    [Plugin] TT_Lib²
    310 Posts 66 Posters 499.0k Views 66 Watching
    • tt_suT
      tt_su
      @g_wilson said:
      SUCCESS !!! Thank you Thomas. Have nominated you for the "TIG" award for fast service.
      Whohoo! Sorry for the inconvenience - had I had a copy of XP it would have been fixed earlier.
      • irwanwrI
        irwanwr
        Thank you very much, Thomas.
        Love you 😄
        I don't know how to do this though;
        @tt_su said:
        Hmm... must be some differences in the environment variable between Win8/7/Vista and XP.
        Can you open the Ruby Console and give me the result of ENV.each { |k,v| puts "#{k} = #{v}" } ? Then I can make a patch for this.
        Thanks to Gary Wilson for the help 😄
        • tt_suT
          tt_su
          irwanwr: did 2.9.4 fix the error message you where getting?
          • guanjinG
            guanjin
            2.9.4+Selection_Toys,In Sketchup8 windows XP, open the dialog, automatic sketchup8 quit after tens of seconds, without any prompting。
            Edge Tools,Can not be used, loading errors。
            • tt_suT
              tt_su
              That is strange. I cannot reproduce that. By the way, Selection Toys has never used TT_Lib2. I used TT_Lib1 for a while - but I made it stand-alone earlier this year. What version of Selection Toys do you have? And if you have only Selection Toys loading, does it still crash?
              What are these loading errors? (I can't do much without them.) Also, what version of Edge Tools.
              • guanjinG
                guanjin
                Selection Toys loading2.36 Edition。
                UV Toolkit v2.31
                Are not available。Earlier versions without problems。
                • guanjinG
                  guanjin
                  [attachment=0:32tfbp3s]<!-- ia0 -->QQ图片20131211190130.jpg<!-- ia0 -->[/attachment:32tfbp3s]
                  UV Toolkit v2.31
                  TT_Lib2 2.8No problem, you can normally use
                  • guanjinG
                    guanjin
                    tt_selection_Tools ,In 2013 the working properly
                    • tt_suT
                      tt_su
                      I'm sorry, but I am a bit confused now. Which plugins work and which plugins doesn't work?
                      Also, if there are error messages - what do they say?
                      • guanjinG
                        guanjin
                        1.tt_selection_Tools ,In sketchup8 Does not work,After opening the tool, sketchup automatically exit after a few seconds。
                        • tt_suT
                          tt_su
                          Hm. I'm unable to reproduce this. Maybe it happens only on XP. I have to ask someone to test for me.
                          Does it happen if you have only Selection Toys installed?
                          • guanjinG
                            guanjin
                            Did not happen, but the old version 2.2 can be used normally
                            • tt_suT
                              tt_su
                              hm.. if you can load Selection Toys alone, but not with the rest of your plugins it sounds like a clash. Any chance you can find out which plugin it clashes with?
                              • guanjinG
                                guanjin
                                Version 2.2 normal way? It will not conflict.
                                2.36 will flash back it?
                                • tt_suT
                                  tt_su
                                  I'm sorry, but what do you mean by "flash back"?
                                  • guanjinG
                                    guanjin
                                    After opening tools, a few seconds sketchup8 automatically quit.
                                    • tt_suT
                                      tt_su
                                      But doesn't happen when it is the only plugin installed?
                                      If it crashes when you have other plugins installed, can you find out which one that will make it crash?
                                      • G
                                        g_wilson
                                        Hi - Given the season - I feel like Alastair Sim haunted by the Ghost of Christmas Past dragging the chains of XP about. I loaded 2.3.6 Selection Toys - SU8 starts up - stays up - functions with no problems. All items in tool bar enabled. BTW => XP SP3 plus TT Library v2.9.4 plus I also have a gazillion plugins installed but none of the known troublemakers.
                                        • irwanwrI
                                          irwanwr
                                          Nope. No error at all 😄
                                          Selection Toys 2.3.6
                                          Edge Tools 2.0.4
                                          UV Toolkit 2.3.1
                                          on Win XP SP3, IE 8.
                                          • OxerO
                                            Oxer
                                            Hi, I have a question, why does appear the TT_Lib² in Disabled Extensions on SketchUcation Extensions Manager window?
                                            In SketchUcation Plugins Manager window it appears like Plugin Loaded (see the image below).
                                            I select TT_Lib² on SketchUcation Extensions Manager window and I push the button Load-Permanently, I close the window and quit SU, then I restart SU but TT_Lib² appears in Disabled Extensions again.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 12 / 16
