    Dentil moulding..HELP!
    16 Posts 5 Posters 1.3k Views 5 Watching
      Here's a quick example.
        Grayorm
        [attachment=0:33quoiw6]<!-- ia0 -->dentil.png<!-- ia0 -->[/attachment:33quoiw6]
        Thanks for the help Dave. I can't see a link in your second post?
          There's no link. It's just an image. Can you see that?
          • BoxB Offline
            If you can't see Dave's image you need to adjust your adblocker to allow ads for Sketchucation. The site is Ad funded and the ads are all relevant and unobtrusive. By blocking the ads you also block access to file downloads and images. You can always remove the ads by becoming a premium member.
              Grayorm
              OK thanks guys......rushing be back later to try
                Grayorm
                OK just checked. I have Kaspersky and the banner blocker is switched off anyway! Still cant see it.
                  Perhaps there's some other part of it that is blocking? What happens if you switch it all off?
                    Grayorm
                    The baddies get in and eat my hard drive! Hang on I'll try it........wait, you're not a baddie are you?
                      Grayorm
                      Nope still nothing, however I have searched You Tube for a tutorial on it and am struggling my way through it. Much appreciate your input, I'll probably be back when I'm stuck. Have a great Christmas!!
                      • S ShepherdS Offline
                        S Shepherd
                        Here's two cent's worth of dentil making with evenly spaced teeth. At least within 1/64".
                        • BoxB Offline
                          Scott, there is no reason for the components not to be divided exactly. if you are unable to position accurately to your guide line it suggests you have snapping on and precision set lesser than needed. If you are too big down small you'll jump over the place you want.
                          You'll also find it simpler to create a suitably shaped component and array it rather than constructing your subtraction tool. For your example a simple L-shape and a corner piece is all that is needed.
                          As an example I made this profile in a few minutes. As it's made from components it can be quickly edited, textured, extended etc... it can always be made into a single solid if needed for texturing or printing or cutlists and such.
                          It also keeps file size down.
                          You can build a nice library of such components to make for very quick elaborate mouldings.
                          • F Offline
                            fluffy82
                            What would be even more fantastic and less time consuming, is a way to push pull the profile of your moulding, and have the dentils add themselves as you go. Keeping the dentils the same size and changing the spacing within a couple of centimeters of the "ideal" proportion as you stretch (jumping back to a smaller spacing and adding another dentil when the gap gets too big etc).
                              S Shepherd
                              Box, I understand your point and from a drafting point of view I agree. I'm more of a carpenter than draftsman. My interest in sketchup is drawing things I might build. If I were making this type of dentil and I had a 5/8" cutter but not a 41/64", then the teeth will be 1/64" over size. And of course the longer the run, the more precise the divisions. Perhaps my post would be better suited on a carpentercation forum. In any event I appreciate your input.
                              Regards,
                              S
                              • BoxB Offline
                                Yes, it is entirely possible to create a Dynamic Component that will behave as you describe.
