the fact that I highlight a layer, select a group and try to move it to that layer but nothing happens.
                              http://www.mahfuz.arq.br
                                kct3937
                                This version is working well for me at this time, where the previous installation just killed Sketchup totally.
                                I am running this on OSX 10.8 and am now so used to the CMD-click setting that I am having trouble with the CTRL-click setting.
                                Since your extension is similar to the Layers panels in Photoshops, which I also use, I automatically pressed CMD-G to create the group.
                                I had another ruby or extension that recognizes which OS that SU is running on and changes actions accordingly. Could you try and modify the commands based on the OS and implement the CMD keystoke instead of CTRL for the MAC users.
                                This is exactly what I wanted.
                                Thanks much.
                                Ken T
                                  kct3937
                                  I have not been able to get the Layers panel to open on Sketchup launch even though I checked the option.
                                  This is SU 2013 running under OSX 10.8.5.
                                  I opened the panel and checked the option in my default template, but no luck.
                                  When I reopened the panel, I noticed that the check had not "stuck" as other selections had.
                                  Maybe it's just me.
                                  Ken t
                                    Sait Moore
                                    I'm an architect and I organize my layers with a four digit numerical prefix, e.g. 4000 Masonry. This is expanded by me as needed to: "4020 Masonry - Second Floor Interior Walls." It can also be "3012 Concrete - First Floor Side Walks" or, 0301 Concrete - Foundation Walls" and so on. In each layer instance, the first two digits are taken from the Construction Specification Institute's guide specifications hand books, 0300 for concrete (in all its variations poured, precast, etc.) or 0500 for metals (in all its various forms, rolled steel beams or columns, etc.) This format, which goes beyond 2400, is also followed by "Masterspec" software for specification writing by architects.
                                    This makes it easy to tie the drawings of the model with the written specifications, and also acts as a help in cross checking the drawings with the specs & vice-versa.
                                    I don't know if you find it too cumbersome for uses you envisage in setting up your software or not.  Just passing on one person's idiosyncrasys for your use if you wish.  :wink:
                                      jiminy-billy-bob
                                      Does this happen with every file? Even files created after you installed Layers Panel?
                                      You mean an actual SU group, with the icon at the top of LP's dialog?
                                      kct3937 > I'll change the shortcuts to CMD.
                                      As for the options panel, it seems broken on mac, I'm not sure why. Does any option works for you?
                                      Sait Moore > I'm not sure I get your point. Do you have a question/request?
                                        kct3937
                                        Regarding the option panel…
                                        Yes the other options seem to work. The only one that seems not to work is the top one… "Open Layers Panel when Sketchup Starts".
                                        I too am an architect and I also wondered about the point in the Moore comment.
                                        I do however wonder what the Teapot is all about.
                                        I really like the extension and am looking forward to any new developments. Keep up the good work.
                                        Thanks for getting back
                                        Ken T
                                          jiminy-billy-bob
                                          Well this is weird. If you have time, could you please test each option individually and confirm they all work with no exception besides the startup one? I need solid confirmation instead of "seems" πŸ˜‰ Thanks a lot, that would be really helpfull.
                                          I'm writing docs on the plugin features. In the meantime, take a look at this :
                                          [screenr:2b1ad6tw]OHcH[/screenr:2b1ad6tw]
                                            kct3937
                                            Sorry for being weird.
                                            I took it that the other options were working as of the four and numbering from the top, 2 & 3 were selected, while 1 &4 were not. After experimenting, I cannot see anything different with them and I would have to say that at this time, none of them seem to be working.
                                            I checked specifically to see if I got an error message as indicated in Option 2 and received no error.
                                            Option # 3 talks about a Render Toolbar, yet neither state shows or hides anything on my screen.
                                            In the attached video, I see two extra panels. If I am supposed to be seeing both or either of them…I do not I see only one panel.
                                            Considering that the previous version of this plugin crashed SU everytime and caused me to disable it, I found this version quite stable. Since I do not know what the operating plugin should look like, I made an assumption that is was now working.
                                            Without knowing what to expect from the plugin, I can only comment on how I am trying to use it and if this is not specific enough or confusing to you, I apologize.
                                            I have many years of experience in Beta and QC testing of software and hope that my comments can be of help.
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 33 / 34
