    View from the bottom of the model
    8 Posts 5 Posters 3.8k Views 5 Watching
      jlyon
      I'm trying to create a scene of a ceiling plan. I can easily cut a section looking up at the ceiling, but is there a way to get a clean parallel projection of the ceiling, similar to what I'd get if I clicked "Top View" to get a roof plan? Is there such a thing as "Bottom View", Or a workaround to get the same effect?
        TECHDAVE02
        404 Not Found
        (sketchucation.com)
          You don't need a plugin to get a bottom view. Just go to Camera>Standard Views and choose Bottom from the menu.
            pgarmyn
            With standard Sketchup: select a face of the ceiling (not a group...), right-click and select 'align view' in th context menu.
            πŸ˜„
              jlyon
              Never looked to see "bottom" as a standard view. Always something new to learn. Thanks everyone. Now...how do I add an icon for bottom view to the view toolbar? I'm using SU2013.
                There isn't an icon to add to the native Views toolbar but you could make a shortcut for Camera/Standard Views/Bottom.
                • pbacotP Offline
                  I'd usually end up having a Scene or more for this, once I got going with a project, so an icon wouldn't be so useful. Making it a "reflected" ceiling plan is the trick. Sonder covers this some in his videos.
                    jlyon
                    Ok. Thanks
