[Plugin] TT_Lib²
I'm sorry, but I am a bit confused now. Which plugins work and which plugins doesn't work?
Also, if there are error messages - what do they say? -
Also, if there are error messages - what do they say?1.tt_selection_Tools ,In sketchup8 Does not work,After opening the tool, sketchup automatically exit after a few seconds。
Hm. I'm unable to reproduce this. Maybe it happens only on XP. I have to ask someone to test for me.
Does it happen if you have only Selection Toys installed?
Did not happen, but the old version 2.2 can be used normally
hm.. if you can load Selection Toys alone, but not with the rest of your plugins it sounds like a clash. Any chance you can find out which plugin it clashes with?
Version 2.2 normal way? It will not conflict.
2.36 will flash back it?
I'm sorry, but what do you mean by "flash back"?
After opening tools, a few seconds sketchup8 automatically quit.
But doesn't happen when it is the only plugin installed?
If it crashes when you have other plugins installed, can you find out which one that will make it crash? -
Hi - Given the season - I feel like Alastair Sim haunted by the Ghost of Christmas Past dragging the chains of XP about. I loaded 2.3.6 Selection Toys - SU8 starts up - stays up - functions with no problems. All items in tool bar enabled. BTW => XP SP3 plus TT Library v2.9.4 plus I also have a gazillion plugins installed but none of the known troublemakers.
@tt_su said:
irwanwr: did 2.9.4 fix the error message you where getting?
Nope. No error at all
Selection Toys 2.3.6
Edge Tools 2.0.4
UV Toolkit 2.3.1on Win XP SP3, IE 8.
Hi, I have a question, why does appear the TT_Lib² in Disabled Extensions on SketchUcation Extensions Manager window?
In SketchUcation Plugins Manager window it appears like Plugin Loaded (see the image below).
I select TT_Lib² on SketchUcation Extensions Manager window and I push the button Load-Permanently, I close the window and quit SU, then I restart SU but TT_Lib² appears in Disabled Extensions again. -
When an Extension 'sticks' in the disabled [red] side of the Manager despite you trying to enable it, then it means that something is wrong with its code as it loads...
Have you ever disabled this Lib ?
Are you sure it is installed correctly ?Look at the files inside the Plugins folder.
If they are named ending in .rb! they manually rename them as .rb and restart SketchUp.
You should now see an error message.
This might help resolve what is wrong.If you have FULL rights to your Plugins folder and have installed the very latest versions of the Lib and other related Plugins, then there should not be any odd behavior
Maybe the PluginStore is confused over the root TT_Lib2.rb file. It implements SketchupExtension class - it it appear in the Window > Preferences > Extensions list. But unticking it won't disable TT_Lib2 because the plugins that use it load TT_Lib2/core.rb directly.
I still don't know if that is the case though, I don't know what PluginStore is doing.
When TT_Lib2 appear disabled in PluginStore - do the plugins that depend on it load?
@TT - your Lib appears in the native Extensions panel and the SketchUcation Extensions Manager.
But it fails to display details in the latter - I suspect because you've named it with a superscript 2 - because if I rename it with a normal 2 it works with details etc !
So that is probably causing subtle issues - perhaps in js ?So I know how to probably fix the issue - I'm testing it shortly...
Watch for v2.5.0 out soon...
Ah, an multi-byte character issue then.
I now have it working with the superscript 2...
Thanks TIG!
That superscript 2 has caught many off guard.
"Nobody expects Unicode multi-byte characters!"
Oddly the superscript 3 in your 'Cleanup' name works just fine.
It's only seems to be the superscript 2 !
But then even 178.chr fails too...I already knew that names including a ' or starting with '#' messed up in the ruby/js/callbacks...
I have also now found that names ending in a <space> also mess up !
But they are all trapped now.
huh! That's very odd, as I'm sure that superscript 3 is in unicode as well... :s
