    Problems installing and running Sketchup on MacBook Pro
    6 Posts 4 Posters 1.3k Views 4 Watching
      asrnyc
      I am trying to install Sketchup on my son's Macbook Pro, which is running OSX 10.9.1. We are able to install the application and save a file, but then when trying to launch the saved file, we get an error message that file cannot be opened. We tried to install both Sketchup version 8, the one he uses at school on a PC, and also version 2013 for Mac. Both give us the error message when opening files. Any advice appreciated. Thank you.
        TECHDAVE02
        Are you tiring to open .skp (Model File) or .skb (Backup File)??
          asrnyc
          We are trying to open a .skp file. When we attempt this we are asked for a location to expand the file and an expander icon appears on the desktop. We set the location in our documents folder and say ok, then get an error message that the stuffit engine is unable to determine the file format. Thank you for your help.
            So you are able to open SketchUp itself?
            • wind-borneW Offline
              wind-borne
              Sounds like Stuffit is set to open application rather than SU. Right click on file, Open With should be SU(default) and if it's not choose 'Other...', applications folder will open and there you can choose SU.
              If that was problem go to 'Get Info' to set which version of SU you want as default when opening .skp files.
              "To read between the lines was easier than to follow the text."OSX 10.11.6
              %(#BF80BF)[SU 8 pro
                asrnyc
                Thank you very much, to you and Dave. That is the problem as you have described. We were able to correct it and now can successfully launch SketchUp on my son's Mac. Happy New Year to all!
