    [Plugin] Components manager plugin
    156 Posts 15 Posters 52.7k Views 15 Watching
    • inteloideI Offline
      inteloide
      Hello,
      Just post new version, with following updates :
      1.9.8: Corrected : Delete all debugging messages, now works on MAC ! Thanks to Oxer !
      1.9.7:	Corrected :	Some javascript standard respect
      	Added :		Show a message to update the list if the wasn't.
      		Added :		Option not to start component mangement on SU start up to avoid adding attribute to model or slow down due to Observers
      1.9.6:	Corrected :	For localisation, in cas of error, the English language is chosen, also, english tranlsation always preload in case translation is missing
      	Corrected :	Change function in BGSketchup.rb functions into unic name function to avoid problem with other plugins
      Humanity will do a huge step when the IT professionals will understand that computers are tools...
        inteloide
        New version update (v 1.10.0) :
        Added : Toolbar with icon to show the plugin window
        Added : Help file is now in plugin sub folders, with a link from the "about" window. It was updated with last options explainations
        Optimzed : "About" window in HTML format for better rendering and to allow links to help file and forum.
        Optimzed : Component list shows scrollbar only is required.
        Optimzed : On MAC, use plugin window is now always on top.
        Corrected : Only one instance of the window can be shown.
        Corrected : Added, some missing translations in Spanish language.
          inteloide
          Hello,
          Some updates today !
          JQL, one of your request is complete (filters) !
          1.11.0:
          Added : New option to show list without a tree-style
          Added : New button and window to filter item shown on list in case of non tree-style list
          Corrected : Component with relative path were shown as "not updated", now shown in grey
          Corrected : Tiny bug when showing components without dates
          Corrected : Add filter in remove observer to avoid errors
          Corrected : When clicking on component in model, all instances were selected if option Auto-select component in model was chosen
          Optimzed : Purge only the definitions reloaded, to avoid any trouble with other definition
          1.10.0:
          I hope lots of you feel this plugins useful...
          3D printer progress...only 1 euro by now... 😒
          • OxerO Offline
            Oxer
            Thanks for the update!! πŸ‘
            Some questions in OSX:
            1. If you select Yes in "Show list in tree-style" Option it doesn't appear like tree-style but if you select No then it appears the list in tree-style, is it the option upside down?
            2. In Filters window the option "Component has no defined date" has a blue color but in Component Manager window it appears in black, is it an error?
            PS. The tooltips in Component Manager window don't translate to Spanish.
            EDIT: I had not understood the functionality, it works correctly but if you push Filter button when you have selected YES in option "Show list in tree-style", it appears a pop-up window with this message "You must choose option Show list in tree-style.", I think that it should say --> "You must choose NO in option Show list in tree-style." because with YES it isn't appear the Filters window.
              inteloide
              Hello Oxer,
              Just post new version 1.11.1 that solve your issues:
              Corrected : New filter for components which were not checked (option "Auto-check file paths")
              Optimized : Improve warning message for filter window
              Optimized : Component without modification date are shown in blue
              Optimized : Message shown if filter make the list empty
              Optimized : Allow more translations
              • OxerO Offline
                Oxer
                Hi again,
                I'll test it. πŸ‘
                • JQLJ Offline
                  JQL
                  @inteloide said:
                  Hello,
                  Unbelieaveble!
                  I have not had the time to work with your plugin recently, but this week I will try it for sure. Thanks for all the recent excellent updates, this is growing strong.
                  JQL
                  www.casca.pt
                  Visit us on facebook!
                  • OxerO Offline
                    Oxer
                    There are yet some problems:
                    1. To work fine the Filter function you must to change the line#50 in Localization.rb file
                    Of @strTreeListOptionToBeSelected="You must set option '"+@strOptionVerifierChemin+"' to '"+@strNon+"'."
                    to @strTreeListOptionToBeSelected="You must set option '"+@strAfficherArbre+"' to '"+@strNon+"'."
                    2. The Filter only works the first time, then when you push Filter again all items are unselected, and if you select one or various items and push Apply button nothing happens in the List window, it appears only the message "Nothing to show due to filters". The Ruby Console is empty.
                    PS. The tooltips continue without translation in Component Manager window. I send you a new spanish language by PM.
                      inteloide
                      Thank to Oxer a big bug is corrected in version 1.11.2.
                      Everybody should download this version to avoid problem using the plugin.
                      Updates :
                      1.11.2:
                      Corrected : Major error while linking component to file of reloading component
                      Corrected : In non tree style, numbers of instances of components filtered still appeared
                      Corrected : A bug appear in consol when leaving the plugin due to observers still working
                      Corrected : Change context menu javascript position which may imply some Safari problems
                      Optimized : Add translation for component updating while opening new sketchup instance.
                      Oxer, we keep in touch for your button title issue.
                      • OxerO Offline
                        Oxer
                        I'm testing the last version on Mac and the Filters doesn't work. 😞
                          inteloide
                          Hello Oxer,
                          Could you tell me what's goes wrong ?
                          • OxerO Offline
                            Oxer
                            When I push the Filter button the first time it appear the Filters window with all items selected, I unselect for example "Group" and "File path doesn't exist" and I push Apply button, then the Filters window disappears and it appears this message in the Component Manager window "Nothing to show due to filters".
                            I had groups, component linked and component unlinked in the model. I suppose that the Filters function works showing only the items selected in Filter windows but it isn't so.
                            If I open the Filters window a second time, all items are unselected.
                            Mac OSX 10.9.1 and SU2013
                              inteloide
                              Hello Gents,
                              Please download last version of the plugins which solve the 2 issues you raised me :
                              Version 1.11.3:
                              Optimized : The modification of components don't add lots of undo/redo action in Edit menu.
                              Corrected : Bug when changing filters
                              Oxer, could you tell me also if the last version solve your issue about button title translation in main window ?
                              JQL, thx for chasing me on the undo/redo action, actually it was just simple as reading the sketchup rubi api...
                              Just one thing : for example if you delete an edge linked to a face, so edge and face are deleted, when undo the action, the component manager will tells you that your component has been modified (even if it actually reverse back to original design).
                              It's not a big bug, but I'll keep thinking about a solution.
                              Inteloide
                                inteloide
                                @jql said:
                                4 - There is a feature that is not working as I would expect too. If one refreshes the list by whatever reason it collapses (some commands also refresh it). You loose the context on the list you were on. Of course it's easy now to choose from model so this is just a minor question.
                                JQL
                                Except this request, I think I've complete all the other request. 😍
                                But don't worry I have one idea for this request, even if I think that at the end using list in a non-tree style is easier to use.
                                Other steps for plugin optimization would be :
                                • Add possibility to auto-update the list when change the model with defining the update time (from 1 sec for small model, too minutes for big one) I could link this frequency to the time required to update the list : frequency auto-defined !
                                • Add possibility to attached current time as modification time for component in model. This could be usefull for old model designed before having the plugin, or designed while plugin was desactivated.
                                • change Option interface (options are mixed, and design just horrorful !)
                                • change actions button at bottom of main window. Or allow user to defined which button he wants to have.
                                  If you have other request...they will be welcomed. πŸŽ‰
                                If few days I will open a new topic to find some beta tester for an industrial 6 axis robot manager plugin. This will be the second plugin I'll officially release even if they are months I'm working on.
                                So if you have other requests it's time, even if I won't let you down !
                                Inteloide
                                • JQLJ Offline
                                  JQL
                                  Congratulations on this Milestone!
                                  I'll try this one... but don't worry, I'll find some feature requests for you to deal with πŸ˜„
                                  Thanks,
                                  JQL
                                  www.casca.pt
                                    inteloide
                                    Hello,
                                    Today update :
                                    Optimized : New options windows in HTML mode.
                                    Corrected : Little change in code to avoid error when deleting components with merge faces (to be verified...)
                                    Added : Prompt before upload all dΓ©finitions
                                    Options texts translation have to be done again...sorry for that...
                                    Inteloide
                                    • OxerO Offline
                                      Oxer
                                      Test v1.12 on Mac:
                                      The Options button doesn't work, it appears this message in Ruby Console when you push the button:
                                      %(#FF0040)[Error: #<TypeError: can't convert false into String>
                                      /Users/Oxer/Library/Application Support/SketchUp 2013/SketchUp/Plugins/BGSketchup/Composants/Rb/Composants_Main.rb:794:in `+'
                                      /Users/Oxer/Library/Application Support/SketchUp 2013/SketchUp/Plugins/BGSketchup/Composants/Rb/Composants_Main.rb:794:in `options'
                                      /Users/Oxer/Library/Application Support/SketchUp 2013/SketchUp/Plugins/BGSketchup/Composants/Rb/Composants_Main.rb:793:in `each'
                                      /Users/Oxer/Library/Application Support/SketchUp 2013/SketchUp/Plugins/BGSketchup/Composants/Rb/Composants_Main.rb:793:in `options'
                                      /Users/Oxer/Library/Application Support/SketchUp 2013/SketchUp/Plugins/BGSketchup/Composants/Rb/Composants_Main.rb:52:in `initialize_window']
                                        inteloide
                                        Hello Oxer,
                                        Version 1.12.1 should solve your issue.
                                        Inteloide
                                        • OxerO Offline
                                          Oxer
                                          Other problems 😳
                                          1. The Options "Auto-select instances in model" & "Auto-select instances in list" worked only the first time that I ran the plugin.
                                          2. The Groups don't appear in the List although you have marked them in the Filters windows.
                                          3. I don't know if this is important but when I create a "New File" with the Ruby Console opens, it appears this message:
                                          %(#FF0040)[Error: #<NoMethodError: undefined method `execute_script' for nil:NilClass>
                                          /Users/Oxer/Library/Application Support/SketchUp 2013/SketchUp/Plugins/BGSketchup/Composants/Rb/Composants_Main.rb:132:in `maj_liste'
                                          /Users/Oxer/Library/Application Support/SketchUp 2013/SketchUp/Plugins/BGSketchup/Composants/Rb/Composants_Main.rb:1100:in `onNewModel'
                                          /Users/Oxer/Library/Application Support/SketchUp 2013/SketchUp/Plugins/BGSketchup/Composants/Rb/Composants_Main.rb:1073
                                          /Users/Oxer/Library/Application Support/SketchUp 2013/SketchUp/Plugins/BGSketchup/Composants/Rb/Composants_Main.rb:132]
                                          • OxerO Offline
                                            Oxer
                                            Great work!! πŸ‘
                                            All work fine now *****, nice Options window, perhaps a scrollbar, the windows size is very small on Mac and you have to resize them manually.
                                            The translation works partially.
                                            It works in:
                                            1. Plugins Menu
                                              1. Titles of the windows.
                                              1. Tooltips of the items in the List.
                                              1. Tooltip of the toolbar icon.
                                              1. All the strings in the Filters window.
                                              1. String: "List update at "
                                              1. All pop-up windows.
                                            The rest no.
                                            ***** See the next post.
                                            • 5 / 8
