Need help on a panel door
Hi again
with regards to building the mitred moulding
I hide the the share lines and delete the the internal surfaces
Then change the axis so as make minimum need for formulas,the sizes of the mitres are trapped, the section of the length is also trapped, only movement is along x-axis
the scale tool is incorporated for easy size change for other projects
with regards to "cut-list" I did not know it was part of the criteria so I've downloaded it and will try to figure it out
cheers
had a quick look @ cutlist
I note that my picture frame produces 4 lengths (middle) and 8 ends (4 left,4 right), the middles are short points to the mitre ends
if I open a moulding and explode the 3 groups then I can get a single entity on the list
(this maybe the foundation to a ruby script,,,"explode internal entities", the coders can make)
you did a great job of explaining it!!!! Last night I did finish the thing, but not quite like you did.... mines sloppy in comparison but you can see how I bungled through it. I just go in and group the 2 miters and center pieces after I set the door size and then it exports to cut list fine,(it only goes done 2 layers)then I can explode the group to edit it if need be.
Cheers Mike,
it works, just need to hide the joins (double click the offending surface, right click, hide)
I am glad you didn't give up...
your model is completed..I'm still playing around with some ideas...I added formulas to the mould I made which allows change in degrees, added options to pick scale or fixed length (thanks to "eselick".... "Scale AND keyed in values for component size")
Philip
I did as you suggested and hide those ends looks much better!
but did discover an error I have to fix when I move the door lol Post yours when done am interested in seeing finished formulas
Ok got it fixed. I made the mistake of referencing the door Z value instead of just referencing the bottom style lol everytime I moved the door up the rails went to the moon! Still have improvements to make... but it has been interesting lol
Question for you: How does your door show up in a cutlist?
Sorry it took so long to answer have been in the shop a lot working. As to Cut list, it shows each piece of trim as three separate pieces. But, since the ends are all the same and only the length of the center changes, I manually edit the export file and just add in the length of 2 ends to the length of the center and delete the ends. This works because cutlist reads the end trim to the long point of the miter. I just made sure the naming is correct left center right or top center bottom so I can find them later.
Ah. I see. So does a panel show up as nine parts?
As long as it works for you. I guess if you have a lot of the same doors, that could be workable. My personal preference is to keep the parts as single entities and get accurate numbers out of the cut list without doing any math. I've never found resizing doors manually to be any trouble, anyway.
No the panel just resizes
Oh. Just a flat panel, then. Not raised?
