    [Plugin][$] TopoShaper - v2.7b - 30 Jan 26
    460 Posts 145 Posters 905.0k Views 144 Watching
    • fredo6F
      @gmansu8 said:
      If Fredo6 could find a way to make the TopoShaper operations menu size itself dynamically that would help those of us with suboptimal vision.
      Hey, it's Christmas! I can ask, right?
      You are right. It's Christmas and the impossible can be ordered, with probable delivery for the next one 😄
      Actually, the Ruby API completely lacks control about text display (size, color, fonts, ....) and this is something that would be welcome. For info, the hottest issue today is on Mac with Retina screens.
      • pbacotP
        Yes some rubies are unusable with a retina screen.
        Actually SU is not that great on it either. It looks nice, but the lines are very thin and one sometimes cannot easily see what lines and faces are selected.
        • bobpineoB
          bobpineo
          Fredo,
          first of all thank you again for your most excellent Plugin.
          I have a question, how do you suggest modeling contours around a retaining wall?
          I have been testing a variety of options, but can't quite get a clean surface that would approximate this detail.
          There would be a lot of clean up to get the surface correct, and I was hoping you could comment on a work around...
          Or dare I say it, and added function to the plugin..?
          Not sure even how to explain it, (let alone figure out how to go about adding this function)...but could it be possible to designate areas that are to remain flat?
          For example a surface at the top of a retaining wall.
          Thank you in advance TIG, and I am dropping by your donation tab to give you a much appreciated thank you!
          Best.
          BP
          Plan view of topographic lines around a retaining wall
          Perspective view
          Result after running toposhaper
          Deviation of mesh from contour
          Bob Pineo, Design Develop LLC http://www.designdevelop.org.
          • I
            ivreich
            Hi Fredo
            I'm having problems running your latest version of Topo Shaper. Everything works fine up until I hit "generate terrain" at the last step, then the model goes crazy and i end up with a bunch of unexpected geometry (guide lines, blank rectangle face)
            No error warnings in the ruby console either...
            I've attached the SU 2013 file, could you help me have a look?
            Joel
            SU 2013 File with contours
            Preview Mode works fine...
            Unexpected end-results...
            • fredo6F
              @ivreich said:
              Hi Fredo
              Joel
              I tried, with SU13 (since your model is SU13) and get a correct result with a 50x and 100x grid. However, I noticed a small problem (which requires a model fix), most probably in a small triangle of the skirt.
              Ivreich_Topo.skp
              Could you send the bad-generation file.
              • fredo6F
                @bobpineo said:
                Fredo,
                Unfortunately, cliff cannot be handled in the current version of Toposhaper, because it is based on a Grid concept where each point of the grid corresponds to one altitude.
                Currently, you have to post-process the shape by cutting the wall manually.
                • I
                  ivreich
                  Hi Fredo
                  File with bad results attached...
                  Thanks again!
                  J
                  bad results
                  • bobpineoB
                    bobpineo
                    @fredo6 said:
                    @bobpineo said:
                    Fredo,
                    Thank you Fredo, How hard is that to incorporate into the plugin, its is christmas pretty soon after all!
                    thanks Again.
                    BP
                    • fredo6F
                      thanks Again.
                      BP
                      Before Christmas, you may use the Sandbox stamp and then JointPushPull to extrude the sahpe surrounded by walls.
                      Handling cliff is rather complex, because I need first to introduce a feature where the mesh is adapted to follow exactly some contours and then change the mesh logic to handle several altitudes for the same grid node.
                        jcorreiadefreitas
                        Tried the plugin today and it does wonders... however i am wondering if it is possible to clip or "limit" the terrain generation to a line as i dont want it to generate in terrain beyond the lowest contour...
                        • fredo6F
                          @jcorreiadefreitas said:
                          [attachment=0:3eevq3al]<!-- ia0 -->1.jpg<!-- ia0 -->[/attachment:3eevq3al]
                          If all contours are enclosed within a big one, then this big contour is taken as the limit.
                          So it should work in your case.
                          Otherwise, just send me the model so that I have a look.
                          • T
                            tspco
                            Error in SU make, I installed toposhaper in SU make this morning, and got this error. I used the same terrain in SU8 no error using the same procedure. Just wanted to let someone know.
                            SU make 2017, /Twilight Render Hobby
                            Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
                            • fredo6F
                              @tspco
                              I will publish a fix for this error.
                              However, I am interested in seeing your model, as it may be related to defects in the contours.
                              • T
                                tspco
                                I just tried again this morning and it worked, but somehow things were different, not sure what is going on. The model was simply a geolocation grab, from within SketchUp.
                                • mariochaM
                                  mariocha
                                  As requested in the documentation, here is the error report I get when trying to edit a generated terrain.
                                  On Mac (french) and PC (english) same error.
                                  %(#0000BF)[**Une erreur s'est produite dans
                                  L'opération a été annulée
                                  undefined method `unshift' for nil:NilClass
                                  TopoShaperTool.rb:: 1457 -- registry_info_new
                                  TopoShaperTool.rb:: 1389 -- registry_info_get
                                  TopoShaperAAMixin.rb:: 184 -- contour_global_boundaries
                                  TopoShaperAAMixin.rb:: 176 -- contour_analysis
                                  TopoShaperAlgo.rb:: 330 -- top_analysis_contour
                                  TopoShaperAlgo.rb:: 228 -- top_processing
                                  TopoShaperTool.rb:: 559 -- algo_processing
                                  TopoShaperTool.rb:: 581 -- algo_load_from_attr
                                  TopoShaperTool.rb:: 973 -- onLButtonUp**]
                                  %(#0000BF)[**An error occured in CALCULATING TERRAINS
                                  The operation is fully aborted
                                  TopoShaperTool.rb: 1457 -- registry_info_new
                                  TopoShaperTool.rb: 1389 -- registry_info_get
                                  TopoShaperAAMixin.rb: 184 -- contour_global_boundaries
                                  TopoShaperAAMixin.rb: 176 -- contour_analysis
                                  TopoShaperAlgo.rb: 330 -- top_analysis_contour
                                  TopoShaperAlgo.rb: 228 -- top_processing
                                  TopoShaperTool.rb: 559 -- algo_processing
                                  TopoShaperTool.rb: 581 -- algo_load_from_attr
                                  TopoShaperTool.rb: 973 -- onLButtonUp**]
                                  Contour file attached
                                  Contours-plats.skp
                                  %(#008000)[Mario C.
                                  • fredo6F
                                    I found the error. Will go into the next release.
                                    If you wish to skip this error, select a contour anywhere in the model, then deselect it and select your Terrain Group.
                                    • fredo6F
                                      SAMPLE CONTOURS MODELS
                                      Earthmover Topo 1.skp
                                      Krisidious Hanna Topo.skp
                                      pbacot Contours 1.skp
                                      pbacot Contours 2.skp
                                      Solo Topo 1.skp
                                      utiler Survey 01.skp
                                      • fredo6F
                                        NEW RELEASE: TopoShaper v1.1b - 02 Mar 14
                                        This minor release fixes a bug preventing to reload generated terrains, as signaled by Mariocha
                                        I also published a few sample contours model so that you can exercise TopoShaper
                                        See main post of this thread for Download of TopoShaper.
                                        • guanjinG
                                          guanjin
                                          Chinese text dislocation selection panel,Does not affect use. Thank you 👍
                                            matt.gordon320
                                            Hi Guys,
                                            I wanted to see if anyone might be able to help me figure out what's causing errors in this model. The odd thing is that it doesn't seem to throw out any actual errors, the model just gets to a certain point in the script and stops. No errors, but using any tool, trying to get out of the script or going to revert causes either Windows Runtime Errors or BugSplat.
                                            Any thoughts would be appreciated. I'm helping out someone in the office who set up the model, so I have somewhat limited knowledge of her workflow, especially with a bit of a language barrier.
                                            Thanks,
                                            Matt
                                            Topo shaper test.skp
                                            • 11
                                            • 22
                                            • 23
                                            • 9 / 23
