    Emboss logo over a curved shape
    21 Posts 6 Posters 3.4k Views 6 Watching
      Buckyman
      Thanks everyone.
      I tried SuperDrape, but when I try to select the first group (the logo), SuperDrape will not select it. Maybe it thinks the log is an invalid entity.
      BTW I scaled the model 1000x to make life easier πŸ˜„
      • BoxB Offline
        Attach your model.
          Buckyman
          Thanks for the offer! File attached.
          BTW, I completely redrew the logo so it very friendly. However I am now getting bug splat whether I use regular drape or super drape.
          stl_export_7902_fillets.skp
          • BoxB Offline
            There is something screwed up with your file.
            I took the logo and the face you want to put it on and pasted them into another file.
            I exploded, cleaned up and regrouped the logo and resized everything to something realistic.
            Super drape and JPP worked fine. I have attached it for you as a finished solid. You can always use the tape tool to size it exactly to fit. But you'd be better off making or fixing your own.
            I can't tell what version of SU you are using so I saved it as SU7. Please fill in your profile.
            Super Drape solid.skp
            • cottyC Offline
              cotty
              Another possibility only with JPP and intersection...
              (scaled up before screencast 100x)
              [screenr:25iymm9r]46wH[/screenr:25iymm9r]
              my SketchUp gallery
                Buckyman
                Wow, Box & Cotty, super helpful. Thanks very much!
                • BoxB Offline
                  Now if we'd know you had SU2013 Pro we could have suggested using Solid tools.
                    Buckyman
                    Hi Box, I did update my profile as you suggested πŸ˜„
                    I can see how Solid Tools could be used, but extruding (embossing) the logo on the curved shape would not have been possible without JPP I think.
                    Cotty, at the beginning of your video, I am not sure you are doing with the lines on the casting, how are you making them disappear? Thanks
                    • BoxB Offline
                      If you extrude the logo and make it a solid you can then place it in the surface of the other solid and use subtract. But yes, getting the depth right would be troublesome because of the curve.
                      The lines can be smoothed just using the Eraser while holding ctrl, or hidden by holding shift. If you welded or recurved your profile lines you wouldn't get the lines on the surface to begin with.
                        Buckyman
                        OK I think I see what Cotty was doing, local smoothing to yield a single face.
                        I have followed Cotty's instructions, then used CleanUp v3, but when I save Sketchup prompts to fix the model, the result of which you can see below.
                        • olisheaO Offline
                          olishea
                          Turn on hidden geometry and just reverse the blue faces. (RIght click reverse faces). Or click a white face (a normal) and then right click and Orient Faces.
                          oli
