    LumenRT Training Needed - Willing to pay.....
    extensions
    35 Posts 5 Posters 3.1k Views 5 Watching
    • JAWSnAZJ Offline
      JAWSnAZ
      Thank You Solo! How do I up load a model to you?
      Windows 7 Pro 64
      i7-3770 3.4Ghz 32GB RAM
      GeForce GTX 650 Ti
      3dconnexion SpaceNavigator 3D Mouse
      Dual 27" Monitors
      My Site
      • JAWSnAZJ Offline
        JAWSnAZ
        Thank You Solo.
        How can I get a copy of my model to you.
        Can I put it up on Google Drive and share it to you?
        Windows 7 Pro 64
        GeForce GTX 650 Ti
        Dual 27" Monitors
        My Site
        • soloS Offline
          Yeah, sure Google drive, Dropbox, or even post in pm.
          • JAWSnAZJ Offline
            JAWSnAZ
            OK. Sent you a link to my model in a PM.
            Thanks.
            Windows 7 Pro 64
            GeForce GTX 650 Ti
            Dual 27" Monitors
            My Site
            • soloS Offline
              Thanks.
              Saw that, I clicked on link and it needs me to get permissions to download.
              Can you not direct link or Dropbox?
              • JAWSnAZJ Offline
                JAWSnAZ
                @solo said:
                Thanks.
                I got your request for permissions. I added the email that you sent. Hope it works. If not I will try drop box.
                Windows 7 Pro 64
                GeForce GTX 650 Ti
                Dual 27" Monitors
                My Site
                • soloS Offline
                  Got them, so how can I help?
                  • soloS Offline
                    Jay
                    Lets do the yard first.
                    Here is an image for those following of how the model looks.
                    For this exercise we are not going into modeling or texturing discussions. however I did remove most vegetation as I'd rather use the LumenRT supplied trees as they are way better and optimized.
                    In your email you wanted to know how to add lights, I saw you had string lights and a ton of them on the arbors, I deleted a bunch of them as there were just too many and inserted a point light inside see image. These are found on the LumenRT toolbar.
                    I also added 3 point lights in pool
                    Then I did a draft export to Lumion, set to night and done, some screen shots.
                    And here is the Live cube to play with
                    https://www.dropbox.com/s/5yot7t7pdz7lqur/Back%20Yard%2005.exe
                    Dropbox link will be removed in 48 hours.
                    • soloS Offline
                      Using SU scale tool.
                      • JAWSnAZJ Offline
                        JAWSnAZ
                        OK. So added a point light as you said but my point light is much much larger than the one you show. How do I change the size so I can see where I am placing it?
                        https://lh3.googleusercontent.com/-dI3U70aCPVk/UrSoDKimI0I/AAAAAAAAA5o/KFGlQL2pk9g/s1280/Back%2520Yard%252005%2520-%2520Point%2520Light.jpg
                        Windows 7 Pro 64
                        GeForce GTX 650 Ti
                        Dual 27" Monitors
                        My Site
                        • JAWSnAZJ Offline
                          JAWSnAZ
                          lol... that is the missing link in my head... treat the LumenRT components as any other component. Scale, Copy, etc...
                          Windows 7 Pro 64
                          GeForce GTX 650 Ti
                          Dual 27" Monitors
                          My Site
                          • soloS Offline
                            When you export to live cube you press TAB and it will open up a menu on the left side where you can go into the lights menu and adjust the lights one by one, if you have a ton of lights it becomes a pain in the arse, there is no way to group adjust them.
                            • soloS Offline
                              Also notice how I reduced the amount of lights, less is best here, trust me.
                              • JAWSnAZJ Offline
                                JAWSnAZ
                                OK. Cool.
                                Next question is about the glass bulb. Is there a way to make the glass bulb itself glow like it is frosted or translucent vs transparent?
                                https://lh4.googleusercontent.com/-cWz1-HW8Ve8/UrS2P_sQ31I/AAAAAAAAA6E/XMprJ5_mGSI/s1280/Back%2520Yard%252005_001.jpg
                                Windows 7 Pro 64
                                GeForce GTX 650 Ti
                                Dual 27" Monitors
                                My Site
                                • soloS Offline
                                  You can make the bulb a luminous material and not use the point lights, but then you do not have intensity control in live cube
                                  • JAWSnAZJ Offline
                                    JAWSnAZ
                                    OK. So here is a test of Luminous Materials vs Point Light in LumenRT.
                                    Luminous Materials - Luminous 1000
                                    https://lh5.googleusercontent.com/-55_nui7KKKc/UrXxdMh3PuI/AAAAAAAAA6o/XqycM3ZPbMo/s1440/lighting%2520test%2520-%2520Luminous%2520Materials.jpg
                                    https://lh4.googleusercontent.com/-L0I9UvA89IA/UrXylFTe5lI/AAAAAAAAA7M/HRexmidAOIw/s1280/Luminous%2520Materials.jpg
                                    Point Light - Incandescent - 2500 lumens
                                    https://lh5.googleusercontent.com/-5Ypb6sM2fiY/UrXxdEKTssI/AAAAAAAAA6s/r0EWyr8hrmg/s1440/lighting%2520test%2520-%2520Point%2520Light.jpg
                                    https://lh3.googleusercontent.com/-w673BqMJ6ko/UrXylED58SI/AAAAAAAAA7I/6nOYzcuIQPo/s1280/Point%2520Light.jpg
                                    Point Light - Incandescent - 10,000 lumens
                                    https://lh4.googleusercontent.com/-2KACDICtlkU/UrX2Rj_I2iI/AAAAAAAAA7o/7UiWqKKobRA/s1280/Point%2520Light%2520-%2520Incandescent%2520-%252010%252C000%2520Lumens.jpg
                                    I have tried to place the point light inside of and also overlap the luminous material to get the luminous material to cast a shadow. No luck either way.
                                    Windows 7 Pro 64
                                    GeForce GTX 650 Ti
                                    Dual 27" Monitors
                                    My Site
                                      d12dozr
                                      What if you put the point light inside the luminous material, so you get shadows and the frosted light bulb effect?
                                      http://goo.gl/f7ooYh
                                      • olisheaO Offline
                                        olishea
                                        This is a great thread and very generous of Solo to help out. Amazing forum work.
                                        oli
                                        • JAWSnAZJ Offline
                                          JAWSnAZ
                                          Thanks d12dozr
                                          I have also tried that. When I scale the point light down small enough and insert it into the luminous material the luminous material blocks the point light from escaping and does not create shadows.
                                          It seems like the point light treats the luminous material as a solid object.
                                          Windows 7 Pro 64
                                          GeForce GTX 650 Ti
                                          Dual 27" Monitors
                                          My Site
                                          • JAWSnAZJ Offline
                                            JAWSnAZ
                                            I agree olishea.
                                            I am very grateful to solo for the help. I also upgraded my membership from free to premium as a way to show thanks to SketcUcation and support these forums.
                                            Windows 7 Pro 64
                                            GeForce GTX 650 Ti
                                            Dual 27" Monitors
                                            My Site
                                            • 2 / 2
