    [Plugin] EdgeInspector - v1.2a - 12 Oct 14
    42 Posts 18 Posters 44.2k Views 18 Watching
      A new hit for the repairs! ๐Ÿ˜Ž
      • mitcorbM
        mitcorb
        This is excellent. Of course, for Fredo's work, that is like saying the sky has air in it. ๐Ÿ’š
        • micioneM
          micione
          Excellent!
          • ely862meE
            ely862me
            This looks very interesting ! Thank you ! ๐Ÿ‘
            I hope to have a real use for it in my next 3d printing project !
            Elisei (sketchupper)
            Come and See EliseiDesign
              rv1974
              sounds awesome โ˜€ gone testing.
              Oh Fredo!
              • N
                numerobis
                ๐Ÿ˜ฎ ๐Ÿ˜†
                OMG! This looks really incredible. Another great tool out of the blue...
                Big THANKS! ๐Ÿ˜Ž
                ๐Ÿ‘
                  johnlv
                  It's a great tools..........
                    rv1974
                    I've been terrorized for years by poor skilled autocadders with this triple decease, see attached.
                    If only this tool could treat it(preferably automatically, without excessive manual digging) I'd nominate you for Nobel.
                    zazaz.skp
                    • K
                      kaas
                      Absolutely fabulous! ๐Ÿ‘
                      • panixiaP
                        panixia
                        very very intersting.. thank you once again!
                        • fredo6F
                          NEW RELEASE: EdgeInspector v1.1a - 15 Feb 14
                          EdgeInspector 1.1a is a release which introduces the detection and fixing of 2 new defects: lost junctions and needle-eyes.
                          This comes from an original request by rv1974 (I will soon add the Fake Holes detection so that he owes me a Nobel prize!).
                          [flash=640,480:3f05uay3]http://www.youtube.com/v/2xI7G3MK5hg&hl[/flash:3f05uay3]
                          See main post on EdgeInspector for more information
                          See main post of this thread for Download of FredoTools.
                            rv1974
                            http://img.ehowcdn.com/article-new/ehow/images/a07/uq/9o/presbyterian-resources-black-history-month-800x800.jpg
                              rv1974
                              Had some field tests- This is Rock-solid tool! Very stable and polished. Amazing!
                              What I noticed sometimes Inspector leaves some bad vertexes that it won't be able to remove
                              (see attached). It could be easily solved by coping the faces only, deleting everything and inserting the copied.
                              zzz.skp
                              • N
                                notareal
                                Nice work! Thank you!
                                • fredo6F
                                  Seems your segments are not perfectly aligned, one with a difference of 1.38 degrees and the two other with 0.01 degrees. These last two are detected, but are not fixed, because the method assumes segments are perfectly aligned for Sketchup.
                                  By the way, RemoveLonelyVertices does not detect them either.
                                  I'll see if I can do something to trap these cases and fix them.
                                    rv1974
                                    Don't bother. Make a Groove Maker Tool instead.
                                    • BurkhardB
                                      Burkhard
                                      For a magnifier tool I asked years before when Pixdim comes out
                                      Thanks for it!
                                      http://www.ia-plus.de
                                      • fredo6F
                                        NEW RELEASE: EdgeInspector v1.2a - 12 Oct 14
                                        EdgeInspector 1.2a is a major release which is fixing a number of problems with 3 tools: Lost Junctions, Tiny Gaps and Tiny Edges.
                                        This release provides a more accurate and relevant inspection and fixing:
                                        • Tiny Edges are now detected and fixed in groups (loop, hook and sequence)
                                        • Tiny Gaps are detected more adequately and fixed either by moving vertices or by moving the whole connected shapes (to keep the integrity of geometry)
                                        • Lost Junctions receives a more accurate treatment
                                        • F
                                          floriane_mvdb
                                          Hello Fredo 6, thank you for this plugin that seems to be really awesome!
                                          I don't know if it's the good place to ask for some help using this tool, didn't find any subject about it in the forum.. The problem is that everytime i try to fix the defects calculated in Edge Inspector, i get the same error message saying : error during inspection, Cannot convert argument to Sketchup::Point3d (with a list of errors)
                                          What could i do to solve the problem ?
                                          Thank you
                                          • fredo6F
                                            Thank you
                                            In order for me to help, could you post or send me the error full text, either as a copy paste, or by exporting the file as a txt.
                                            Could you also tell me which correction tool(s) you were using.
                                            I may also need the model, incase I do not see the problem from the error log.
                                            • 1 / 3
