    4 mitred edges
    24 Posts 8 Posters 2.1k Views 8 Watching
    • gillesG
      gilles
      Something like this?
      done with move tool.
      autofold
        For draw the corners between 2 rectangles maybe Split Sausage by TIG can help you ?
        http://sketchucation.com/forums/download/file.php?id=83045&t=1
        • P
          pcmoor
          for a panel, draw shape them offset the thickness, select the middle area and use move(M) start operation then press "alt" to auto fold, enter thickness done.
          Can do for roof pitch also, offset run, move up (alt) the height
          Cheers
          Philip
          autofold thickness
            Yes, practical when you want the all corners, but not when you want just 3 corners πŸ˜‰
            • gillesG
              gilles
              Select the three edges you want to offset then then
              πŸ’š
                mrossk
                touche!
                https://www.mkaplanfinefurniture.com/
                  No, 3 links or more πŸ˜‰
                    Pilou, why is it that your examples have nothing to do with the original poster's question?
                      Some deviations πŸ˜„
                      But some ideas for Push Pull some drawers!
                      • T
                        tommy75
                        Hi, thanks for the replies...
                        @pcmoor: tried your example, but when I look at the bottom of the panel, it looks like this:
                        What am I dong wrong?
                          That would be correct since you haven't already made the thing 3D. Draw a rectangle, use Push/Pull to make it 3D then follow the steps to move the top surface as above.
                          • T
                            tommy75
                            Offcourse...Thanks.. Sorry for the stupid question...
                            Here's another one πŸ˜„ : Is the mitre 45 Β° using this method?
                            The drawing of gilles is almost exactly what I want to draw by the way...
                              mrossk
                              the miter will be 45 if you move the surface up or down by the thickness of the material
                                Or it will be 45Β° if you move it by the width of the offset.
                                Also, you could make the panel with the final thickness, do the offset and then select the exterior edges and move them down while holding Alt on the PC or Command on Mac.
                                If you're drawing drawer fronts you really ought to just draw them vertically from the beginning. I would draw them in place on the case to use the case as a reference for dimensions.
                                • gillesG
                                  gilles
                                  There is no stupid question, sometimes stupid answer.
                                  Use guide lines ( ) to create inference at the desired angle, length...
                                  • T
                                    tommy75
                                    I just tried it using the follow me tool, and it worked out pretty well (only did one layer though) Is there a video tutorial somewhere on this miter issue? Can't really find one that fits my question...
                                      What specifically is your question? It seems like there's several different ones throughout the thread.
                                      • T
                                        tommy75
                                        I want to draw the closet as shown in my first post. It has mitered sides, that was my initial problem. While learning and drawing it, I encounter some other things I don't know yet, so I thought I'd just ask in thios topic, because it's about the same closet... And all my questions are about the miters...
                                        • pbacotP
                                          On your last question, a picture would help to explain what you mean about taking off a "layer". Are you trying to do the miter with a follow-me? Doable. Probably not a video on "Miters" in general, as it is pretty easy and many methods. The question is what would fit your question? What's the specific question? Someone might even make a video.
                                          • gillesG
                                            gilles
                                            look at this:
                                            mitersv6.skp
