    Help with round corner
    10 Posts 3 Posters 962 Views 3 Watching
      mcgaffin
      I am new to sketch up. I have installed the round corner plug in. When I open the program it tells me that I cant run the round corner plug in because I need a version later than 5 even though I am running 13. Any suggestions?
      • massimoM Offline
        massimo Moderator
        I think that "5" is referred to LibFredo. Install the latest LibFredo version.
          mcgaffin
          "Module RoundCorner requires Sketchup version greater than 5.0.160. Current Version is 13.0.3689"
          This is the message.
          • massimoM Offline
            massimo Moderator
            Do you have the latest "RoundCorner"?
              Update Lib_Fredo6, too.
                mcgaffin
                I downloaded it yesterday. How do I know if i have the latest versions of round corner and lib_frido
                  where did you get them? Use the Sketchucation Plugin Store tool to download and auto install the current versions of them.
                    mcgaffin
                    ok, I deleted the plugins and started over. I used the plugin store. downloaded the two plugins. I copy and pasted them into my plugins folder. I no longer get any error messages, but I don't see a tool for round corner.
                    • massimoM Offline
                      massimo Moderator
                      The files you downloaded are .rbz (a compressed rb), so you can't put them directly in the plugins folder.
                      Use window-->preferences-->extensions to install them or download SketchUcation Tools in order to easily manage the plugins.
                        mcgaffin
                        Thanks for all the help. It is working now.
